Finally broke down a bought a trailer
by BeerCan. 12/13/18 04:25 PM
What oil for '19 Subaru WRX?
by TKNY. 12/13/18 04:12 PM
Splitting wedges
by buck91. 12/13/18 04:00 PM
Avoiding rust in the rust belt states?
by Chris B.. 12/13/18 03:00 PM
Joey Logano and the 2019 Mustang
by Malo83. 12/13/18 02:40 PM
BMW LL01FE Spec
by The Critic. 12/13/18 02:03 PM
I Tried and Failed to Not Buy a New Car
by badtlc. 12/13/18 01:49 PM
OEM Brand Coolant by Rocochem
by NumbersGuy. 12/13/18 01:15 PM
Motomaster Dexron Vi Fully Synthetic
by Gannet167. 12/13/18 12:55 PM
Hacked
by Smoky14. 12/13/18 12:41 PM
Scanning for U codes.
by LeakySeals. 12/13/18 12:23 PM
Food photography trickery
by nthach. 12/13/18 11:29 AM
oil for 2.5 2013 vw passat?
by jstert. 12/13/18 09:47 AM
Scotty Kilmer Parody
by oilpsi2high. 12/13/18 09:41 AM
ID this old tool
by John_Conrad. 12/13/18 09:30 AM
Weak New CR2032/remote start + fob batteries
by redhat. 12/13/18 09:23 AM
WondrousBread, slickoo9, turntable_life, Poles19, HinaMach
66669 Registered Users
100 registered members (Bbonez, andyd, aquariuscsm, Astro14, 2K2AcuraTL, Baracoa, 14 invisible), 1,915 guests, and 40 spiders.
Topics295,032
Posts4,926,408
Members66,669
Most Online2,553
Oct 27th, 2018
Page 1 of 3 1 2 3
HDEO in 284k miles Corolla #4449893
07/04/17 08:30 PM
07/04/17 08:30 PM
Venezuela, South America
Emanuel Offline OP
Emanuel  Offline OP
Hello, I am from Venezuela and I currently own a 2001 Toyota Corolla with an 7AFE engine. It has almost 284k miles and its burning almost 1 qt per 1k miles. We have a very warm climate, the coldest temperature is 65F and the hottest is 100F so Ive been using 20w50 Conventional Oil in it, I know it is not the best viscosity so Im planning to use 15w40 in my next oil change.
Im planning to use an HDEO that has an SN Rating which is the one the owners manuals ask for. Here in Venezuela, diesel has a very high sulphur content, I think that is important for the oil properties.
The differences that I see in the website of the brand of oil I use is that the 20w50 Conventional that I use currently has a TBN of 6 and the HDEO 15w40 Conventional has a TBN of 12.
Do you think it will be safe to use this oil? my car has a cat delete so Im not concerned about that but I dont know if it will be safe for the oxygen sensor.
Re: HDEO in 284k miles Corolla [Re: Emanuel] #4449895
07/04/17 08:32 PM
07/04/17 08:32 PM
Michigan
daves87rs Offline
daves87rs  Offline
Michigan
Think that it would be okay....
Coming together is a beginning; keeping together is progress; working together is success.
Henry Ford
Re: HDEO in 284k miles Corolla [Re: Emanuel] #4449914
07/04/17 08:57 PM
07/04/17 08:57 PM
Emanuel Offline OP
Emanuel  Offline OP
What happens if TBN is to high? Can it be bad? I know that starting TBN isnt the most important thing but is TBN retention over time that is more important but I ask it as a theorical question
Re: HDEO in 284k miles Corolla [Re: Emanuel] #4449918
07/04/17 09:00 PM
07/04/17 09:00 PM
Fort Worth TX
TheKracken Offline
TheKracken  Offline
Fort Worth TX
TBN shouldnt be any issue for your vehicle. We have a poster on here with Corrolla with miles near you and he runs toyota 0w20 with good results.
2011 Prius 96k miles RLI 5w20
97 Toy T100 4x4: amsoil 0w20 242k Miles
04 Toy Sienna awd: Pennzoil 0w20 281k Miles
Re: HDEO in 284k miles Corolla [Re: Emanuel] #4449924
07/04/17 09:04 PM
07/04/17 09:04 PM
Gold Coast, QL, Australia
19jacobob93 Offline
19jacobob93  Offline
Would be perfectly fine!
I have run everything between 10w30 and 20w50 in my car without problems or side effects, and it seems to love the 15w40 HDEO diesel oil in it now, bearing in mind both our engines have the same viscosity recommendations at least in Aus.
You could run any of those viscosities in your climate, your summer is probably similar to where I am but winters can get below freezing here and the 20w50 made for some slow winter cranks...
Car: 2000 Ford Falcon AU2 - 4.0L I6 @330,000km
Oil: Castrol GTX HM 15W50 + LM MoS2
Filter: Ryco Z9
Re: HDEO in 284k miles Corolla [Re: TheKracken] #4449932
07/04/17 09:13 PM
07/04/17 09:13 PM
Emanuel Offline OP
Emanuel  Offline OP
Wow, that is interesting, I would guess it would blow up.
Re: HDEO in 284k miles Corolla [Re: 19jacobob93] #4449935
07/04/17 09:16 PM
07/04/17 09:16 PM
Emanuel Offline OP
Emanuel  Offline OP
The viscosity recomendation of the owners manual is very ambiguous in my car. It says that I can use anything from 5w30 to 20w50 depending of the temperatures. In the climate that I live that means I can use anything from 10w30 to 20w50.
Re: HDEO in 284k miles Corolla [Re: Emanuel] #4449939
07/04/17 09:21 PM
07/04/17 09:21 PM
Crawfordville FL
SilverFusion2010 Offline
Crawfordville FL
I would run 10w-30. Thick enough to do the job, saves a bit of fuel compared to the thicker grades.
Seriously 10w-30 will be ok
2010 Ford Fusion SE 3.0L V6, 181 miles M1 HM 10w-30
Re: HDEO in 284k miles Corolla [Re: SilverFusion2010] #4449947
07/04/17 09:28 PM
07/04/17 09:28 PM
Emanuel Offline OP
Emanuel  Offline OP
Couldnt the oil consumption go extremely higher if I use that viscosity?
Re: HDEO in 284k miles Corolla [Re: SilverFusion2010] #4449952
07/04/17 09:32 PM
07/04/17 09:32 PM
Emanuel Offline OP
Emanuel  Offline OP
By the way here in Venezuela gasoline is almost free, 100 gal cost 0.3$
Re: HDEO in 284k miles Corolla [Re: Emanuel] #4449955
07/04/17 09:38 PM
07/04/17 09:38 PM
Crawfordville FL
Crawfordville FL
So enjoy a bit more power compared to the 20w-50.
Try it. If you don't like it you can always change it.
I think both you and your car will like it.
Yes it could increase consumption, but depending on the cause it could reduce it. If it does burn it faster then you can just top off with a thicker oil
Re: HDEO in 284k miles Corolla [Re: SilverFusion2010] #4450006
07/04/17 11:26 PM
07/04/17 11:26 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
I'd just run the cheapest oil you can get for it, as long as consumption doesn't go up drastically.
Re: HDEO in 284k miles Corolla [Re: Emanuel] #4450027
07/05/17 12:49 AM
07/05/17 12:49 AM
'Stralia
Shannow Offline
Shannow  Offline
'Stralia
Here's a 2006 Yaris UAO on HD engine oil...
https://bobistheoilguy.com/forums/ubbthreads.php/topics/4450017/Re:_Penrite_Diesel_FX_-_Toyota#Post4450017
Re: HDEO in 284k miles Corolla [Re: Emanuel] #4450031
07/05/17 01:56 AM
07/05/17 01:56 AM
Los Angeles, California
Gokhan Offline
Gokhan  Offline
You have an engine that uses more oil than gas and you're losing sleep over its oxygen sensor? wink
Catalysts shouldn't be deleted for obvious pollution reasons.
This said, I had the same problem in my Corolla and ran 15W-40 for many years. Corollas like thinner oils (less sluggish) but run the cheapest thick oil because of your consumption as others said.
Here is the remedy. Unfortunately Photobucket has recently stopped the third-party hosting of images for free accounts:
Wonders of valve-stem oil seal replacement
1985 Toyota Corolla LE, 4A-LC engine, ~ 271,000 M
Toyota (TGMO) 0W-20 SN high-moly GTL (© 2015 reformulation)
Mobil 1 EP M1-103 filter, 90430-12031 drain gasket
Re: HDEO in 284k miles Corolla [Re: Emanuel] #4450120
07/05/17 06:41 AM
07/05/17 06:41 AM
Toronto, Canada
HKPolice Offline
HKPolice  Offline
Toronto, Canada
Using thicker oil won't stop the oil from leaking into your engine. Fix the leak!
Page 1 of 3 1 2 3
