Bad Motorcraft Plug?
by tmorris1. 03/21/19 10:47 AM
SAE 20 non-detergent oil
by fleetwood62. 03/21/19 10:39 AM
PSF3 in older Kia?
by Jetsfan421. 03/21/19 09:48 AM
USB WiFi adapter recommendations?
by Quattro Pete. 03/21/19 09:44 AM
m1,ep and valvoline.
by avi1777. 03/21/19 09:39 AM
540 RAT
by elpcmaster. 03/21/19 09:18 AM
Caliper recommendation?
by supton. 03/21/19 09:08 AM
Honda st1300 LED light
by Zuraxus. 03/21/19 08:26 AM
2001 CRV no restart when hot
by Kurtatron. 03/21/19 07:27 AM
Amazing human feats - free-diving...
by Shannow. 03/21/19 04:59 AM
How long to warm-up an engine?
by OilUzer. 03/21/19 04:58 AM
Disappearance and appearance
by bbhero. 03/21/19 04:38 AM
Big Changes for WIX 51334 - Pics
by tony1679. 03/21/19 04:26 AM
Supertech Synthetic Data Sheets
by The Critic. 03/21/19 04:25 AM
Forester XT filter recommandation
by jbutch. 03/21/19 04:23 AM
Taking the leap to self-employment.....
Eventually
by clinebarger. 03/21/19 01:39 AM
Redline releases Professional Series
by Marco620. 03/20/19 11:52 PM
M1 HM 10w-30 vs M1 FS 0w-40
by RDY4WAR. 03/20/19 10:04 PM
Need Recommendations For A New SUV
by Dwight_Frye. 03/20/19 08:50 PM
AlanGonzales, Jrealstreeter, DarkFrontier, Zuraxus, Burks21
67574 Registered Users
87 registered members (arowbat, Astro_Guy, addyguy, 928, a2gtinut, 3311, 8 invisible), 1,895 guests, and 63 spiders.
Topics286,183
Posts4,903,727
Members67,574
Most Online2,967
Mar 10th, 2019
Driving all thread into the ground? #4449479
07/04/17 02:47 PM
07/04/17 02:47 PM
New Jersey
JHZR2 Offline OP
Global Moderator
JHZR2  Offline OP
Global Moderator
New Jersey
Say 4'?
Need to have some threads in the ground, and shear is more the concern than pulling out. I have a rotary hammer with sds plus connector, and have seen some ground rod hammer adaptors for that.
Is it doable? What would my concerns be? Id use threaded rod of 1/2 or 5/8" size, and could grind a point into the end of it if that somehow helps. I could also cut the hammered section (leave it a little long) and chase the threads.
The other option might be to drive a ground rod and then use a die to cut threads.
Thoughts/recommendations?
Re: Driving all thread into the ground? [Re: JHZR2] #4449496
07/04/17 03:02 PM
07/04/17 03:02 PM
Champlain/Hudson Valley
Kira Offline
Kira  Offline
All for electric grounding? How deep is code? I've done it a couple of times with a hammer (lucky, I guess) but someone else was in charge.
Re: Driving all thread into the ground? [Re: JHZR2] #4449503
07/04/17 03:15 PM
07/04/17 03:15 PM
New Jersey
JHZR2 Offline OP
Global Moderator
JHZR2  Offline OP
Global Moderator
New Jersey
No. Nothing to do with electrical grounding at all. A ground rod is just an option to get a piece of metal intended for driving in the ground.
Re: Driving all thread into the ground? [Re: JHZR2] #4449578
07/04/17 04:29 PM
07/04/17 04:29 PM
Lemont IL
Fattylocks Offline
Fattylocks  Offline
Lemont IL
How hard is the ground and how deep do you have to drive the rod in?
94 Caprice Wagon Daily driver
05 Focus Wagon 2.0 Duratech Thrifty city car
05 P71 ex Homeland Security emergency Beagle cruiser
Re: Driving all thread into the ground? [Re: JHZR2] #4449586
07/04/17 04:39 PM
07/04/17 04:39 PM
Sav ga
NStuart Offline
NStuart  Offline
Sav ga
Double nut it, beat on it, unscrew....threads should be fine
Detroit14l 1m75k mi bp schaffer9k 30k oil
96 ram 5.9 gas 80k built tranny 5k m1
85 cj7 4.2 performance build. Schaeffer 9000
08 cbr600rr graffiti. T6
08 husky sm610 t6
Re: Driving all thread into the ground? [Re: JHZR2] #4449615
07/04/17 05:11 PM
07/04/17 05:11 PM
Midwest USA
LoneRanger Offline
LoneRanger  Offline
Midwest USA
I thought this was going to be about trolls killing valid discussion threads on the forum . . .
'09 Subaru Forester ...................(QS HM 5W30)
'16 Moto Guzzi Stelvio 1200 .....(ENI i-Ride PG 10W60)
Re: Driving all thread into the ground? [Re: JHZR2] #4449687
07/04/17 06:01 PM
07/04/17 06:01 PM
Buffalo, NY
JTK Offline
JTK  Offline
Buffalo, NY
It's going to corrode and deteriorate over time obviously, but should be fine for a long time provided you can get where you need it.
2017 Ram 1500 4x4, 3.6L. 2016 Nissan Quest SV (Babe magnet IV)
Re: Driving all thread into the ground? [Re: LoneRanger] #4449691
07/04/17 06:06 PM
07/04/17 06:06 PM
Clovis, CA
Merkava_4 Offline
Merkava_4  Offline
Clovis, CA
I thought it was going to be about threads that have lasted way past their useful life.
Re: Driving all thread into the ground? [Re: Fattylocks] #4449848
07/04/17 08:37 PM
07/04/17 08:37 PM
New Jersey
JHZR2 Offline OP
Global Moderator
JHZR2  Offline OP
Global Moderator
New Jersey
We have sandy-organic mix. Drains well.
Im thinking 4-ish feet down. Shouldn't hit water table until we go 10 feet based upon where water sits in the sump hole in my basement.
Re: Driving all thread into the ground? [Re: JHZR2] #4449910
07/04/17 09:54 PM
07/04/17 09:54 PM
Illinois
SHOZ Offline
SHOZ  Offline
Illinois
It will pull out rather easy if it's under a load. I've used 3/8" x 4' before and removed it every fall for a greenhouse. If left to rust up it then holds very well.
You could slip the top foot with some PCV pipe to help with lateral pull.
2008 Hyundai Accent 1.6L 5 sp manual hatchback
2010 Hyundai Genesis Coupe Track 2L Turbo 6sp manual
Re: Driving all thread into the ground? [Re: JHZR2] #4450090
07/05/17 06:47 AM
07/05/17 06:47 AM
New Jersey
JHZR2 Offline OP
Global Moderator
JHZR2  Offline OP
Global Moderator
New Jersey
So you drive it with a hammer? 3/8 is a good deal smaller than the 1/2 I'm considering.
Longevity is less of a concern than feasibility.
Re: Driving all thread into the ground? [Re: JHZR2] #4450104
07/05/17 07:14 AM
07/05/17 07:14 AM
NH
supton Online content
supton  Online Content
NH
Since it's shear you are worried about and not tension I'd think about using a GND rod, and then adding the clamps that are used to attach solid core wire. They have threads for a screw on them, although you could perhaps tap the clamp or building something from those. Use multiple clamps if necessary.
I think you can get 4 foot rods also.
2011 Toyota Camry, base, 2.5L/6MT, 179k, hers
2010 Toyota Tundra DC, 4.6L/6AT, 146k, ours
1999 Toyota Camry LE, 2.2L/4AT, 202k, his
Re: Driving all thread into the ground? [Re: JHZR2] #4450107
07/05/17 07:18 AM
07/05/17 07:18 AM
Illinois
SHOZ Offline
SHOZ  Offline
Illinois
Yes I put a nut on top and pound it in. Usually very easy when the soil is wet. I've used a hammer drill before with dryer soil. And put a point on the end of the all thread.
Re: Driving all thread into the ground? [Re: JHZR2] #4450118
07/05/17 07:35 AM
07/05/17 07:35 AM
MI
doitmyself Offline
doitmyself  Offline
MI
We use T post fence pounders to install 8 ft.electric fence ground rods. For 3/8", maybe put a pvc pipe sleeve over it to reduce side bending and just cut off the pvc one ft. at a time as you proceed.
Re: Driving all thread into the ground? [Re: JHZR2] #4450134
07/05/17 08:02 AM
07/05/17 08:02 AM
Illinois
SHOZ Offline
SHOZ  Offline
Illinois
I just used a post driver like that to put a 8' x 1/2" ground rod in a couple weeks ago. The soil was not really wet and I had to use a #3 hammer to finish it.
