Counterfeit MANN filter???
by IllinoisSparky. 09/23/18 06:54 PM
The smell of an oil: VME adds?
by fdcg27. 09/23/18 06:48 PM
Classic road brake pads
by buck91. 09/23/18 06:18 PM
Air up your vehicle's tires
by Papa Bear. 09/23/18 06:07 PM
A cool litttle Fall foliage site
by Papa Bear. 09/23/18 06:02 PM
Suggestion: "Likes"
by SnowDrifter. 09/23/18 05:36 PM
Condensation in headlights?
by irv. 09/23/18 05:06 PM
Nissan VQ V-6 Engines
by Al. 09/23/18 04:57 PM
List of dexos licensed oils?
by k1xv. 09/23/18 04:24 PM
High flow oil pump? Thinner oil?
by SnowDrifter. 09/23/18 04:06 PM
Is Tiger back?
by gman2304. 09/23/18 03:51 PM
Castrol Edge Pro OE LLIV FE 0W20 for VW508
by BrandonT. 09/23/18 03:33 PM
Value of 90's stereo equipment
by wrcsixeight. 09/23/18 03:28 PM
Wisdom of BITOG'ers wanted- 19 Avalon Hybrid oil
by scion_xb. 09/23/18 02:36 PM
w116 300sd Mercedes Diesel HPR fuel
by Gito. 09/23/18 02:14 PM
Power Stop Wheel Bearing/Hubs?
by oilpsi2high. 09/23/18 01:37 PM
Dump the 30k ATF in the 17 Kia?
by 3Aone. 09/23/18 01:31 PM
Miata Aisin 6 speed question
by 10ecfarmer. 09/23/18 12:36 PM
Shortest time you owned a car?
by Corollaman. 09/23/18 12:21 PM
The_Money_Light, DALTRON0659, skippermatt, HondaTech250, SandCruzer
66047 Registered Users
105 registered members (1.8Tango, 69GTX, 3Aone, 10ecfarmer, 16 invisible), 1,706 guests, and 33 spiders.
Topics290,906
Posts4,852,275
Members66,047
Most Online3,590
Jan 24th, 2017
Fram Ultra 7317 in a Triumph triple engine #4448276
07/03/17 11:37 AM
07/03/17 11:37 AM
USA
Reddy45 Offline OP
Reddy45  Offline OP
USA
Per some recommendations here, I am now running a XG7317 on my 2013 Triumph Tiger 800. This engine is a larger version of the Triumph triple 675 used on the street triple.
Are there any estimates on how much mileage I can put on this filter before changing it?
The OEM filter is a rebranded Wix 51358 and the factory recommendation is 6000 mile OCI with synthetic oil.
I will be using either Rotella T4 15W40 or T6 5W40. Riding is mostly highway.
Re: Fram Ultra 7317 in a Triumph triple engine [Re: Reddy45] #4448296
07/03/17 12:00 PM
07/03/17 12:00 PM
New York
jeff78 Offline
jeff78  Offline
New York
What's the manual's recommendation for the oil filter change interval? Every oil change, or every other?
FWIW I run the 6607 (smaller version of the 7317) for 3 oil changes which works out to be about 10K-12K miles. The manual for my Yamaha recommends an oil change every 4K miles with a filter change every 8K.
I bet the 7317 can easily do 12K+ miles on a motorcycle. For cars Fram claims the Ultra has enough holding capacity for 20K miles but bikes have clutches and gears so I'd knock that life expectancy down a bit but that's just me guessing.
Re: Fram Ultra 7317 in a Triumph triple engine [Re: Reddy45] #4448303
07/03/17 12:14 PM
07/03/17 12:14 PM
Gulf Coast, MS
3800Series Offline
3800Series  Offline
Gulf Coast, MS
I believe the Ultra is rate for 15k miles but do to how synthetic media is made it's filtration increases with usage.
Re: Fram Ultra 7317 in a Triumph triple engine [Re: Reddy45] #4448360
07/03/17 01:33 PM
07/03/17 01:33 PM
MD
AirgunSavant Offline
MD
I ran one over 24K with three OCI's in a 2L Mitsubishi
Pictures are on here- same model.
After I set it aside and it dried after several months it looked fantastic. I still have that filter here.
Need to update the pictures.
Re: Fram Ultra 7317 in a Triumph triple engine [Re: jeff78] #4448816
07/03/17 09:10 PM
07/03/17 09:10 PM
USA
Reddy45 Offline OP
Reddy45  Offline OP
USA
Filter change seems to be indicated as 6k interval along with oil.
I think what I'll do on this bike is stick with the XG7317 and change the oil whenever I check/adj the valves -- every 12k miles per the factory manual. Doesn't save a LOT of money but still saves around $10 every 12k miles lol.
Re: Fram Ultra 7317 in a Triumph triple engine [Re: Reddy45] #4452740
07/07/17 08:36 PM
07/07/17 08:36 PM
New York
jeff78 Offline
jeff78  Offline
New York
Yep, the Ultra will be more than up to the task. If I were doing 6K OCI's, I wouldn't lose any sleep over a filter change every other oil change.
