Phillips 66 Shield Choice $1.99 @ Orscheln
by Pat in Speedway. 03/18/19 12:41 PM
Barely there back seats
by y_p_w. 03/18/19 11:47 AM
should i be afraid of the DCT ?
by WhyMe. 03/18/19 11:28 AM
Friction modifiers
by Truckedup. 03/18/19 10:57 AM
Sometimes, choices are made for you!
by addyguy. 03/18/19 10:30 AM
I Hope This Amuses You Guys Like It Did Me
by NYEngineer. 03/18/19 10:27 AM
New Exmark Lazer Z / Oil ?
by johnD2. 03/18/19 10:13 AM
First welder recommendation
by Astro14. 03/18/19 09:55 AM
Amsoil Burning
by ridgerunner. 03/18/19 09:38 AM
2007 Sonata Pinging + DTCs
by F24Sonata. 03/18/19 09:31 AM
Nissan Maxima 2009 synthetic oil choices
by mahanddeem. 03/18/19 09:23 AM
Best coated rotors
by JMHC. 03/18/19 09:11 AM
Brake Bleeder Question
by maverickfhs. 03/18/19 08:57 AM
Ring alarm system, any good?
by Redright9. 03/18/19 08:18 AM
4 oil changes Saturday.
by ls1mike. 03/18/19 08:08 AM
Careers.....Boomers vs Millennias
by ZZman. 03/18/19 08:05 AM
Need Expert TIG Welder, Toronto Area
by George7941. 03/18/19 01:44 AM
Cadillac CT5 Revealed
by E365. 03/18/19 01:36 AM
toplscuda, swrve, TomRx, Ozdave, Rod1701
67547 Registered Users
114 registered members (97prizm, 928, 2009Edge, 97f150, 2015_PSD, 11 invisible), 2,300 guests, and 60 spiders.
Topics286,014
Posts4,900,744
Members67,547
Most Online2,967
Mar 10th, 2019
Raybestos rotors? #4448921
07/03/17 11:25 PM
07/03/17 11:25 PM
West Michigan
buck91 Offline OP
buck91  Offline OP
West Michigan
Does anybody know much about raybestos brake rotors? Working on our Explorer and I can source either 680982 (advanced technology) or 680982P (police/fleet). The catch is, its significantly cheaper ordering one of each than a pair of either. Think they would be good running one of each on the same axle? Think either one would offer a significant advantage over the other? Both are listed as made in "CN" which I'm assuming means China.
2011 F150 4x4 5.0L
1996 Mustang GT 5spd/ragtop
Re: Raybestos rotors? [Re: buck91] #4448932
07/03/17 11:38 PM
07/03/17 11:38 PM
Jacksonville, FL
FlyNavyP3 Offline
FlyNavyP3  Offline
Jacksonville, FL
I just installed a pair of advanced technology rotors on my Lexus after having [censored] luck with two sets of Dura rotors in a row, they would develop a terrible pulse after about 8,000-10,000 miles occurred about the same mileage on both sets. So off they came and on went a set of Raybestos AT rotors with Raybestos EHT pads. So far so good but they've only been on for just shy of 2,600 miles.
I wouldn't have any worries buying a set of each, so far I'm really liking the GG friction code Raybestos EHT pads, more bite and less dust than the previous pads and LESS dust than the much loved Akebono Pro-ACT pads that are installed on the rear axle of the same car.
Luke
Re: Raybestos rotors? [Re: FlyNavyP3] #4448942
07/03/17 11:48 PM
07/03/17 11:48 PM
Jupiter, FL
thescreensavers Offline
Jupiter, FL
That would be a pad issue, rotors have little to do with brake pulsation.
http://www.stoptech.com/technical-support/technical-white-papers/-warped-brake-disc-and-other-myths
I've personally purchase the cheapest rotors I can get from a reputable brand(usually centric cteks) and then buy a decent pad never had an issue even when used on the track.
Don't forget to check Amazon warehouse deals.
And to answer your question OP buy which ever is chepeast.
2017 Camaro SS 1LE (Motul 8100 X-clean 5W40)
1997 Jeep XJ 4x4 (15W40 HDEO Maxlife)
Re: Raybestos rotors? [Re: buck91] #4448949
07/03/17 11:59 PM
07/03/17 11:59 PM
West Michigan
buck91 Offline OP
buck91  Offline OP
West Michigan
Thoughts on mixing one of each on the same axle, though?
2011 F150 4x4 5.0L
Re: Raybestos rotors? [Re: buck91] #4448959
07/04/17 12:14 AM
07/04/17 12:14 AM
Kansas
ejes Offline
ejes  Offline
Kansas
Pedal pulsation comes from thickness variation, which in turn is caused by excessive lateral runout. Almost all rotors come from China nowadays. I would not mix the different types however. Generally, police/fleet/HD rotors have less thickness variation and reduce pulsation so they last longer. I would go with pairs of whatever you decide. I have found if the police/fleet/HD rotors are not much more expensive it is worth it. More important for actual stopping performanc is a high quality pad though. I'd go with a pair of the 680982P rotors.
Re: Raybestos rotors? [Re: thescreensavers] #4448960
07/04/17 12:14 AM
07/04/17 12:14 AM
Jacksonville, FL
FlyNavyP3 Offline
FlyNavyP3  Offline
Jacksonville, FL
It was not a pad issue, the rotors had 0.001-0.002 runout when installed and 0.003-0.008 runout when removed, re bedding the pads didn't fix the issue. The original rotors went 145,000 miles without any issues, the same exact pads were used from the last set on the original rotors to the replacement dura rotors (a new set to clarify, Akebono ACT, I only switched to Raybestos to match the new rotors since the Akebono pads already had 20,000 miles on them). Not all brake pulsating issues are pads, chuck a used rotor up in a lathe and see for yourself, I've personally cut several hundred.
Luke
Re: Raybestos rotors? [Re: buck91] #4448992
07/04/17 02:05 AM
07/04/17 02:05 AM
California
boom10ful Offline
boom10ful  Offline
California
Just whatever you do don't buy the cheapest rotors on Rockauto! I did that and now I have brake pulsations and noise when braking. Won't make that mistake again. I would trust the Raybestos.
Re: Raybestos rotors? [Re: FlyNavyP3] #4448994
07/04/17 02:27 AM
07/04/17 02:27 AM
Regina, Saskatchewan, Canada
Garak Offline
Garak  Offline
OT, but I got the same deal, and am happy with them so far. To the OP, I wouldn't want to mix rotors on the same axle if I could at all avoid it. Of course, I'm sure that happens often enough in fleet environments, particularly if one rotor is shot and the other is "serviceable enough."
Plain, simple Garak.
Re: Raybestos rotors? [Re: FlyNavyP3] #4449067
07/04/17 07:05 AM
07/04/17 07:05 AM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
I see this article quoted on the board like it was gospel, it was written by one person and that is his opinion. I totally disagree with his conclusions, IMO the chances are he probably never operated a brake lathe in his life and is talking about racing brakes that use a lot of pad material in a very short time and do deposit pad material heavily on the rotors. Most posters have never seen a brake lathe never mind operated one so they don't know and understandably just quote the article.
Over the last 40+ years I too have cut literally hundreds maybe even thousands of drums and rotors, there was a time not too long ago that every car that got a brake job had its drums/rotors cut and calipers and cylinders rebuilt.
When cutting the rotors it wasn't old pad material being cut that I can tell you, it was metal. rotors do warp that's a 100% fact. As in your case they were mounted properly on a clean surface and had low install runout numbers.
I use to hate the singing when someone forgot to belt the rotor or drum in the lathe, it would drive drive people crazy.
Re: Raybestos rotors? [Re: buck91] #4449115
07/04/17 08:23 AM
07/04/17 08:23 AM
USA
slacktide_bitog Offline
USA
Get rotors that are coated smile
Re: Raybestos rotors? [Re: buck91] #4449128
07/04/17 08:32 AM
07/04/17 08:32 AM
New England
Peter_480 Offline
Peter_480  Offline
New England
Can't go wrong with the daily driver grade Centric's from RA.
'10 Ford E250 4.6L
'11 Ford Fusion 2.5L
Re: Raybestos rotors? [Re: buck91] #4449132
07/04/17 08:34 AM
07/04/17 08:34 AM
Central Maryland
HangFire Offline
HangFire  Offline
Central Maryland
Buck91,
I put a set of Raybestos Professional Rotors on my Dakota about 3 years ago, and they are doing well, no problems. Of course I checked for parallelism and on-vehicle runout as part of the install. The reason I tried them is they come with a guarantee on flatness and runout (which would be off-vehicle runout). I haven't tried their higher end line.
Thickness variation is but one cause of pedal vibration. It can be avoided by 1.) buying rotors with a flatness guarantee (like the Raybestos has) and 2.) Confirming with instruments. All you need is a common micrometer, measure the rotor thickness at 8 more-or-less equidistant points around friction surface. The resulting measurements should vary not at all, factory specs say less than .0015", I've found even the cheaper Chinese rotors beat that. But I always check anyway. (This is a different check than run-out, which is done on vehicle with a dial indicator.
Sorry, while the author is no longer able to defend himself, he was THE EXPERT on braking.
I too have rotors that warped, one set after an extreme over-tightening by Goodyear Tire & Auto center. (I had to replace a bunch of studs it was so bad). So yes it happens, but I hardly mention it any more because I got shouted down by people quoting the article.
I've learned a lot from Trav and respect his opinions, but you're dead wrong about pad buildup. How else do you explain a rotor with in-spec runout and parallelism/flatness, and severe brake shudder problems?
http://www.sciencedirect.com/science/article/pii/S0043164815004792
Various musings: http://hangfire.net
Re: Raybestos rotors? [Re: HangFire] #4449147
07/04/17 08:46 AM
07/04/17 08:46 AM
Trav Offline
Trav  Offline
You misunderstand me, I know there can be pad buildup and of course it can cause pulsation but that article it seems totally dismisses rotor warping for reasons other than improper installation.
Re: Raybestos rotors? [Re: Trav] #4449357
07/04/17 12:10 PM
07/04/17 12:10 PM
Central Maryland
HangFire Offline
HangFire  Offline
Central Maryland
Sorry, I did misunderstand you. I think we're on the same page...
Re: Raybestos rotors? [Re: buck91] #4449369
07/04/17 12:31 PM
07/04/17 12:31 PM
Ontario, Canada
mightymousetech Offline
Ontario, Canada
As another pro tech, yes, warped rotors is very, very real. Usually caused by improper torquing of the wheel nuts.
Mighty Mouse Tech
BMW Tech, Former Acura Tech
2010 Civic Si Castrol 0W40, Redline MTL
2013 BMW 135i M Sport Edition Castrol 0W40, Redline MTL
