Redline releases Professional Series
by Marco620. 03/20/19 11:52 PM
M1 HM 10w-30 vs M1 FS 0w-40
by RDY4WAR. 03/20/19 10:04 PM
Need Recommendations For A New SUV
by Dwight_Frye. 03/20/19 08:50 PM
GE dishwasher clicking
by silverrat. 03/20/19 08:20 PM
Every 6 months or one year OCI
by asker123. 03/20/19 07:36 PM
Valu Home Ctr. Peak Oil $9.94/5 qt jugs
by Nickdfresh. 03/20/19 07:32 PM
Chemical fire in texas
by Fitter30. 03/20/19 07:09 PM
PZ 37 CUT OPEN
by 53' Stude. 03/20/19 06:42 PM
Lube Intervals
by NibbanaBanana. 03/20/19 06:41 PM
When to send in oil for testing?
by SnowDrifter. 03/20/19 06:12 PM
ATF vs CHF
by GG16v. 03/20/19 05:40 PM
Landline Answering Machines
by das_peikko. 03/20/19 05:10 PM
Mobil oil on “clearance” at Target
by WiskyBadger. 03/20/19 04:04 PM
Master Mechanic Motor Oil @ True Value
by CG_BrianM. 03/20/19 01:35 PM
Some cars haven't changed much in 30 years...
by addyguy. 03/20/19 01:16 PM
Super Knock - Engineering Explained
by StevieC. 03/20/19 01:11 PM
Mobil Super Synthetic Clearance at Meijer
by Tjbouwhu. 03/20/19 12:53 PM
DarkFrontier, Zuraxus, Burks21, GG16v, fleetwood62
67572 Registered Users
43 registered members (bbhero, Ag76, ArrestMeRedZ, Agnosto, Brad_C, Bailes1992, 6 invisible), 947 guests, and 57 spiders.
Topics286,170
Posts4,903,516
Members67,572
Most Online2,967
Mar 10th, 2019
Oil for a 2017 RAM CTD #4450307
07/05/17 10:58 AM
07/05/17 10:58 AM
Munster, IN
tstewart Offline OP
tstewart  Offline OP
Munster, IN
The maintenance package that I purchased from the dealer includes 10 synthetic oil changes, 10 tire rotations / balances and fluid verifications, and 5 wheel alignments. During my first oil change, the dealer used RAM part # 68218941AC oil.
The little I have been able to find regarding the RAM part # 68218941AC oil. The RAM website identifies that it is for the CTD. It is 15W-40 but the bottles do not reference that it is synthetic. Since other RAM oils do reference "Synthetic", I suspect that it is a conventional oil.
Since I paid for synthetic, I will get on them about using synthetic in lieu of the RAM part # 68218941A that is identified in their system. I am trying to verify that conventional oil is used.
Is it acceptable to use T6 year around? That is the oil the dealer used in my last EcoD.
Re: Oil for a 2017 RAM CTD [Re: tstewart] #4450343
07/05/17 11:33 AM
07/05/17 11:33 AM
Midwest, Illinois
beanoil Offline
beanoil  Offline
Midwest, Illinois
A quick Mopar part search tells me that is a 15w40.
Not likely synthetic. Synthetic is usually 5w40.
beanoil: Tough under heat, real dirty afterwards.
Re: Oil for a 2017 RAM CTD [Re: tstewart] #4450412
07/05/17 01:00 PM
07/05/17 01:00 PM
Houston, TX
2015_PSD Offline
2015_PSD  Offline
Houston, TX
T6 is a 5W-40 synthetic and works in all ranges of temperatures. If you are looking for an oil that works year round then any 5W-40 which meets the specifications for your engine will serve you well.
2018 Mercedes Benz AMG GLC43 3.0L Bi-Turbo [Castrol Edge 0W-40 & Pur filter]
2018 Mercedes Benz C300 2.0L Turbo [Pennzoil Platinum 0W-40 & Mann filter]
Re: Oil for a 2017 RAM CTD [Re: tstewart] #4450435
07/05/17 01:33 PM
07/05/17 01:33 PM
Northern Kentucky
901Memphis Offline
901Memphis  Offline
Northern Kentucky
It would be very odd for a 15w40 to be synthetic since the presence of synthetic base oils will easily put you in the 5w cold pump ability range
For some reason brings this to mind.
http://www.pqiamerica.com/May%202013/lucas.htm
2012 Chevy Cruze LT 1.4T - 59k - Edge 0w30 SL + Mahle OX401D
2002 Buick Century 144k - Built 4T65e(Maxlife) - GTX 5w30 + Fram XG3980
Re: Oil for a 2017 RAM CTD [Re: tstewart] #4450437
07/05/17 01:37 PM
07/05/17 01:37 PM
Sask, Canada
BrianF Offline
BrianF  Offline
Sask, Canada
Interesting. ya that part number comes back to the 15w40, which is rare in a synthetic. In this day in age with all the marketing hype, if it was synthetic it would be labeled as such Not like there would be anything wrong with the oil regardless. But you paid for the "synthetic" so you [censored] well better get it.
2006 Trailblazer LT. QSUD with Fram Ultra.
2017 Ram 3500 SLT Megacab. Duron SHP 10w30 with Hastings LF608.
1993 GMC 1500. QSAD with Fram PH5
Re: Oil for a 2017 RAM CTD [Re: tstewart] #4450438
07/05/17 01:38 PM
07/05/17 01:38 PM
Central Iowa
TiredTrucker Offline
Central Iowa
There are full syn 15w40's, but not very common. I would be somewhat averse to using a 15w40 in that engine, but not sure I would fret much over it. If the dealer was not using the oil I had paid for, then I would have a fit on that issue alone. Being short changed on what the consumer is paying for is immoral.
Freedom is not about having the choice to do what you want, but the choice to do what you ought.
Re: Oil for a 2017 RAM CTD [Re: tstewart] #4450644
07/05/17 06:02 PM
07/05/17 06:02 PM
NY
DdDd Offline
DdDd  Offline
NY
Why would anyone pay for dealer service outside of warranty work?!
For sure you overpaid for what you're getting. The subbing of regular for synthetic is just the tip of the iceberg. At least that's been my experience.
Simple service work gets done sloppy if at all. The money has already been had, no incentive to actually go the extra mile.
Sadly most drivers won't even notice, so the incentive to short change is even greater than yore.
Either you DIY or resign to the fact that every time you let a dealer touch your car, something new will go snap.
Re: Oil for a 2017 RAM CTD [Re: TiredTrucker] #4450652
07/05/17 06:17 PM
07/05/17 06:17 PM
Regina, Saskatchewan, Canada
Garak Offline
Garak  Offline
I agree. I have seen them, mostly in boutiques, but I don't see any overriding reason for Shell to make a special 15w-40 synthetic solely for Chrysler dealerships, given what they already have available in the Rotella lines.
Plain, simple Garak.
Re: Oil for a 2017 RAM CTD [Re: tstewart] #4450687
07/05/17 07:02 PM
07/05/17 07:02 PM
Pa, USA
NH73 Offline
NH73  Offline
Pa, USA
I tried looking for info. on that part number and surprising very little is out there. So this is way I look at it. You did buy a maintenence package that involved synthetic oil. Does the oil used say its synthetic? If not they are not holding there end of the deal up. Just don't take the answer its synthetic, demand they show it to you.
2017 Toyota RAV4 Hybrid
2004 Ford Explorer Sport Trac
2012 Gravely ZT XL 48 w/ Kawasaki FR730
Re: Oil for a 2017 RAM CTD [Re: tstewart] #4451353
07/06/17 01:58 PM
07/06/17 01:58 PM
California
SavagePatch Offline
SavagePatch  Offline
California
Highlighted in yellow is what I assume is the same oil, just different quantities. It appears that it isn't synthetic since under Product where I highlighted in Red you can see that they clearly state when an oil is synthetic.
Re: Oil for a 2017 RAM CTD [Re: tstewart] #4451358
07/06/17 02:01 PM
07/06/17 02:01 PM
California
SavagePatch Offline
SavagePatch  Offline
California
Here's the full document for reference.
Re: Oil for a 2017 RAM CTD [Re: DdDd] #4451425
07/06/17 02:59 PM
07/06/17 02:59 PM
Munster, IN
tstewart Offline OP
tstewart  Offline OP
Munster, IN
What little spare time I have is devoted to maintaining and building my road race motorcycles. That is why I pay the dealer to do oil changes. My time is much to valuable to waste on simple truck service. Their incentive is the fact that I have purchased 5 vehicles from them in the past three years. I have been working with the service manager for a number of years. The dealership will have no problem correcting the issue. I just wanted to be sure my facts are straight regarding the conventional oil used. Most likely they used the oil identified in the RAM data base not considering that it was conventional oil.
At $800.00 for 10 synthetic oil changes, 10 tire rotations / balances and fluid verifications, and 5 wheel alignments, I hardly think that I over paid. They have actually been a very responsive service department to work with over the past few years.
Re: Oil for a 2017 RAM CTD [Re: SavagePatch] #4451427
07/06/17 03:02 PM
07/06/17 03:02 PM
Munster, IN
tstewart Offline OP
tstewart  Offline OP
Munster, IN
I found the same document yesterday. I agree, if it is synthetic, it would say as such. I will just have them use T6. They stock it and used it in my EcoD. Thank you for your help.
Re: Oil for a 2017 RAM CTD [Re: tstewart] #4453734
07/08/17 07:42 PM
07/08/17 07:42 PM
Michigan
A_Harman Offline
A_Harman  Offline
Michigan
The oil they put in is probably Valvoline Premium Blue conventional in a different bottle.
1985 Z51 Corvette track car
2002 Camaro Z28 LS1/6-speed
2001 Dodge Ram 2500 diesel
1972 GMC 1500 shortbed project truck
