New Toyota Tacoma oil recommentation
by Moondawg. 03/19/19 08:11 PM
Which oil for modified turbo engine?
by headoff93. 03/19/19 08:02 PM
Problems After Adding 2 Stroke To Diesel
by InfernoRedBeast. 03/19/19 07:47 PM
Amsoil filter
by Bill_W. 03/19/19 07:01 PM
My $1 ocod 4k
by Pinoak. 03/19/19 06:58 PM
GMC tailgate latch repair question
by aquariuscsm. 03/19/19 06:49 PM
Can I Use Maple Syrup Instead Of Oil ?
by Warstud. 03/19/19 06:09 PM
Should criminals be given a second chance?
by ZZman. 03/19/19 04:28 PM
Oil recommendations for old car
by chromedome. 03/19/19 04:06 PM
Reply Box Window
by das_peikko. 03/19/19 03:45 PM
New plants around the yard
by gregk24. 03/19/19 03:24 PM
New Nissan Titan XD w/5.6l oil choices
by josephp732. 03/19/19 03:20 PM
Gran Prix Tour RS tires
by HangFire. 03/19/19 01:50 PM
Look How Good Our Cars Are Getting!
by ekpolk. 03/19/19 11:49 AM
Good or bad? Special ordering a brand new car?
by Ed_Flecko. 03/19/19 11:49 AM
Good Purchase?
by FordBroncoVWJeta. 03/19/19 11:33 AM
not sure what spark plugs to buy now
by MrTruckDriver. 03/19/19 11:33 AM
mm2020, emepher, headoff93, yahtzee, jmd
67560 Registered Users
140 registered members (1foxracing, 2015_PSD, 2010Civic, 01rangerxl, 2004tdigls, 14 invisible), 2,065 guests, and 57 spiders.
Topics286,084
Posts4,902,266
Members67,560
Most Online2,967
Mar 10th, 2019
Shorten OCI w/ ethanol usage? 2014 GM L83 5.3 #4447244
07/02/17 09:03 AM
07/02/17 09:03 AM
IL
04SE Offline OP
04SE  Offline OP
IL
My 2014 Chevrolet Silverado has the 5.3 L83 engine and I use E85 exclusively. I am almost 2,000 miles into my OCI and the OLM is tracking precisely towards the 7,500 mile OCI that GM recommends.
Ford calls for a severe service OCI when using E85 (according to my previous 2009 FX4). GM doesn't even mention a shortened OCI (for any reason) anywhere that I have found yet for this engine. I thought that GM might have the PCM programmed to shorten the OCI with E85 usage and other factors but she is on track to hit 7,500 miles almost exactly at 0%.
I am running Mobil 1 EP 0w20 w/ Wix 57045 and am planning on an OCI at 3,000 just to see if the E85 is chewing up the oil and see if I have any dilution due to the direct injection.
Thoughts?
Life's little problems can be solved with a shovel and silence.
Re: Shorten OCI w/ ethanol usage? 2014 GM L83 5.3 [Re: 04SE] #4447295
07/02/17 10:15 AM
07/02/17 10:15 AM
Crawfordville FL
SilverFusion2010 Offline
Crawfordville FL
My ford manual states severe service oci when running e85. The only way you'll know for sure is to UOA
2010 Ford Fusion SE 3.0L V6, 181 miles M1 HM 10w-30
Re: Shorten OCI w/ ethanol usage? 2014 GM L83 5.3 [Re: 04SE] #4447300
07/02/17 10:19 AM
07/02/17 10:19 AM
Texas
WyrTwister Offline
WyrTwister  Offline
Texas
Flex Fuel engine ?
How does fuel economy on E85 compare to the E10 common here ?
Thanks , :-)
Wyr
God bless
Wyr
God bless
Re: Shorten OCI w/ ethanol usage? 2014 GM L83 5.3 [Re: WyrTwister] #4447321
07/02/17 10:34 AM
07/02/17 10:34 AM
Crawfordville FL
Crawfordville FL
Originally Posted By: WyrTwister
Flex Fuel engine ?
Thanks , :-)
Wyr
God bless
20/25% less mpg. I just run regular pump gas. I've never found an e85 station to be convenient in terms of location. I few tanks of e85 will clean out a motor though. Carbon go bye bye. Also the motor is supposed to add 10HP on e85. I guess ford programmed it to advance the timing
Re: Shorten OCI w/ ethanol usage? 2014 GM L83 5.3 [Re: 04SE] #4447323
07/02/17 10:35 AM
07/02/17 10:35 AM
Canyon County Idaho
CT8 Online content
CT8  Online Content
Canyon County Idaho
Syn oil seems like a 100% waste with short oil changes.
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: Shorten OCI w/ ethanol usage? 2014 GM L83 5.3 [Re: 04SE] #4447342
07/02/17 10:58 AM
07/02/17 10:58 AM
Virginia Beach
Astro14 Offline
Astro14  Offline
Virginia Beach
For my Toyota flex-fuel vehicle, the OCI is one half that of the regular fuel vehicles.
For my truck, the OCI is 10,000 miles for a regular engine, it's 5,000 miles for the flex fuel.
The service minder in my Tundra (an FFV) is simply set to 5,000 miles. No real OLM that monitors usage. It simply counts down time and miles. Interestingly, the owner's manual goes on to say that if primarily E85 fuel is used, the oil change interval should be halved, which implies a 2,500 mile OCI...
As far as MPG, arithmetic would tell you that 85% ethanol would get you about a 35% loss in MPG, because of energy density of ethanol versus gasoline.
In practice, it's closer to 20% loss in MPG.
This may be because E85 is anywhere from 50% to 85% ethanol, so the full reduction isn't realized because it's not actually 85% ethanol every time I've filled it. Further, the truck runs better on E85. More responsive, more HP. Not a huge change, but definitely noticeable. So, perhaps I am also using less throttle, which might contribute to efficiency in a very modest way.
32 Packard 15W40
02 Volvo V70 T5 0W40 M1
02 Volvo V70 XC 0W40 Edge
05 MB S600 0W40 M1
Re: Shorten OCI w/ ethanol usage? 2014 GM L83 5.3 [Re: 04SE] #4447356
07/02/17 11:23 AM
07/02/17 11:23 AM
USA
slacktide_bitog Offline
USA
Your Silverado has an OLM, which will account for the E85 usage smile
Re: Shorten OCI w/ ethanol usage? 2014 GM L83 5.3 [Re: 04SE] #4447386
07/02/17 12:05 PM
07/02/17 12:05 PM
IL
04SE Offline OP
04SE  Offline OP
IL
Flex Fuel engine ?
Thanks , :-)
Wyr
God bless
https://bobistheoilguy.com/forums/ubbthr..._oc#Post4392091
GM only allows for 0w20 in this engine and I have a factory 100,000 mile powertrain warranty to maintain.
That is just it, the OLM hasn't reduced oil life beyond 7,500 miles per OCI. The OLM shows a percentage and when you do the math of miles driven versus percentage used it works out to almost exactly 7,500 miles - as in 7,4XX. It would appear that the OLM is just a counter and not a 'smart' OLM.
Re: Shorten OCI w/ ethanol usage? 2014 GM L83 5.3 [Re: 04SE] #4447398
07/02/17 12:17 PM
07/02/17 12:17 PM
Florida
hatt Offline
hatt  Offline
Florida
My 2013 Ford doesn't say anything about a shorter OCI. It does say to run a tank of regular gas each oil change if using e85 exclusively.
2013 F150 5.0, Delo XLE CK-4 10W-30, Baldwin B7449
2010 Camry 2.5, PP 10W-30, Mobil1 M1C-251A
Re: Shorten OCI w/ ethanol usage? 2014 GM L83 5.3 [Re: 04SE] #4447428
07/02/17 12:59 PM
07/02/17 12:59 PM
TN USA
Crispysea Offline
Crispysea  Offline
TN USA
My wife has a 2012 Grand Caravan with the 3.6L Pentastar. It goes from 17-18 mpg on E10 to around 14-15 mpg on E85. I have a few E85 stations close by, but the price usually isn't worth it. However, it hit $1.50 last week, so I filled it up. There's definitely more torque and HP. I changed the plugs last month, and the valves were very clean. I'd been using E85 every few tanks.
Re: Shorten OCI w/ ethanol usage? 2014 GM L83 5.3 [Re: 04SE] #4447459
07/02/17 01:42 PM
07/02/17 01:42 PM
Fly-over country
zuluplus30 Offline
zuluplus30  Offline
Fly-over country
Thoughts?
Your Oil Life Monitor will account for the E85 automatically and shorten your OCI accordingly. Watch how quickly your oil life drops while running E85.
Re: Shorten OCI w/ ethanol usage? 2014 GM L83 5.3 [Re: 04SE] #4447502
07/02/17 02:46 PM
07/02/17 02:46 PM
USA
USA
What kind of driving do you do in your truck? Highway miles? Towing? etc
Re: Shorten OCI w/ ethanol usage? 2014 GM L83 5.3 [Re: SilverFusion2010] #4447606
07/02/17 04:43 PM
07/02/17 04:43 PM
Texas
WyrTwister Offline
WyrTwister  Offline
Texas
Flex Fuel engine ?
Thanks , :-)
Wyr
God bless
20% - 25% Is about what I have heard . Do not have a flex fuel vehicle , but with the decreased mileage , the cheaper price for E85 seems like just about a wash ? ( There is a convenience store close to work that has E85 . )
Thanks ! :-)
Wyr
God bless
Wyr
God bless
Re: Shorten OCI w/ ethanol usage? 2014 GM L83 5.3 [Re: 04SE] #4447673
07/02/17 06:13 PM
07/02/17 06:13 PM
Crawfordville FL
Crawfordville FL
I concluded that it was a wash the last time I crunched numbers but it's been years since I seriously looked at it. If you care about using less gasoline then that's a point to consider. Otherwise I think it's kind of a fools fuel. I wish I could find E0 at a reasonable price
Re: Shorten OCI w/ ethanol usage? 2014 GM L83 5.3 [Re: 04SE] #4447876
07/02/17 10:23 PM
07/02/17 10:23 PM
Albury, NSW
JFAllen Offline
JFAllen  Offline
Albury, NSW
E85 can pollute sumps, especially in cold start conditions where the fuel mix is rich and no parts are yet at operating temperature (the same is true of normal petrol.) However ethanol poorly mixes with oil - hence potential for problems. Thus, if you only do short trips as part of your regular commute (say <16kms or 10miles) then the oil in the sump never gets hot enough to vaporise the petrol and ethanol components. Plus over the course of your oil change you have a significantly higher number of 'cold starts.' Thus the greater number of events that have the potential to contaminate the oil. If you however do longer commutes, drive long distances regularly or are often putting the engine under load (towing / live in the mountains / sports driving / ...) then the more volatile petrol and ethanol will vaporise and be consumed through your engines crank case breathing system.
Remember ethanol has a boiling point of 78C, while engine oil is supposed to operate at 100C. Petrol likewise has a boiling point far below 100C, though this will vary from region to region / month to month.
Ford have had similar sump pollution problems in their passenger diesels with DPF's. The 'active' regen dumps significant amounts of fuel into the engine to 'burn-off' soot in the filter. However, this causes the cylinder bores to be washed and fuel escapes into the sump. Overtime this excess fuel vaporises.
In theory, engines that burn alcohol fuels 'should' keep their engine oils cleaner though significantly lower soot production. It's just that in certain use cases, oil can become contaminated. And unlike the diesel example, petrol and ethanol have no lubricity. Hence the valid concern.
For the cost of an oil change and if you're curious, it would be good to know the results. But GM gave a warrenty based on their engineering and testing, suggesting 7,500miles.
Regards
Jordan.
