Valvoline 5w30 Synpower HSTS?
by avi1777. 03/20/19 05:05 AM
Castrol Edge 5W50 "Supercar Titanium FST"
by Berto. 03/20/19 02:43 AM
The power of reaching out
by SlavaB. 03/20/19 12:57 AM
Used brake fluid
by OilUzer. 03/19/19 11:26 PM
Look what I found
by deven. 03/19/19 11:23 PM
91 E-free, or 91 "up to 10%" for GDI?
by Ws6. 03/19/19 11:12 PM
Ford 2019 F350 oil
by arowbat. 03/19/19 11:04 PM
Royal purple discontinuing 30-1218 ?
by jmj540. 03/19/19 10:02 PM
Nissen Radiator Review
by zmelli. 03/19/19 09:01 PM
March madness
by gman2304. 03/19/19 08:36 PM
Shell Rotella T6 5W-30 Multi
by kstanf150. 03/19/19 08:21 PM
New Toyota Tacoma oil recommentation
by Moondawg. 03/19/19 08:11 PM
Which oil for modified turbo engine?
by headoff93. 03/19/19 08:02 PM
Problems After Adding 2 Stroke To Diesel
by InfernoRedBeast. 03/19/19 07:47 PM
Amsoil filter
by Bill_W. 03/19/19 07:01 PM
My $1 ocod 4k
by Pinoak. 03/19/19 06:58 PM
GMC tailgate latch repair question
by aquariuscsm. 03/19/19 06:49 PM
Can I Use Maple Syrup Instead Of Oil ?
by Warstud. 03/19/19 06:09 PM
Should criminals be given a second chance?
by ZZman. 03/19/19 04:28 PM
Washoe_Mark, CG_BrianM, TBF, mm2020, emepher
67563 Registered Users
68 registered members (69Torino, avi1777, 2015_PSD, 87sammy, 97K15004WD, ArrestMeRedZ, 5 invisible), 777 guests, and 53 spiders.
Topics286,105
Posts4,902,665
Members67,563
Most Online2,967
Mar 10th, 2019
GM 2012 AAM 8.6" rear diff need additive? #4449788
07/04/17 07:37 PM
07/04/17 07:37 PM
In
SquirrelMan Offline OP
In
Hello, I am new.
This is a Chevy 1500 crew cab half ton, 2012 5.3L. I find it hard to find specific info on the additive question. the VIN code does not tell me if it's locking or limited slip. It only tells me 3:42 ratio. I have read where someone on here said all GM after a certain date uses NO additive.
My father and I serviced my rear diff, we put Mobil 1 synthetic 75w90 and NO additive. I don't hear any noise out of it; did we do right by not using a friction modifier?
Re: GM 2012 AAM 8.6" rear diff need additive? [Re: SquirrelMan] #4449792
07/04/17 07:41 PM
07/04/17 07:41 PM
BC, Canada
userfriendly Offline
BC, Canada
Re: GM 2012 AAM 8.6" rear diff need additive? [Re: SquirrelMan] #4449796
07/04/17 07:46 PM
07/04/17 07:46 PM
In
In
Thanks for that fast response. Much appreciated
Re: GM 2012 AAM 8.6" rear diff need additive? [Re: SquirrelMan] #4449803
07/04/17 07:55 PM
07/04/17 07:55 PM
In
In
So I do have the G80 locking differential? That's good info to know. Confusing on the web if you're not a diff expert.
Re: GM 2012 AAM 8.6" rear diff need additive? [Re: SquirrelMan] #4449810
07/04/17 08:01 PM
07/04/17 08:01 PM
Specific Ocean
Kibitoshin Offline
Kibitoshin  Offline
Specific Ocean
Check the RPO codes in the glovebox if you have the "G80" RPO code. These trucks either have an open or auto locking diff from the factory where they don't need additional LS additives.
Shin Gekiretsu Shin'ou'hou
01 Toyota Tundra 2WD V8 4.7L
02 Chevy Silverado C1500 V8 5.3L
Re: GM 2012 AAM 8.6" rear diff need additive? [Re: SquirrelMan] #4449818
07/04/17 08:13 PM
07/04/17 08:13 PM
In
In
I most certainly do have the G80 RPO code; this forum is awesome. It sure helps to talk with knowledgeable people in this field. Thank you very much. To both of you.
Re: GM 2012 AAM 8.6" rear diff need additive? [Re: SquirrelMan] #4449825
07/04/17 08:18 PM
07/04/17 08:18 PM
BC, Canada
BC, Canada
One more little tid-bit; The Max-Trailer option gives you the bigger 9.76" diff.
3.76 with the 6 speed, 3.42 & 3.23 with the 8 & 10 speed 90Es.
Re: GM 2012 AAM 8.6" rear diff need additive? [Re: SquirrelMan] #4449845
07/04/17 08:36 PM
07/04/17 08:36 PM
In
In
That's good to know... Thanks
Re: GM 2012 AAM 8.6" rear diff need additive? [Re: SquirrelMan] #4450059
07/05/17 05:09 AM
07/05/17 05:09 AM
ROCHESTER, NY
Char Baby Offline
Char Baby  Offline
ROCHESTER, NY
Maybe your rear diff doesn't require an additive however, the synthetic Mobil 1 75W90 LS that you put in your differential already carries the limited slip additive hence the "LS" designation.
Also if it's any consolation, using the "LS" additive in a differential that doesn't require it, won't hurt anything either! : )
"Retired"
'15 Nissan Altima 2.5 SV
'15 Honda Civic LX
Re: GM 2012 AAM 8.6" rear diff need additive? [Re: SquirrelMan] #4450063
07/05/17 05:26 AM
07/05/17 05:26 AM
Texas
4WD Offline
4WD  Offline
Texas
Used that on several of those diffs through the years ... Delvac 1 now & some Delo on deck ...
Re: GM 2012 AAM 8.6" rear diff need additive? [Re: SquirrelMan] #4450125
07/05/17 07:47 AM
07/05/17 07:47 AM
socal
barkingspider Offline
socal
My escalade has the G80 and it does NOT need the limited slip additive in the rear diff
06 Cadillac Escalade Ext
17 Cadillac ATS (wife)
05 Toyota Camry (daughter)
11 GMC Canyon off-road (daily)
Re: GM 2012 AAM 8.6" rear diff need additive? [Re: barkingspider] #4450155
07/05/17 08:21 AM
07/05/17 08:21 AM
Texas
4WD Offline
4WD  Offline
Texas
Same - ran several G80's off M1 ... in fact cured cornering chatter in one ...
My current G80 went 40k on it before D1 went in ... that fluid looked new
Re: GM 2012 AAM 8.6" rear diff need additive? [Re: SquirrelMan] #4450440
07/05/17 01:41 PM
07/05/17 01:41 PM
Sask, Canada
BrianF Offline
BrianF  Offline
Sask, Canada
My trailblazer has the G80. It is running Amsoil 75w90 without any additive. 5 years on this oil and it is as smooth as it ever was.
2006 Trailblazer LT. QSUD with Fram Ultra.
2017 Ram 3500 SLT Megacab. Duron SHP 10w30 with Hastings LF608.
1993 GMC 1500. QSAD with Fram PH5
Re: GM 2012 AAM 8.6" rear diff need additive? [Re: SquirrelMan] #4450795
07/05/17 08:42 PM
07/05/17 08:42 PM
In
In
Thanks for all the replies; great information. If any questions arise when we service the transfer case and front diff; I know where to come. Thanks a million.
