Look How Good Our Cars Are Getting!
by ekpolk. 03/19/19 11:49 AM
Good or bad? Special ordering a brand new car?
by Ed_Flecko. 03/19/19 11:49 AM
Good Purchase?
by FordBroncoVWJeta. 03/19/19 11:33 AM
not sure what spark plugs to buy now
by MrTruckDriver. 03/19/19 11:33 AM
Tires on a Lease Return
by clarkflower. 03/19/19 11:25 AM
Auto-Rx now available on Amazon
by LarryD. 03/19/19 11:14 AM
Best place to advertise used car for sale?
by Ed_Flecko. 03/19/19 10:51 AM
A little help with a 2010 Santa Fe
by nicholas. 03/19/19 10:50 AM
Lawn Mower Battery - What's Up with That?
by Astro_Guy. 03/19/19 10:34 AM
This makes me sick
by SLO_Town. 03/19/19 10:32 AM
Slanderous Fram Orange Can Review
by doitmyself. 03/19/19 08:39 AM
MRV of PP EURO 0W40 an anomaly?
by 21Rouge. 03/19/19 08:39 AM
The Beater is Even Uglier Now!
by Delta. 03/19/19 08:28 AM
Oil viscosities at 200 to 225 F
by Snagglefoot. 03/19/19 07:35 AM
What would you do...
by Bailes1992. 03/19/19 05:28 AM
'65 Mini.
by Silk. 03/19/19 02:08 AM
Our trash guy is getting on my nerves.
by Chris142. 03/19/19 01:20 AM
Ecogard trans filter
by pda1122. 03/19/19 12:11 AM
4.3 vortec issues
by mobilaltima. 03/18/19 09:17 PM
tbann, LisaMC, chops, drsoils, Gbear
67554 Registered Users
98 registered members (77GrandPrix, AandPDan, aircooled, AdditiveOCD, 10 invisible), 2,102 guests, and 65 spiders.
Topics286,064
Posts4,901,784
Members67,554
Most Online2,967
Mar 10th, 2019
Anyone have a hobart mig welder? #4449977
07/04/17 11:09 PM
07/04/17 11:09 PM
Houston, Texas
motor_oil_madman Offline OP
Houston, Texas
I bought this about a year ago and haven't really used it because it doesn't put any metal down. Even after talking to the Hobart guys, he basically said you're pretty limited using the 115V setup and 1/4" steel is about as thick as you can do with it on 115. It's the Hobart 210MVP (multi volt plug)
I ended up setting it at 7 for the voltage and 5 for the wire speed, (I may have that backwards) Anyways it comes standard with flux core wire and I've verified the polarity is correct, so what's the deal? I can hold it in one spot and it doesn't even build up any metal. Do I need to be completely inside when mig welding?
2007.5 dodge cummins 6.7 liter. Chevron Delo400 15w40. 7000 mile or 250-300hr intervals.
Re: Anyone have a hobart mig welder? [Re: motor_oil_madman] #4449993
07/04/17 11:51 PM
07/04/17 11:51 PM
Houston, Texas
Houston, Texas
At first I was thinking it was the wind, but I did it on a day it wasn't windy at all and still didn't have any luck.
Re: Anyone have a hobart mig welder? [Re: motor_oil_madman] #4450002
07/05/17 12:20 AM
07/05/17 12:20 AM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
I have a Lincoln 135SP, (pretty close in size to yours) and it'll weld 1/4" thick pretty well when using .035" flux core with LOTS of heat and LOTS of wire speed.
Duty cycle sucks at those settings, though.... it'll over heat fast and takes a long time to cool down.
You aren't using an extension cord, are you?
Re: Anyone have a hobart mig welder? [Re: motor_oil_madman] #4450007
07/05/17 12:26 AM
07/05/17 12:26 AM
Houston, Texas
Houston, Texas
Yeah a 100ft 12 gauge cord. It will run a bead, but it's only about 1/8" wide and doesn't penetrate.
Re: Anyone have a hobart mig welder? [Re: motor_oil_madman] #4450021
07/05/17 01:11 AM
07/05/17 01:11 AM
northern NY
Driz Offline
Driz  Offline
northern NY
https://www.hobartwelders.com/weldtalk/forum.php
Give it a try here. It's a slow kite these days but the die hards are still around. It also links to manuals and other info.
Re: Anyone have a hobart mig welder? [Re: motor_oil_madman] #4450029
07/05/17 02:11 AM
07/05/17 02:11 AM
Central Washington
Colt45ws Offline
Colt45ws  Offline
Central Washington
I have a Hobart 140, am using .030 flux core, and have no problem welding 1/8" and 3/16" material. I have confidence I could do 1/4" as well.
I did modify it a little. It had a pathetic 14ga 15amp cord. I opened it up and replaced it with 10ft of 10ga SJOOW with a L5-30 plug on the end. Then that plugs into a 50ft 10ga extension running to an L5-30 outlet I added to my garage which gives me anywhere in my garage and then a little bit out of it. My generator has that particular plug for remote locations as well.
Across 100ft of 12ga extension, you are losing 6 or 7 volts. Depending on where your at on the circuit and how far it is from the breaker would could be losing another 3 or 4 volts there.
Heres some things I welded recently.
Boxing a control arm. The plate Im adding is 1/8", but the control arm is not...is probably 12ga or close to it.
Here I added a 3/16 brace to one of the control arm mounts.
-Colton
2002 Ford Crown Vic PI 207k, Ex-Kootenai County, ID Unit #42
Down for engine swap
2003 Ford Crown Vic PI 86k
Pennzoil Conv HM 5W30, Fram XG2
Re: Anyone have a hobart mig welder? [Re: Driz] #4450033
07/05/17 03:12 AM
07/05/17 03:12 AM
northern NY
Driz Offline
Driz  Offline
northern NY
And yes that's supposed to be SITE not kite but can't change i.e. , [censored] autospell!
For anything bigger than fenders and like I always grab the good old Tombstone arc welder. It's just easier to switch electrodes than changing reels. You never have penetration issues with one of those but you need a 220 dryer outlet or similar to plug in. Always cheap on Craig's list for a song as guys have to move up to a mig rig to weld better, or so they think.
FYI I have to always run my hh135 at least a setting higher than the recommended setting always it seems.
Re: Anyone have a hobart mig welder? [Re: motor_oil_madman] #4450088
07/05/17 06:46 AM
07/05/17 06:46 AM
KY
pburchett Offline
pburchett  Offline
KY
I have the Hobart 140 mig welder. It is 120volt and I have no problem with something that thick using flux core wire. I normally turn a box fan on to blow the smoke away from me as flux core is designed for outside windy areas. I would think the 100ft extension cord is killing your welds. Try it without the 100ft cord.
Re: Anyone have a hobart mig welder? [Re: motor_oil_madman] #4450092
07/05/17 06:56 AM
07/05/17 06:56 AM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
Is it sputtering? Do you have enough drive roller tension? I use a Millermatic 211 inverter mig with Steel Mix gas on 125 for thin stuff and it goes like a house on fire, thicker gets the 220v. For the automotive work I do it more or less lives on 125V, it does sheet metal really nice.
I have an old regulator (works great) here if you want it, just buy a gas bottle and trade in when its empty at Airgas. Let me know and I will send it to you.
Re: Anyone have a hobart mig welder? [Re: motor_oil_madman] #4450109
07/05/17 07:19 AM
07/05/17 07:19 AM
Central Coast, Calif.
tom slick Offline
tom slick  Offline
If you pull the trigger holding the gun in the air does the wire feed out smoothly and quickly?
You get what you pay for...
So keep in mind how much you paid for this advice.
Re: Anyone have a hobart mig welder? [Re: motor_oil_madman] #4450111
07/05/17 07:25 AM
07/05/17 07:25 AM
Sav ga
NStuart Offline
NStuart  Offline
Sav ga
Can you not run it with 75\25 instead of flux. As other have said lose the extension cord, put it on its own 20 or 30 amp circuit.,if you insist on an extension cord hf has a cheap,heavy duty cord if welded with. My Lincoln welder from home depot works great!
Detroit14l 1m75k mi bp schaffer9k 30k oil
96 ram 5.9 gas 80k built tranny 5k m1
85 cj7 4.2 performance build. Schaeffer 9000
08 cbr600rr graffiti. T6
08 husky sm610 t6
Re: Anyone have a hobart mig welder? [Re: motor_oil_madman] #4450207
07/05/17 09:21 AM
07/05/17 09:21 AM
Houston, Texas
Houston, Texas
This is why I was looking at an engine driven welder. That way I could power it off a 50amp outlet. Any setting less than 6 or 7 it sputters, yes the wire feeds out quick.
Re: Anyone have a hobart mig welder? [Re: motor_oil_madman] #4450236
07/05/17 09:49 AM
07/05/17 09:49 AM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
I'd love to see a video of what's going on.
You are losing more than 6-7 volts from that 100' cord. As it heats up, resistance increases.
Get a heavier cord (10 gauge)
Keep playing with the settings. On the Lincoln SP135, I think the heat knob is maXxed out when on 1/4" steel - and the wire is really, really flowing!
Re: Anyone have a hobart mig welder? [Re: motor_oil_madman] #4450729
07/05/17 07:39 PM
07/05/17 07:39 PM
Trav Offline
Trav  Offline
Hold it a an inch away from the metal and trigger it with no ground clamp so it doesn't fire, if it doesn't start bending the wire and continue to feed under pressure tighten the drive roller till it does.
Re: Anyone have a hobart mig welder? [Re: motor_oil_madman] #4451389
07/06/17 02:30 PM
07/06/17 02:30 PM
Sav ga
NStuart Offline
NStuart  Offline
Sav ga
I damaged the casing inside one time which caused intermittent feeding issues,replaced and g2g
08 husky sm610 t6
