Bank 1 on an Equinox
by Washoe_Mark. 03/20/19 08:47 AM
How do you pronounce the word Vehicle?
by ZZman. 03/20/19 08:21 AM
Inline Fuel Filter
by CCI. 03/20/19 08:08 AM
Are All Douglas Tires USA Made?
by Miller88. 03/20/19 07:30 AM
Turn signal bulbs for '15 BMW?
by Benzadmiral. 03/20/19 07:02 AM
Drain/refill vs diy flush?
by Back40. 03/20/19 05:59 AM
Valvoline 5w30 Synpower HSTS?
by avi1777. 03/20/19 05:05 AM
Castrol Edge 5W50 "Supercar Titanium FST"
by Berto. 03/20/19 02:43 AM
The power of reaching out
by SlavaB. 03/20/19 12:57 AM
Used brake fluid
by OilUzer. 03/19/19 11:26 PM
Look what I found
by deven. 03/19/19 11:23 PM
91 E-free, or 91 "up to 10%" for GDI?
by Ws6. 03/19/19 11:12 PM
Ford 2019 F350 oil
by arowbat. 03/19/19 11:04 PM
Royal purple discontinuing 30-1218 ?
by jmj540. 03/19/19 10:02 PM
Nissen Radiator Review
by zmelli. 03/19/19 09:01 PM
March madness
by gman2304. 03/19/19 08:36 PM
Shell Rotella T6 5W-30 Multi
by kstanf150. 03/19/19 08:21 PM
New Toyota Tacoma oil recommentation
by Moondawg. 03/19/19 08:11 PM
Which oil for modified turbo engine?
by headoff93. 03/19/19 08:02 PM
Saxman657, Maxxforce, Washoe_Mark, CG_BrianM, TBF
67565 Registered Users
105 registered members (69Torino, 2012AccentSE, 2010Civic, 69GTX, 1978elcamino, 8 invisible), 1,802 guests, and 51 spiders.
Topics286,112
Posts4,902,848
Members67,565
Most Online2,967
Mar 10th, 2019
Best way to grip a semi automatic pistol #4449902
07/04/17 09:44 PM
07/04/17 09:44 PM
N.C.
gman2304 Offline OP
gman2304  Offline OP
N.C.
https://www.youtube.com/watch?v=KJrA7wMXuuQ
I've tried several different grips, but keep coming back to this old tried and true grip. Do you guys have any slight variances?
Re: Best way to grip a semi automatic pistol [Re: gman2304] #4450003
07/05/17 12:21 AM
07/05/17 12:21 AM
Louisiana
SuzukiGoat Offline
SuzukiGoat  Offline
Louisiana
I grip every gun slightly differently. The 1911 drops into my hand and "feels" right.
But the glock feels like an extension of my arm when holding it.
2003 Nissan Xterra 4x4 M1 HM 10w40
2001 Toyota 4runner 4x4 M1 0w40
2016 Yamaha YXZ1000R VR1 20w50
Re: Best way to grip a semi automatic pistol [Re: gman2304] #4450035
07/05/17 03:21 AM
07/05/17 03:21 AM
northern NY
Driz Offline
Driz  Offline
northern NY
Whatever works best for you. Just keep in mind clearance for slide recoil . When that slide hits your thumb it bleeds like [censored]. Do it in winter it makes loading really hard with the blood getting all over the rounds and mags. You'll only do it once usually though. Two hands makes sure you don't stick your other hand out in front. Just a good habit to form. Some fine day try shooting Gangsta style, sideways like on tv. It'll show you how stupid these guys are. crazy
Don't forget your stance. Basically there's Bladed with one foot ahead of the other then Weaver. Weaver makes you a wider easier to hit target in police circles.
Re: Best way to grip a semi automatic pistol [Re: gman2304] #4450076
07/05/17 06:11 AM
07/05/17 06:11 AM
Virginia Beach
Astro14 Offline
Astro14  Offline
Virginia Beach
Weaver stance is, essentially, bladed. Feet about 45 degrees to the target. LAPD detective named Weaver was the proponent of this in the 60s...
Feet perpendicular to the direction of the target, arms equal, is called isosceles. This is the current thinking.
Prior to Weaver, the preferred stance was quite varied, but much was made of facing 90 degrees to the target (fully bladed) with the shooting arm straight out, to present as little target to he opponent as possible.
Regardless of stance, grip is important. The video was good, and essentially what I was taught in training.
High on the frame with the strong hand, firm, but not so tight as to lose fine motor control of your trigger finger. The placement of your support hand becomes the issue. I put the heel of my support hand in the gap left by my strong hand, wrap my support fingers around my strong fingers, and just leave my thumb parallel and forward of my strong thumb.
Basically, just what he shows in the video.
If you use your pistol defensively, then shooting strong hand only and support hand only is absolutely necessary. Principles remain the same, high on the frame. Firm. Wrist straight. Good control is more of a challenge with one hand shooting.
32 Packard 15W40
02 Volvo V70 T5 0W40 M1
02 Volvo V70 XC 0W40 Edge
05 MB S600 0W40 M1
Re: Best way to grip a semi automatic pistol [Re: gman2304] #4450149
07/05/17 08:19 AM
07/05/17 08:19 AM
PV Az @ 5000'
AZjeff Offline
AZjeff  Offline
PV Az @ 5000'
popcorn2
A variation you can try is how your hand actually grips the pistol. Instead of the common squeeze grip that presses your fingertips into the side of the grip and the grip presses into your palm, try the "vice" grip where you squeeze the front of the grip with the 2nd joint in you fingers and it presses straight back into the base of your thumb.
thanks for the video.
86 Samurai 1.3 leftovers
14 RAV4 2.5 5W-20 PP
16 Silverado 1500 4.3, DI, AFM 5W-30 PP
The most important thing to do in your life is to not interfere with someone else's life. - Frank Zappa
Re: Best way to grip a semi automatic pistol [Re: gman2304] #4450260
07/05/17 10:14 AM
07/05/17 10:14 AM
PA
MarcS Offline
MarcS  Offline
PA
The late Paul Gomez breaks down the thumbs-forward grip https://www.youtube.com/watch?v=LJOslIIfggk
Re: Best way to grip a semi automatic pistol [Re: Driz] #4450321
07/05/17 11:14 AM
07/05/17 11:14 AM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
I wonder if it originated from having weak mag spring issues in their $50 SA's...
You know, if you're having feed issues, let gravity help!
Re: Best way to grip a semi automatic pistol [Re: gman2304] #4450332
07/05/17 11:23 AM
07/05/17 11:23 AM
Elizabethtown, Pa
Al Offline
Al  Offline
Elizabethtown, Pa
My instructor is very high on keeping the strong hand thumb loose bc keeping it tight affects trigger finger action. As a result he (and now me) keep the right hand thumb pointing almost straight up...this way you will be more inclined to keep it loose. Also it allows you to bring the base of the left hand thumb to rotate up closer to the top of the gun.
Honestly there are different positions that work (as mentioned) But..I highly recommend a competant ionstructor who will be able to adjust your grip based on how well you are shooting. Theere are so many things ionvolved that you won't get it right with personal instruction.
My instructor has trained with the "Sheriff of Baghdad"
https://sofrep.com/54861/watch-find-out-how-john-shrek-mcphee-became-the-sheriff-of-baghdad/
Re: Best way to grip a semi automatic pistol [Re: gman2304] #4450434
07/05/17 01:33 PM
07/05/17 01:33 PM
KingCake Offline
KingCake  Offline
I followed this instructor's advice. Helped me out.
https://www.youtube.com/watch?v=XQy5yKN-2vw
Re: Best way to grip a semi automatic pistol [Re: gman2304] #4563121
11/03/17 03:55 PM
11/03/17 03:55 PM
Canyon County Idaho
CT8 Online content
CT8  Online Content
Canyon County Idaho
Jerry Miculeck videos are lots of fun. link to videos
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: Best way to grip a semi automatic pistol [Re: Astro14] #4564252
11/04/17 07:35 PM
11/04/17 07:35 PM
Elizabethtown, Pa
Al Offline
Al  Offline
Elizabethtown, Pa
You can grip everything as tight as you want.....the key is to keep your dominant thumb loose. My instructor wants me to have this thumb pointing up to insure it is loose. The thing is; having that thumb loose insures you have good trigger control.
Re: Best way to grip a semi automatic pistol [Re: Al] #4565093
11/05/17 05:39 PM
11/05/17 05:39 PM
Ruidoso, NM USA
ammolab Offline
ammolab  Offline
Ruidoso, NM USA
Just keep it away from the slide stop!
2009 Honda CR-V
2011 BMW R1200R
2005 Kaw Ninja 250
1994 Jeep Wrangler 2.5L
2016 Chevy SS Sport Sedan
Re: Best way to grip a semi automatic pistol [Re: gman2304] #4565189
11/05/17 07:18 PM
11/05/17 07:18 PM
Houston, TX
2015_PSD Offline
2015_PSD  Offline
Houston, TX
One tidbit to add is make sure your supporting hand is at a 45 degree angle when it is opened. This ensures the wrist of the supporting hand is locked and aids in recoil management.
2018 Mercedes Benz AMG GLC43 3.0L Bi-Turbo [Castrol Edge 0W-40 & Pur filter]
2018 Mercedes Benz C300 2.0L Turbo [Pennzoil Platinum 0W-40 & Mann filter]
