Mobil1 5W-30 EP, 8317mi, 2007 Prius Touring, 98133
by DuckRyder. 03/21/19 05:32 PM
Maxima Pro Plus 20/50 syn bike oil
by Truckedup. 03/21/19 04:54 PM
CHAMPION COS 3593A **NEW** CUT OPEN
by 53' Stude. 03/21/19 04:28 PM
NAPA PROSELECT 21348 CUT OPEN
by 53' Stude. 03/21/19 04:21 PM
Atlanta No Nonsense Honda dealer
by DuckRyder. 03/21/19 04:16 PM
Echo (PAS) - Good, Bad, Other?
by GemStater. 03/21/19 04:06 PM
Serpentine Belt - When To Change?
by Propflux01. 03/21/19 03:08 PM
Magnetic Out, ST in at Wally Auto Care Center.
by csandste. 03/21/19 02:26 PM
One license plate in a Two-Plate State
by bunnspecial. 03/21/19 02:07 PM
TPMS Units Honda
by Chester11. 03/21/19 01:58 PM
Another brake question
by supton. 03/21/19 01:54 PM
BOUGHT WRONG OIL FILTER
by IBelieveinlube. 03/21/19 01:47 PM
miscible ester, using is as oil additive ?
by pep808. 03/21/19 01:23 PM
LT Oil Temps
by StillLearning. 03/21/19 12:44 PM
What kind of lug nut is this?
by LeakySeals. 03/21/19 12:38 PM
Need help finding a riding mower with $1,500 budget
by MetalSlug. 03/21/19 11:55 AM
Volvo 2.0 Turbo
by Ddub. 03/21/19 11:43 AM
Paperboy, Flinch, AlanGonzales, Jrealstreeter, DarkFrontier
67576 Registered Users
93 registered members (addyguy, ArrestMeRedZ, 2009Edge, anndel, 53' Stude, 240_Ed, 15 invisible), 2,070 guests, and 63 spiders.
Topics286,203
Posts4,904,149
Members67,576
Most Online2,967
Mar 10th, 2019
30 weight dino vs. 10w-30 synthetic for generator #4447923
07/02/17 11:16 PM
07/02/17 11:16 PM
Houston
MarkLTX Offline OP
MarkLTX  Offline OP
Houston
I recently bought a generator with a 7 HP air-cooled engine (DuroStar DS4000S). The manual recommends using 10w-30 in temps up to about 80 degrees F and straight 30 weight above that. However, I'm sure that refers to conventional oil whereas I would like to use synthetic.
What viscosity synthetic would you guys recommend? I like the idea of a multi-grade oil, e.g. 10w-30, to get better flow at startup. Will a synthetic 10w-30 do the job in 95-100 degree weather that, apparently, a conventional 10w-30 can't? Well it perform as well as conventional straight 30 weight in 100 degree temps?
Re: 30 weight dino vs. 10w-30 synthetic for generator [Re: MarkLTX] #4447934
07/02/17 11:38 PM
07/02/17 11:38 PM
Where the wind comes sweepin'
Reddy45 Offline
Reddy45  Offline
An air cooled generator in Houston? Is it mostly for emergency power or for job site?
For emergency use - Stick with synthetic 10W30. As with any emergency equipment, you would need to run it occasionally to make sure the fuel doesn't go bad and to ensure it's ready when needed.
For jobsite - I would put something like Rotella SAE 30 grade or even 15W40. Something stout.
Re: 30 weight dino vs. 10w-30 synthetic for generator [Re: MarkLTX] #4447940
07/02/17 11:42 PM
07/02/17 11:42 PM
Northern Kentucky
901Memphis Offline
901Memphis  Offline
Northern Kentucky
10w30 synthetic will generally always be superior to an SAE 30
2012 Chevy Cruze LT 1.4T - 59k - Edge 0w30 SL + Mahle OX401D
2002 Buick Century 144k - Built 4T65e(Maxlife) - GTX 5w30 + Fram XG3980
Re: 30 weight dino vs. 10w-30 synthetic for generator [Re: MarkLTX] #4447952
07/03/17 12:26 AM
07/03/17 12:26 AM
South Carolina
bmwtechguy Offline
bmwtechguy  Offline
South Carolina
This is what I have been using for quite a few years. Equipment all runs like new. Amsoil Commercial 10W-30 Synthetic
Before it was available we used Amsoil SAE 30/10W-30 which was available only in gallons.
Re: 30 weight dino vs. 10w-30 synthetic for generator [Re: MarkLTX] #4447962
07/03/17 12:48 AM
07/03/17 12:48 AM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
There will be NO "start-up flow issues" in Houston.
I use 15W-40 HDEO (Shell Rotella, Chevron Delo) in all air cooled engines.
Re: 30 weight dino vs. 10w-30 synthetic for generator [Re: MarkLTX] #4448015
07/03/17 06:19 AM
07/03/17 06:19 AM
Port Orange, Florida
Panzerman Offline
Panzerman  Offline
I would go with a Straight 30HD or 15w40. You don't need the cold flow properties of a synthetic. You need extreme heat protection and burn off.
2006 Dodge Ram 2500 Hemi 4x4
2016 Dodge Challenger Scat Pack
Re: 30 weight dino vs. 10w-30 synthetic for generator [Re: MarkLTX] #4448022
07/03/17 06:31 AM
07/03/17 06:31 AM
wi
dave123 Offline
dave123  Offline
wi
Amsoil ASE 30/10w30 or ASF 10w40 is what I would run.
Re: 30 weight dino vs. 10w-30 synthetic for generator [Re: MarkLTX] #4448052
07/03/17 07:47 AM
07/03/17 07:47 AM
Midwest, Illinois
beanoil Offline
beanoil  Offline
Midwest, Illinois
Straight 30 weight. No VI to shear, and will easily handle anything an air cooled small motor will do.
Delo and Rotella come to mind, Rural King sells Mobil in straight 30 weight.
Lube King, Harvest King at Farm and Home, Traveller at Tractor Supply.
Cold flow? Not where you are, and not in OPE.
beanoil: Tough under heat, real dirty afterwards.
Re: 30 weight dino vs. 10w-30 synthetic for generator [Re: MarkLTX] #4448103
07/03/17 08:36 AM
07/03/17 08:36 AM
MO
Carbon12 Offline
Carbon12  Offline
MO
A typical PCMO 10w30 has an HTHS viscosity of about 3.1cP. I have occasionally seen HTHS values for SAE 30 around 3.6 cP. This is likely why the SAE 30 is recommended for the higher temps. In my opinion an oil with an HTHS of 3.1 is too thin for the heat you may encounter in summer where you are.
As a compromise I am running Rotella 10w30 synthetic blend in my generator (emergency power) since 10w30 HDEOs usually have an HTHS of 3.5. After I get a few more hours on it I plan to switch to a 0w40 synthetic for the 3.6 - 3.7 HTHS
Re: 30 weight dino vs. 10w-30 synthetic for generator [Re: Carbon12] #4448108
07/03/17 08:44 AM
07/03/17 08:44 AM
USA
ArcticDriver Offline
USA
I appreciate you citing specific reasons for your advice but this poster lives in Houston so there is zero advantage to a 0w40, right?
Multiple Diesel and Gasoline vehicles
Re: 30 weight dino vs. 10w-30 synthetic for generator [Re: MarkLTX] #4448110
07/03/17 08:46 AM
07/03/17 08:46 AM
il usa
merconvvv Offline
merconvvv  Offline
il usa
I also have a similar question.
Synthetic 10w30 v conventional sae 30.
Which has better noack?
Sae 30 noack info i cannot find for say pyb quaker state mobil valvoline castrol etc.
Will a conventional sae 30 will have low noack like 5 or lower for sure ?
1988 Mazda RX7 na PP 10w30 Noack 4.7
1994 Chrysler Concorde 3.3
1999 Ford Expedition 4.6 QSUD 10W30 NOACK 5.0
Re: 30 weight dino vs. 10w-30 synthetic for generator [Re: MarkLTX] #4448123
07/03/17 08:56 AM
07/03/17 08:56 AM
Illinois
tig1 Offline
tig1  Offline
Illinois
I have used M1 10-30 in all my OPE for many years, including my 5KW Powermate generator.
2007 Ford Fusion 239,000 miles
M1 0-20 EP
2017 Ford Fusion 67K
M1 0-20 EP
M1 ATF and Valvoline LV
M1 10-30 in all OPE
MC filters
Re: 30 weight dino vs. 10w-30 synthetic for generator [Re: ArcticDriver] #4448129
07/03/17 09:00 AM
07/03/17 09:00 AM
MO
Carbon12 Offline
Carbon12  Offline
MO
Right. I would say no need or advantage for 0w40 in Houston. I plan to switch to it since I may need my generator at 0 - 100 F. If I lived in a warm climate I would be confident in SAE 30.
Re: 30 weight dino vs. 10w-30 synthetic for generator [Re: MarkLTX] #4448169
07/03/17 09:45 AM
07/03/17 09:45 AM
California
SavagePatch Offline
SavagePatch  Offline
California
I like GC 0w30 for OPE.
Re: 30 weight dino vs. 10w-30 synthetic for generator [Re: MarkLTX] #4448190
07/03/17 10:16 AM
07/03/17 10:16 AM
Pittsburgh,PA U.S.A.
JimPghPA Offline
JimPghPA  Offline
For the high temperatures you can see in Houston Mobil 15W-50 would be a great choice.
Boy will I be happy when ALL vehicles on public roads are autonomous.
JimPghPa
