Why hang your bicycle from the ceiling?
by mjoekingz28
06/22/18 03:47 AM
Oil For High Sustained RPM on BMW S52
by ZEK
06/21/18 10:41 PM
Chevy brought the blazer back
by WiskyBadger
06/21/18 10:07 PM
LC20 and uses in modern motor oil
by synman
06/21/18 10:01 PM
Full Synthetic CJ-4 or > 5W-30 or 10W-30
by LeTempt
06/21/18 09:57 PM
2018 RAM 1500 EcoDiesel
by OVERKILL
06/21/18 08:37 PM
Fram SureGrip coating
by mobilaltima
06/21/18 08:24 PM
Manual transmissioned electric car
by mjoekingz28
06/21/18 06:45 PM
1991 Toyota Previa New JDM engine Redline
by Kurtatron
06/21/18 06:26 PM
8 yr old channeling John Bonham
by Toy4x4
06/21/18 06:02 PM
Traveller nlgi 2
by Spitter
06/21/18 05:33 PM
Upgrading the Kohler 7000 series air cleaner
by Patrick0525
06/21/18 05:08 PM
Any nano reefers here?
by RichardS
06/21/18 05:04 PM
ARC remanufactured Power Steering Pump
by Pajero
06/21/18 04:58 PM
John Deere "Easy Change" System gimmick
by SnowmanCO
06/21/18 04:55 PM
Oz Planstic Bag Bans - not so green.
by Shannow
06/21/18 04:31 PM
help me choose...
by chaindrive
06/21/18 04:07 PM
France F1 Grand Prix
by DeepFriar
06/21/18 03:16 PM
Valvoline High Mileage with maxlife tech semi-syn
by bradtech
06/21/18 03:16 PM
Best additive in oil to clean sludge?
by ffgb
06/21/18 02:19 PM
ZEK, Dudewayne, kmdz, harborbirds, frascati
65292 Registered Users
19 registered (Ducked, dishdude, 14ecocruze, Billbert, Black_Thunder, 4 invisible), 372 Guests and 37 Spiders online.
65292 Members
67 Forums
285751 Topics
Page 1 of 2 1 2 >
#4448097 - 07/03/17 08:30 AM Do bolts get weaker if loosened and tighten often?
VeeDubb Offline
Loc: Indiana
So I had a bolt on my bike snap even though I was under-torquing it by about 0.7nm (max is 5.2nm and torque wrench was at 4.5nm). This was one of two stem pinch bolts. I usually tighten gradually since I try to balance the torque across the two opposing bolts. Usually, I have no problems getting them to 5.2nm. But today, one of the bolts snapped at 4.5nm. I often loosen and tighten these bolts to adjust the headset after long mountain bike rides. I'm just wondering if the frequent loosening and tightening might have weakened the bolts to the point that they snapped even at less than max torque.
Thanks
#4448112 - 07/03/17 08:47 AM Re: Do bolts get weaker if loosened and tighten often? [Re: VeeDubb]
Linctex Offline
Loc: Waco, TX
This is a metallurgical issue, and I'm going to venture a guess that the bolt was made from bad steel from it's origin.
Fatigue cycle is ZERO on many steels (you can go up to a certain % of its yield strength indefinitely and it will NEVER fatigue)
I don't think it was your fault - - replace with better quality hardware.
#4448114 - 07/03/17 08:49 AM Re: Do bolts get weaker if loosened and tighten often? [Re: VeeDubb]
Linctex Offline
Loc: Waco, TX
I suppose there is the rare (VERY rare) chance this was specifically a "torque to yield" style of bolt, then if that is the case it's definitely your fault. But I kind of doubt it.
#4448137 - 07/03/17 09:07 AM Re: Do bolts get weaker if loosened and tighten often? [Re: VeeDubb]
Johnny2Bad Offline
Loc: Saskatchewan, Canada
Yes. Torque applied by a fastener is based on stretching of the metal; for critical applications one does not measure bolt torque, but instead bolt stretch.
The materials used in the fastener play a role here ... high strength bolts don't like to re-stretch. Repeatedly re-usimg a fastener will result in bolt failure.
'57 FL Straight 50 wt
'90 Miata 1.8L w/Rotrex Supercharger [Mobil1 0W-40]
'96 Ram 1500 [3.7L Mobil1 0W-20 / 1L 15W-50]
'01 PT Cruiser [Mobil1 0W-40]
#4448143 - 07/03/17 09:16 AM Re: Do bolts get weaker if loosened and tighten often? [Re: VeeDubb]
VeeDubb Offline
Loc: Indiana
Good info. So it sounds like I should just go ahead and replace the bolts every few months if I am going to adjust the headset often.
#4448152 - 07/03/17 09:29 AM Re: Do bolts get weaker if loosened and tighten often? [Re: VeeDubb]
KrisZ Offline
Loc: Toronto, Canada
I believe you should look at calibrating your torque wrench first. There is a high possibility that you've been over torquing these bolts without knowing it. Or maybe there is some sort of lubricant or other contamination on the threads that alters the torque reading.
As mentioned before, steel bolts don't fatigue, unless they are torque to yield. Torque to yield takes the material form its elastic range (that's where it always comes back to the original length), to the plastic range (that's where the material stretches beyond its ability to spring back).
Once the bolt goes into the plastic range, the structural changes are irreversible and it is only a matter of time when the bolt fails.
Edited by KrisZ (07/03/17 09:30 AM)
2015 Dodge Grand Caravan-21k miles.
2006 Mazda 3-155k miles
#4448162 - 07/03/17 09:39 AM Re: Do bolts get weaker if loosened and tighten often? [Re: KrisZ]
VeeDubb Offline
Loc: Indiana
Thanks KrisZ. As for the torque wrench, it's fairly new. I've used it a few times on the handlebar stem bolts and a few other bolts using the correct torque settings. The wrench clicked without tightening the bolts further. That is, most of the other fasteners didn't need additional tightening with this wrench. Do you think this is good enough info to trust the wrench?
#4448171 - 07/03/17 09:46 AM Re: Do bolts get weaker if loosened and tighten often? [Re: VeeDubb]
VeeDubb Offline
Loc: Indiana
One more question for you guys. If the bolt fails, is that likely to compromise the threads as well? I'm worried that I may have to replace the stem.
#4448182 - 07/03/17 10:01 AM Re: Do bolts get weaker if loosened and tighten often? [Re: VeeDubb]
KrisZ Offline
Clicker type wrenches will not tell you if a fastener is over torqued. They will click at their setting and that's about it. If there is a little bit of rotation before it clicks, then the fastener is at the set torque, but if the wrench clicks right away, then the fastener could either be at the correct setting or higher.
#4448183 - 07/03/17 10:03 AM Re: Do bolts get weaker if loosened and tighten often? [Re: VeeDubb]
andyd Offline
Loc: Marshfield , MA
If the new bolt tightens smoothly and solidly into place, then the threads are OK. My brother is a biker and does all his own work. I'll ask him, but I don't think he owns a torque wrench. His road bike is worth more than most of my cars.
Thick oil is better grin2
#4448258 - 07/03/17 11:20 AM Re: Do bolts get weaker if loosened and tighten often? [Re: VeeDubb]
Coprolite Offline
Loc: Houston, TX
I wouldn't worry about proactive replacement. If I were in your shoes, I would simply have a spare on hand in case it breaks. This assumes that you use it often and can't wait for replacements to be available.
#4448317 - 07/03/17 12:27 PM Re: Do bolts get weaker if loosened and tighten often? [Re: VeeDubb]
VeeDubb Offline
Loc: Indiana
How would you know if the bolt is a "Torque to yield?" The best description I got on my stem bolts is: ``Uses M5 countersunk, corrosion-resistant steel bolts with 5.2Nm torque spec''
#4448361 - 07/03/17 01:34 PM Re: Do bolts get weaker if loosened and tighten often? [Re: VeeDubb]
bdcardinal Offline
Loc: Santa Barbara, CA
A torque to yield bolt would have a torque sequence that has you turn a specific number of degrees in addition to a Nm or Ft-lb setting.
1995 Ford Mustang GT
Ford/Mazda Parts Counter
NRA Benefactor Member
#4448373 - 07/03/17 01:49 PM Re: Do bolts get weaker if loosened and tighten often? [Re: Johnny2Bad]
L_Sludger Offline
Loc: Ohio
Well the cyclic fatigue of retightening a bolt should be absolutely minimal if the torque applied is a small enough proportion of the bolt's elastic region.
If you're stretching a bolt to the plastic region every time you tighten it down then of course it'll fail quickly after retorquing. But that's only going to be on critical engine components like head bolts.
I have a specific counter point to your last statement.
Many German cars use screw fasteners to attach wheels to their hubs. If these bolts were prone to fail after multiple uses then they'd need to be replaced often. Instead they are of a high enough grade that torquing it repeatedly to remove and reattach wheels does not put them on the path to failure.
too many cars and oil combinations to list in 150 characters or less
#4448376 - 07/03/17 01:52 PM Re: Do bolts get weaker if loosened and tighten often? [Re: VeeDubb]
Johnny2Bad Offline
It's highly unlikely that a header bolt would be a "torque to yield" type.
What I do is install a nut on an over-length bolt, fully seat the bolt, then tighten the nut to secure the header. You could also use two nuts, the outer one secured against the inner one (hold the inner in place with a wrench).
In that way the bolt is never re-installed unless you are removing the header completely.
Page 1 of 2 1 2 >
