Mecredes Bosch vs Ngk sparks plug
by Rohan. 12/13/18 09:48 PM
Wife problem?
by penguin. 12/13/18 08:04 PM
2008 Chevy Malibu 3.6L V6
by lordcheeto. 12/13/18 07:36 PM
power company merged and I got the shaft
by motor_oil_madman. 12/13/18 07:19 PM
Space heater burnt smell
by BossMoss. 12/13/18 07:13 PM
Shell Helix Ultra Maserati 10W-60
by wemay. 12/13/18 06:53 PM
Cox Modem Info???
by Gebo. 12/13/18 06:39 PM
How are these Road Force values?
by mclasser. 12/13/18 05:19 PM
Finally broke down a bought a trailer
by BeerCan. 12/13/18 04:25 PM
What oil for '19 Subaru WRX?
by TKNY. 12/13/18 04:12 PM
Splitting wedges
by buck91. 12/13/18 04:00 PM
Avoiding rust in the rust belt states?
by Chris B.. 12/13/18 03:00 PM
Joey Logano and the 2019 Mustang
by Malo83. 12/13/18 02:40 PM
Ericbrooks, Japanese, lordcheeto, WondrousBread, slickoo9
66672 Registered Users
65 registered members (69Torino, BigShug681, Astro14, aquariuscsm, BeerCan, BlakeB, 10 invisible), 1,407 guests, and 37 spiders.
Topics295,045
Posts4,926,682
Members66,672
Most Online2,553
Oct 27th, 2018
Page 1 of 4 1 2 3 4
Thinking Too Much, Endless Possibilities #4450103
07/05/17 06:14 AM
07/05/17 06:14 AM
Alabama, United States
Red91 Offline OP
Red91  Offline OP
Basic theory: 20K OCI on a 1992 Buick Roadmaster wagon with a TBI 5.7 V8
Oil: SJ Kendall GT-1 30wt
Variables: unpredictable driving conditions, ranging from long trips to 5 minute sprints with engine on/off/on scenarios
How?: 1 solid 10K run with a filter change and top off at 10K, 1 solid 5K run with filter change and top off at 15K, another 5K run with complete oil and filter change at 20K
Why?: In theory, presuming a full quart for top off at the filter changes, the fresh 30wt oil should be sufficient to refresh the additive package and TBN, without sacrificing the tribofilm antiwear layers already in place with the used oil
Thoughts?
'89 Chevy 1500
Supertech 20/50
'15 Chevy Cruze
AcDelco syn dexos 5/30
Re: Thinking Too Much, Endless Possibilities [Re: Red91] #4450117
07/05/17 06:34 AM
07/05/17 06:34 AM
NH
supton Offline
supton  Offline
NH
What is the gain? Less oil used, less waste; or just because you can?
SJ oil?
If it was me, I'd just change it. IIRC this engine was one of those that did well on 3k OCI & dino, racking up miles and miles. Heavy car, low output engine, unknown usage. Lots of gas through the engine. Might not be "severe" but if it was me I'd err towards lower changes.
2011 Toyota Camry, base, 2.5L/6MT, 170k, hers
2010 Toyota Tundra DC, 4.6L/6AT, 144k, ours
1999 Toyota Camry LE, 2.2L/4AT, 195k, his
Re: Thinking Too Much, Endless Possibilities [Re: Red91] #4450130
07/05/17 06:59 AM
07/05/17 06:59 AM
Occupied Virginia
Bottom_Feeder Offline
Occupied Virginia
You're replenishing some of the add pack but you're not removing the contaminants.
You're under the car getting dirty anyway. Why not just change the oil?
Re: Thinking Too Much, Endless Possibilities [Re: Red91] #4450142
07/05/17 07:11 AM
07/05/17 07:11 AM
Ontario, Canada
mightymousetech Offline
Ontario, Canada
Would be a lot simpler to just change the oil every 10k instead of changing the filter every 5k. I change my filter every second oil change, a dirty filter works better than a new filter.
Mighty Mouse Tech
BMW Tech, Former Acura Tech
2010 Civic Si Castrol 0W40, Redline MTL
2013 BMW 135i M Sport Edition Castrol 0W40, Redline MTL
Re: Thinking Too Much, Endless Possibilities [Re: Red91] #4450166
07/05/17 07:32 AM
07/05/17 07:32 AM
Jupiter, Florida
Cujet Offline
Cujet  Offline
Jupiter, Florida
Unless you are using a micronic filter, and some form of contaminate reduction, that's not a recipe for maximum engine life. Microparticulates do cause wear, and pushrod engines do produce plenty of particulates.
I'd suggest a standard oil change interval, using a quality oil.
In fact, GM warranty repaired plenty of timing and balancer chains due to extended OCI's. The culprit: particulates and viscosity loss.
Re: Thinking Too Much, Endless Possibilities [Re: Red91] #4450167
07/05/17 07:33 AM
07/05/17 07:33 AM
Red91 Offline OP
Red91  Offline OP
I'm not changing the filter every 5K. The first run is 10K, then a 5K. Yes, to conserve resources. Ideally this would allow the oil to only be changed every 2 years, or 18,000 to 20,000 miles.
'89 Chevy 1500
Supertech 20/50
'15 Chevy Cruze
Re: Thinking Too Much, Endless Possibilities [Re: Red91] #4450229
07/05/17 08:45 AM
07/05/17 08:45 AM
South Texas Rancho
TexasVaquero Offline
South Texas Rancho
Sounds like a recipe for sludge in spite of having some new oil in there. As posted earlier, you wouldn't be getting rid of all the dirt.
2014 NISSAN VERSA 5spd M/T- M1 EP 5w30 and M1 EP Filter. 5k OCI.
2011 CHEVY IMPALA 3.5ltrs - M1 HM 5w30 and M1 EP Filter. 3k OCI.
Re: Thinking Too Much, Endless Possibilities [Re: Red91] #4450261
07/05/17 09:15 AM
07/05/17 09:15 AM
Waco, TX
Linctex Online content
Linctex  Online Content
Waco, TX
I'd run the cheapest oil & filter available and do 10K on each/both.
From my observations on here and personally, I see no need to do anything exotic. My 5.0 (302) has 284,000 miles on it, my 454 has 271,000 - your ol' 350 should do it easily, too.
Re: Thinking Too Much, Endless Possibilities [Re: Red91] #4450273
07/05/17 09:25 AM
07/05/17 09:25 AM
Oregon
1JZ_E46 Offline
1JZ_E46  Offline
Oregon
I'll never understand the fascination with extending drain intervals to ridiculous levels like this. Expect the oil to be the consistency of gear oil by the end of your test.
2007 X5 4.8i: M1 HM 10W-30
2016 Countryman S: EDGE 0W-30
Re: Thinking Too Much, Endless Possibilities [Re: Red91] #4450281
07/05/17 09:31 AM
07/05/17 09:31 AM
NY
demarpaint Offline
demarpaint  Offline
NY
Thoughts?
I guess at the end of the life cycle of a beater which will ultimately end up in the junkyard, why not? If you plan on keeping the car I wouldn't do it. If you plan on selling it don't reveal your oil change regime. Most car buffs will avoid vehicles which have ultra long OCI's, premium extended drain boutique oil or not.
God Bless Our Troops
Re: Thinking Too Much, Endless Possibilities [Re: Red91] #4450282
07/05/17 09:31 AM
07/05/17 09:31 AM
San Antonio, TX
E150GT Offline
E150GT  Offline
San Antonio, TX
Perhaps put a bypass filter system on it.
1984 Mercedes-Benz 300SD - 100k
1995 F150 XL 4.9 reg cab 5MT - 251k 5w30
2016 Mazda6 Touring 6MT - 57k 10w30
2006 Buick Lucerne CXL 3.8 31k 5w30
Re: Thinking Too Much, Endless Possibilities [Re: Linctex] #4450302
07/05/17 09:50 AM
07/05/17 09:50 AM
Red91 Offline OP
Red91  Offline OP
I already have cheap oil and filters.....
'89 Chevy 1500
Supertech 20/50
'15 Chevy Cruze
Re: Thinking Too Much, Endless Possibilities [Re: Red91] #4450324
07/05/17 10:19 AM
07/05/17 10:19 AM
Grand Rapids, MI
WishIhadatruck Offline
Grand Rapids, MI
I have a '96 version of your car, with an updated motor design. Not long after purchasing mine in 2006, I did a number of UOA and none of the oils I tried were happy past 5k miles. Start with a UOA at 5k miles (don't change the oil until after the results come back if you want) and go from there. I realize what you're trying to accomplish, but there is no way to know if this is an acceptable condition unless you monitor the oil somehow.
1996 Buick Roadmaster Wagon
2014 Cruze Eco Manual
2003 2500 Suburban, 8.1L
Re: Thinking Too Much, Endless Possibilities [Re: Red91] #4450398
07/05/17 11:35 AM
07/05/17 11:35 AM
Jupiter, Florida
Cujet Offline
Cujet  Offline
Jupiter, Florida
That's fine. It's not necessary. Nor will I make the absurd claim that you will experience engine failure. What you are proposing is a perfect plan for a vehicle you don't care about and don't plan on keeping all that long. Filter changes are seldom required. Oil changes are far more important.
However, as professionals know (such as myself) , via objective data, proper regular maintenance is required for maximum lifespan. My old Ford truck, very healthy at 355,000 miles is a good example of why regular service can save you time, money and hassle.
In a past life, I worked for Mobil oil and was involved in some oil and grease testing. Also worked for Mercury Marine testing oils in race engines. I now work in the high end world of G650 business jets.
The good news is that over 20,000 miles, of zero oil changes, you will have saved yourself about $25 per year.
Re: Thinking Too Much, Endless Possibilities [Re: Red91] #4450403
07/05/17 11:41 AM
07/05/17 11:41 AM
Jupiter, Florida
Cujet Offline
Cujet  Offline
Jupiter, Florida
As mentioned above, the oil change is more important than the filter change. In fact, with healthy engines, filter changes are rarely necessary.
Page 1 of 4 1 2 3 4
