I'm sure the dealer would reuse the constant tension clamps on my lower rad hose (replacing hose on 2005 5.7 Hemi).
Should I reuse (assuming they loose tension being removed?)or is there a reason not to? I like the factory original look of them or at least of new oem constant tension clamps and like the idea of not fooling around with cheapo screwdrive clamps or $20 each Sweedish made super engineered clamps. My ocd brain wonders if new oem ones would be too tight for the aged (2005) black plastic rad outlet on the the rad.
P.S. ... anyone have a particular maker of a constant tension spring hose clamp PLIERS ?
