- Joined
- Nov 29, 2009
- Messages
- 7,268
I bought this about a year ago and haven't really used it because it doesn't put any metal down. Even after talking to the Hobart guys, he basically said you're pretty limited using the 115V setup and 1/4" steel is about as thick as you can do with it on 115. It's the Hobart 210MVP (multi volt plug)
I ended up setting it at 7 for the voltage and 5 for the wire speed, (I may have that backwards) Anyways it comes standard with flux core wire and I've verified the polarity is correct, so what's the deal? I can hold it in one spot and it doesn't even build up any metal. Do I need to be completely inside when mig welding?
