How often should I replace breather filter.
Waco, Tx.
In my Focus, 288k Zetec motor. I last replaced the breather filter at about 150k miles. I used a Motorcraft part. Should I replace it again or wait? The last one was plugged shut.
If the last one was clogged at 150,000 mile why are you asking if you should replace the filter??
Originally Posted By: Syntheticuser
In my Focus, 288k Zetec motor. I last replaced the breather filter at about 150k miles. Should I replace it again? The last one was plugged shut.
Dude....... really?
You do mean the Air Cleaner breather right? I blow mine out and wipe down the inner housing every time I do the oil using the air compressor. It's amazing the crud and dust that come outa there. Then I toss it at around 100 k unless it's starting to look funky and deteriorate .
