European Formula: Supertech and Mobil 1
by Snagglefoot. 09/25/18 02:19 AM
KFE brake pads?
by deoxy4. 09/25/18 01:16 AM
GM Marine Engine wont start
by Gito. 09/24/18 11:59 PM
New TV bad picture some channels part2
by raaizin. 09/24/18 10:46 PM
Another Bad PCM on a Buick 3.8L!
by clinebarger. 09/24/18 10:17 PM
Funny pictures thread
by JLTD. 09/24/18 08:40 PM
Redline 15w40: Low or Mid Saps?
by SavagePatch. 09/24/18 06:59 PM
What are these cables to?
by 99Eclipse. 09/24/18 06:44 PM
Help with parasitic draw?
by buck91. 09/24/18 05:57 PM
Costco Car Buying Program
by dkryan. 09/24/18 05:39 PM
Glass Scrub?
by buck91. 09/24/18 05:03 PM
Loosing coolant from somewhere
by NICAT. 09/24/18 03:47 PM
2010 or so Ford Fusion Sport thoughts?
by ZZman. 09/24/18 03:35 PM
My boss killed his jeep.
by Chris142. 09/24/18 02:40 PM
Moly question about walmart oils
by jayjr1105. 09/24/18 02:33 PM
Questions About 9011 Bulbs
by knerml. 09/24/18 02:23 PM
fortim, albert001, LG_Electronics, TCam, OzFrog
66063 Registered Users
30 registered members (Aero540T, Black_Thunder, 2015Corolla, Bailes1992, avi1777, Bjornviken, 4 invisible), 421 guests, and 34 spiders.
Topics290,967
Posts4,853,505
Members66,063
Most Online3,590
Jan 24th, 2017
Splitfire copper plugs after 36k photos #4449600
07/04/17 04:59 PM
07/04/17 04:59 PM
Flaherty, KY
92saturnsl2 Offline OP
Flaherty, KY
Surely you folks will remember the splitfire spark plugs that came out sometime in the 90's-- they made all these claims about how great your engine will run with these plugs, were heavily advertised on TV, magazines, etc. I found them on closeout at Rockauto for about a buck a piece.
They were run in my '04 Honda Odyssey 3.5L V6 for about 36k, the interval I usually run copper plugs for. Before putting in these plugs, I had the engine out of the van for a rebuild-- I did everything but the bottom end. New seals/gaskets, cylinder heads went to machine shop for a valve job, new seals and milled the head. Reason was that the PO overheated the thing and blew a headgasket. Compression was good so I left the pistons/rings/bearings (the entire bottom end) alone. Van has run great since, no issues.
Plugs look to have normal wear for 36k miles. Color was a nice grey/tan-- a tad bit of deposit accumulation, but otherwise a clean plug. My conclusion is that the split-fire design is pure marketing hype, as the center electrode wore down primarily in one location (the rear, toward the outside electrode) on all plugs. That seems to go against the marketing which suggests the split ground electrode promotes multiple spark paths. There is zero evidence that the design allows the plug to last longer, as these are well used up and definitely due for replacement.
I once helped a buddy change plugs on his Jeep Commander that was misfiring. He ran copper plugs over 100k, and at that point the center electrode was worn down below the ceramic insulator, but many were still firing in that condition. So surely I could have run these longer, however the center electrodes were extremely rounded off and the gap had widened significantly from the 0.044 they were originally set at.
I have six more new ones that I'll be putting back in. Not a bad plug, but similar performance to an Autolite or other cheap copper plug, in my opinion. The only good thing worth noting is that they're made in the USA. Someone correct me if I'm wrong, but I don't think they're made any longer. I don't mind running coppers in this engine; they are super easy to change for a transverse engine-- literally a 5 minute job.
1985 F-250HD 7.5L 4x4 135k- Maxlife 15w-40 HDEO
04 Odyssey EX 182k PUP 0w-40
96 Maxima GLE 250k QS Defy 5w-30
07 Chrysler Pacifica Limited 129k PUP 5w-40
Re: Splitfire copper plugs after 36k photos [Re: 92saturnsl2] #4449614
07/04/17 05:10 PM
07/04/17 05:10 PM
Deplorable in apple valley, ca
Chris142 Offline
Chris142  Offline
Ya they had some wild claims about those plugs. A plug will only spark to one side not both like they claimed.
02 Wrangler durablend 10w40
87 F250 traveler 15w40
04 Tahoe super-s 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
Re: Splitfire copper plugs after 36k photos [Re: 92saturnsl2] #4449631
07/04/17 05:21 PM
07/04/17 05:21 PM
Melbourne, Florida
RichardS Offline
RichardS  Offline
Melbourne, Florida
Help me here.
If the gap expanded on one side as the copper eroded, wouldn't the spark start traveling from the other side to a closer ground?
2008 Dodge Caliber SE 2.0 117k
4qt Imeditsu 0w-20, 1/2qt Mobil SS 5w-20 Fram HM
2003 Buick Century 107k
4.5q Havoline 5w-30 HM Fram XG
Re: Splitfire copper plugs after 36k photos [Re: 92saturnsl2] #4449655
07/04/17 05:40 PM
07/04/17 05:40 PM
East Tennessee
Starman2112 Offline
Starman2112  Offline
East Tennessee
Wikipedia says they're still in business, despite this:
https://www.ftc.gov/news-events/press-re...ency-claims-are
2010 Toyota Camry LE 2.5L, Mobil 1 AFE 0W-20, OEM filter
1998 Nissan Frontier XE 2.4L, Castrol GTX HM 5W-30, M1 filter
Re: Splitfire copper plugs after 36k photos [Re: 92saturnsl2] #4449658
07/04/17 05:41 PM
07/04/17 05:41 PM
Idaho
CT8 Offline
CT8  Offline
Idaho
Marketing works as usual.
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: Splitfire copper plugs after 36k photos [Re: 92saturnsl2] #4449668
07/04/17 05:49 PM
07/04/17 05:49 PM
USA
NHGUY Offline
NHGUY  Offline
USA
They dropped the split V design years ago,but still sold that design overseas,not in the USA after getting sued by the FTC.They promoted more power and better gas mileage.Yes,compared to worn out,old plugs.The idea was to open up the flame kernel for more complete combustion...the same language that E-3 plugs do now with "Diamond Fire" technology.They even marketed plug wires with 2 conductors within one jacket....allowing 2 paths for current to flow.More hype. I must say though,that everything I put them in years back....ran better.In a VW,Bosch plugs would foul almost instantly,and in a Mitsubishi they allowed a faster engine start cold.The stock NGKs almost wouldn't start in the winter.Not scientific,but my experience.Sort of sad to see them go.If they hadn't hyped them to the moon (a'la Edsel) they probably could have kept going.
Re: Splitfire copper plugs after 36k photos [Re: 92saturnsl2] #4449672
07/04/17 05:50 PM
07/04/17 05:50 PM
USA
NHGUY Offline
NHGUY  Offline
USA
I had heard that Autolite was making the plugs for them,using Autolite bodies and then welding on the Split-v.
Re: Splitfire copper plugs after 36k photos [Re: 92saturnsl2] #4449682
07/04/17 05:55 PM
07/04/17 05:55 PM
USA
Reddy45 Offline
Reddy45  Offline
USA
Gimmicky, but hey they worked so no loss.
The previous owner of my lawn mower put one of those E3 spark plugs into it. I can't say I have any spark issues and I see no reason to replace it with a less expensive plug since it seems to be working great now.
Re: Splitfire copper plugs after 36k photos [Re: 92saturnsl2] #4449693
07/04/17 06:07 PM
07/04/17 06:07 PM
MN
oil_film_movies Offline
MN
Those plugs were a get-rich scheme for somebody. Is there really anything better than modern iridium plugs?
Re: Splitfire copper plugs after 36k photos [Re: 92saturnsl2] #4449720
07/04/17 06:38 PM
07/04/17 06:38 PM
Colorado
AntsinmyEyes Offline
Colorado
Never used them but i remember when pro circuit Kawasaki was sponsored by them they had some sweet graphics
1987 mazda rx7
2004 mazda rx8
1995 miata
2005 dodge ram
Re: Splitfire copper plugs after 36k photos [Re: 92saturnsl2] #4449732
07/04/17 06:45 PM
07/04/17 06:45 PM
Western S.C. since 1996
CR94 Offline
CR94  Offline
Originally Posted By: 92saturnsl2
Surely you folks will remember the splitfire spark plugs that came out sometime in the 90's-- they made all these claims ...
They were advertised long before the 90s.
I ran regular copper-core resistor plugs over 100K at least twice without problems. Replacing them then didn't make the engine run noticeably better or more efficiently.
2011 Toyota Prius now at 92K
