Review: CVJ Remanufactured CV Axles
by The Critic
Today at 03:40 AM
Towing without 85w140?
by OilFilters
Today at 03:07 AM
2015 VW GTI autobahn oil questions
by Skyalbo
Yesterday at 11:28 PM
Corrosion in the garage - salt or humidity?
by Kurtatron
Yesterday at 11:13 PM
Darn dogs
by AZjeff
Yesterday at 10:21 PM
New GC?
by Bullwinkle007
Yesterday at 10:04 PM
The guy with the plexiglass head on you tube
by andyd
Yesterday at 09:21 PM
'07 Pacifica Timing Belt Replacement success
by 92saturnsl2
Yesterday at 09:10 PM
SAE 90 v 85/140
by Knuckle078
Mobil 1 5W30-HM 5,011 mi, 1999 Ford Escort
by WA1DH
Yesterday at 08:45 PM
what happened to merk
by ernied
Yesterday at 08:34 PM
Schaeffer's oil reviews on Amazon
by zfasts03
Yesterday at 07:41 PM
Decent MP3 player
by Ed_T
Yesterday at 07:08 PM
Letgo
by Donald
Yesterday at 06:52 PM
Tire buying advice
by supton
Yesterday at 06:23 PM
Two versions of M1 5w30 ESP now?
by Patman
Yesterday at 06:21 PM
No older cars in New York State?
by Oldtom
Yesterday at 06:19 PM
2009 Taurus strut mount noise
by terry274
Yesterday at 04:38 PM
A3/B3 vs A3/B4, big difference or irrelevant?
by FordCapriDriver
Yesterday at 03:36 PM
2003 Honda power steering problem
by hogpops
Yesterday at 03:29 PM
lozpxs, danthemanx07, FunktasticLucky, Knuckle078, penncove
65317 Registered Users
35 registered (2015_PSD, Bailes1992, bmod305, billt460, Astro_Guy, bbhero, 1 invisible), 808 Guests and 37 Spiders online.
65317 Members
67 Forums
285954 Topics
#4448109 - 07/03/17 08:45 AM Inline AT filter mount location?
HawkeyeScott Offline
Loc: El Oeste
Sorry, searched this on the site and with Google and found nothing.
Having some second thoughts on where I installed an inline AT filter yesterday on my 2008 Suburban (after I finished a cooler install). I was closing browsers this morning and noticed on the Magnefine website that they tell you to mount their filters in a section of straight cooler line. I missed that yesterday and didn't do that. I put mine between the new cooler output and the factory return line. Splicing it in here between two pieces of rubber hose was simple, and it's a location that won't require me to take off the front clip to change the filter. But there is an small, gradual curve on both sides of the filter, and the fluid has t flow "uphill" into the filter.
I don't think flow could possibly be restricted very much at all, but it's not mounted exactly as Magnifine suggests.
Anyone else had luck mounting these long term in a less than perfect location? The alternative is cutting into metal line or just scrapping the filter idea altogether. FWIW, I just did the new pan filter in March, so this isn't essential, just added filtration.
#4448119 - 07/03/17 08:52 AM Re: Inline AT filter mount location? [Re: HawkeyeScott]
Linctex Offline
Loc: Waco, TX
Perfect. You did right.
Don't lose any more sleep over this, OK?
#4448122 - 07/03/17 08:54 AM Re: Inline AT filter mount location? [Re: HawkeyeScott]
Linctex Offline
Loc: Waco, TX
But there is an small, gradual curve on both sides of the filter, and the fluid has to flow "uphill" into the filter.
That won't matter one iota. Velocity is pretty high in this circuit.
#4448155 - 07/03/17 09:32 AM Re: Inline AT filter mount location? [Re: HawkeyeScott]
Donald Offline
Loc: Upstate NY
They say straight line as easiest to cut into. It also does not matter if it's in supply or return as long as the reason for the filter was not a destroyed transmission. (Magnefine has stated this.). In that case the return.
2015 Ford F250 w/Powerstroke
#4449240 - 07/04/17 10:15 AM Re: Inline AT filter mount location? [Re: HawkeyeScott]
Loc: El Oeste
Thanks a lot. Peace of mind is good.
#4449801 - 07/04/17 07:55 PM Re: Inline AT filter mount location? [Re: Donald]
WyrTwister Offline
Loc: Texas
Please , put it in the supply line or the return line ?
Thanks , :-)
Wyr
God bless
#4450279 - 07/05/17 10:30 AM Re: Inline AT filter mount location? [Re: WyrTwister]
Linctex Offline
Loc: Waco, TX
Originally Posted By: WyrTwister
Please , put it in the supply line or the return line? Thanks , :-)
Tt doesn't matter. Really.
I put it in the return only because I felt the filter would last longer if it wasn't so hot.
#4450414 - 07/05/17 01:03 PM Re: Inline AT filter mount location? [Re: HawkeyeScott]
WyrTwister Offline
Loc: Texas
That is good enough for me . :-)
Another question . If you add an external ATF cooler in front of the radiator , is it best to plumb it in on the supply line or the return line ?
Thanks . :-)
Wyr
God bless
#4451159 - 07/06/17 10:35 AM Re: Inline AT filter mount location? [Re: HawkeyeScott]
b_rubenstein Offline
Loc: Melbourne, FL
FWIW, my Honda CR-V comes with an ATF filter, and the filter is located between the output of the radiator cooler and the input of the transmission. (There is no scheduled replacement schedule for it. It only gets changed if a transmission fails.) I happened to add a B&M transmission cooler last weekend. B&M explicitly states that the cooler should be plumbed into the return side between the integrated ATF radiator cooler and the input to the transmission. There are also recommendations for its orientation: https://static.summitracing.com/global/.../instructions/BMM-bm_cooler_techdoc.pdf
#4451452 - 07/06/17 03:33 PM Re: Inline AT filter mount location? [Re: HawkeyeScott]
WyrTwister Offline
Loc: Texas
Thanks , :-)
Wyr
God bless
