Increased oil capacity = lower pil temps ?
by SavagePatch. 03/22/19 09:15 AM
2007 Corolla - P0441 and P0455 codes
by Bama. 03/22/19 08:44 AM
Oldmoparguy1
by cjcride. 03/22/19 08:23 AM
Check engine light
by rtrdad. 03/22/19 08:21 AM
Super Tech 5W30 Synthetic With GDI Engine ?
by ChrisD46. 03/22/19 07:00 AM
Venol A.M.G brand
by headoff93. 03/22/19 05:51 AM
Anyone use this oil?
by lawnguy. 03/22/19 05:47 AM
Amalie Elixir Full Synthetic ?
by lawnguy. 03/22/19 02:23 AM
All 2's tomorrow or Saturday
by Marco620. 03/22/19 01:28 AM
Mobil 1 0W-16
by The Critic. 03/22/19 01:06 AM
2007 Escape - TCC solenoid?
by Burks21. 03/21/19 11:52 PM
Ac Delco oil on Rockauto
by WiskyBadger. 03/21/19 11:09 PM
Old Laptop - Keeps Freezing - Help!
by reemoe2. 03/21/19 09:52 PM
Cinnamon Cake
by StevieC. 03/21/19 09:43 PM
AMALIE OILS
by kstanf150. 03/21/19 09:41 PM
oem filters
by mobilaltima. 03/21/19 09:34 PM
Magna1 10W30
by mobilaltima. 03/21/19 09:32 PM
Found triple threat
by deven. 03/21/19 09:26 PM
Chrysler Valvetrain week??
by clinebarger. 03/21/19 08:50 PM
Anton93, FrancescoO, russrie, scottjeffrey, Mowata
67582 Registered Users
106 registered members (ARCOgraphite, acme, AandPDan, Aero540T, 11 invisible), 1,766 guests, and 61 spiders.
Topics286,229
Posts4,904,707
Members67,582
Most Online2,967
Mar 10th, 2019
Oil for junkyard big turbo LS #4449172
07/04/17 09:03 AM
07/04/17 09:03 AM
Fairfax, VA
TinyVoices Offline OP
Fairfax, VA
Going to be starting a new project soon. It'll be your typical junkyard 5.3ls truck motor + ls1 intake + turbo cam + Pac 1218 springs + eBay 76mm turbo. Don't know what car it'll be in yet. Maybe an s10. Won't see much track time. Just going to be for hurting feelings on the highway.
What oil would you all use?
2010 Mazda RX8 Sport - 37k miles - ????
2006 Toyota Matrix XR AWD (Wife) - 130k miles - Valvoline Max Life 5w30
Re: Oil for junkyard big turbo LS [Re: TinyVoices] #4449186
07/04/17 09:22 AM
07/04/17 09:22 AM
US-WA
Dyusik Offline
Dyusik  Offline
US-WA
HDEO is always my first pick, Castrol a3b4 second. In winter (a real winter) the other way around.
95 Cherokee 190K DELO 10W30, XG8
07 IS250 106K STP syn HM 10w30, FULL
04 YZF-R1 19K DELO 15w40, XG7317
99 HD XL1200S 21K VR1 20w50, NG1515
14 RX450h 40k Idemitsu 0w20, 57047
Re: Oil for junkyard big turbo LS [Re: TinyVoices] #4449325
07/04/17 11:33 AM
07/04/17 11:33 AM
Jacksonville, FL
FlyNavyP3 Offline
FlyNavyP3  Offline
Jacksonville, FL
If you plan on doing what most people do which is just abuse it till it pops and replace with another junkyard 5.3 I'm not sure the oil matters much. If I was doing the same build I would also upgrade the oil pump to a melling select in either a standard volume high pressure or high volume high pressure. Most who do junkyard turbo swaps also upgrade the rod bolts.
Personally I'd run a 15w40 conventional diesel oil. Which one? Whatever I could get the cheapest.
Luke
Re: Oil for junkyard big turbo LS [Re: TinyVoices] #4449329
07/04/17 11:42 AM
07/04/17 11:42 AM
Oregon
1JZ_E46 Offline
1JZ_E46  Offline
Oregon
If you're trying to keep it on the cheap, run a synthetic CJ-4 HDEO or M1 15W-50. I'd stay away from non synthetic oils to keep the turbo from gumming up.
2007 X5 4.8i: M1 HM 10W-30
2016 Countryman S: Castrol 0W-40
Re: Oil for junkyard big turbo LS [Re: TinyVoices] #4449330
07/04/17 11:42 AM
07/04/17 11:42 AM
San Diego, CA
gryffinwings Offline
San Diego, CA
I'd run Rotella in a 40 weight or chevron delo in a 40 weight what ever. Maybe 10w40 or something.
1987 Honda CRX Si
2015 BMW 320i
2016 Toyota Tundra
Re: Oil for junkyard big turbo LS [Re: TinyVoices] #4449423
07/04/17 01:51 PM
07/04/17 01:51 PM
Balearic Islands , Spain
FordCapriDriver Offline
Rotella T6 5W-40
1975 Ford Capri II Ghia 3000 V6, - Shell Helix HX3 20W-50 w/ 20% Rimula R4X 15W-40 HDEO.
1988 Ford Escort XR3i Cabrio, - Shell Rimula R4X 15W-40, w/ 30% Helix 3 20W-50.
Re: Oil for junkyard big turbo LS [Re: TinyVoices] #4449449
07/04/17 02:18 PM
07/04/17 02:18 PM
NC
Vladiator Offline
Vladiator  Offline
NC
Many here recommend Rotella 5w40 or other HDEOs across the board... So I looked up prices at WalMart... My question is - does Rotella really clean so good that it is worth the 15% price increase over Mobil 1 products? The Delo 5w40 is considered by many as the cheap alternative to Rotella (I do not agree there), but it still comes out more expensive than Mobil 1 products! Here are the current prices at WalMart:
-Rotella 5w40 $5.34/qt (21.36 per gallon)
-Mobil 1 15w50/0w40 $4.58/qt (22.88 per 1.25 gallons)
-Castrol 0w40 $4.59/qt (22.97 per 1.25 gallons)
-Delo 5w40 $4.99/qt (19.97 per gallon)
-Mobil 1 Turbo Diesel 5w40 $6.71/qt (26.83 per gallon)
Here is my take on it - use Mobil 1 15w50 in above freezing temperatures, and use 0w40 below freezing. Best price and an oil that is actually meant for gasoline engines, whatever that means. And many UOAs here show great performance from these oils. Your 5.3 will not complain. Just stay on a synthetic diet to minimize the long term damage to the turbo.
Re: Oil for junkyard big turbo LS [Re: TinyVoices] #4449483
07/04/17 02:51 PM
07/04/17 02:51 PM
South Texas Rancho
TexasVaquero Offline
South Texas Rancho
Any Synthetic
2014 NISSAN VERSA 5spd M/T- M1 EP 5w30 and M1 EP Filter. 5k OCI.
2011 CHEVY IMPALA 3.5ltrs - M1 HM 5w30 and M1 EP Filter. 3k OCI.
Re: Oil for junkyard big turbo LS [Re: TinyVoices] #4449634
07/04/17 05:23 PM
07/04/17 05:23 PM
IL
04SE Offline
04SE  Offline
IL
Mind my asking why you are using the LS1 intake? Packaging/height issues? I thought the recent truck intakes out flowed it?
Life's little problems can be solved with a shovel and silence.
