Chevy Commercial Parody
by 02SE. 12/17/18 02:37 AM
Fluctuating Tachometer Fixed!
by jerseyguy123. 12/17/18 02:10 AM
2015 MB GLA250: OEM oil vs Mobil1 Formula M
by SlavaB. 12/17/18 12:39 AM
Shotgun Ammo
by user52165. 12/16/18 10:24 PM
Bought a Model 3 for wifey
by JeffKeryk. 12/16/18 09:01 PM
Maybe I'm crazy.
by TRDPRO85. 12/16/18 07:50 PM
Pacer EON E-11 Synthetic Motor Fluid
by Brandon9797. 12/16/18 07:46 PM
Reuse transmission fluid??
by FFeng7. 12/16/18 07:35 PM
Amsoil SS color change
by BigShug681. 12/16/18 07:21 PM
Why don't owner's manuals specify the oil type
by OilUzer. 12/16/18 07:13 PM
belt tensioner problems
by mobilaltima. 12/16/18 06:57 PM
How bout them Patriots
by 53' Stude. 12/16/18 06:36 PM
Hand held Ham radio suggestions
by littleant. 12/16/18 05:20 PM
Ford 2.3 EB's using 87 vs 91/93 octane
by Whimsey. 12/16/18 04:48 PM
Oil analysis pump tube?
by maximum6. 12/16/18 03:56 PM
Mahle charcoal lined filter..the best!
by TiGeo. 12/16/18 03:45 PM
stantaur, Brandon9797, Landngroove, DanielH, Cpcz9382
66700 Registered Users
49 registered members (87sammy, bfleeman, alarmguy, 69Torino, ArrestMeRedZ, Brandon9797, 5 invisible), 923 guests, and 47 spiders.
Topics295,172
Posts4,929,136
Members66,700
Most Online2,553
Oct 27th, 2018
Brake fluid effects on plastic, seeking advice #4448179
07/03/17 08:57 AM
07/03/17 08:57 AM
Dallas, TX
rurockn Offline OP
rurockn  Offline OP
Dallas, TX
I work for an injection molding company and one of our customers tests requires a small part to be submerged in DOT3 brake fluid for X amount of time, rinsed off, and then destructively tested. We have not changed out process or raw material. Our raw material has been tested multiple times in recent months and is pure and meets all requirements.... yet suddenly we are failing testing after the DOT3 test. Many people and labs have been involved and cannot seem to nail this down. I have used this website many times in the past for my vehicles and thought, well, maybe someone out there can help out with this issue.
The idea I keep coming back around to is maybe some DOT3 additives have changed over the past few years? For many years we used the same DOT3 brake fluid, we had dozens of small bottles that would last about a month each. Suddenly when we are buying new DOT3 fluid, we are failing testing. Any thoughts or ideas if the fluid today could be more aggressive than a few years ago?
Note: the plastic is polycarbonate polyester blend.
Re: Brake fluid effects on plastic, seeking advice [Re: rurockn] #4448200
07/03/17 09:24 AM
07/03/17 09:24 AM
Minnesota
bmod305 Offline
bmod305  Offline
Minnesota
Are you using any slip agents or colorant in the mix? Any changes in the suppliers? Are you using a moisture tester before molding? Cleaning of barrel and screw any different this round? i.e different purging compounds. I'm the Production Manager for a molder in MN. We mold some parts that are used as clutch master fluid reservoirs using dot 3, 4, and 5 brake fluid with no issues.
Re: Brake fluid effects on plastic, seeking advice [Re: rurockn] #4448362
07/03/17 12:35 PM
07/03/17 12:35 PM
Pennsylvania
Boomer Offline
Boomer  Offline
Pennsylvania
Just a couple of thoughts from a retired organic chemist.
1. Any chance that the composition of the polyester or polycarbonate has changed or that polymerization catalyst might ne present that was not present in the past? Your description almost sounds like the polymer is losing molecular weight (maybe by transesterification with the polyethylene gylcol).
2. Take some of the DOT 3 fluid and add a few drops to water and check the pH. Do you have any of the old Dot 3 fluid to use as a comparison? Is the new stuff more acidic or basic than the old stuff?
3. Is there any indication that the part is undergoing some type of polymeric crystallization during immersion? Does the polymer test strip whiten during immersion? If so, did it used to do this?
4. While this is simple, have you checked all of the temperature and strain/stress measurement systems? Are you really pushing/pulling/bending with the same force that you used to apply? Have you calibrated the test machine(s) with a known material?
5. Extract the DOT 3 material with pure hexane and take a sample of the hexane after the extraction and run a gas chromatographic analysis on it. Again, if you have an old sample for comparison, this would be even better.
2013 VW Passat TDI SE, 61,200 miles Castrol Professional VW507 5W-30
2017 VW Golf All Track 18,370 miles Castrol Professional VW505 5W-40
Re: Brake fluid effects on plastic, seeking advice [Re: rurockn] #4449029
07/04/17 04:32 AM
07/04/17 04:32 AM
Pennsylvania
Boomer Offline
Boomer  Offline
Pennsylvania
Bmod 305 talks about moisture and this is a good point. Brake fluid is VERY hygroscopic. Is the new material tested for moisture? Were the cans left open? Really worth checking.
