New R1250GS and R1250RT
by 02SE. 09/21/18 12:55 AM
Inside Break Booster & Master Cylinder
by StevieC. 09/20/18 11:22 PM
Inside an Alternator
by StevieC. 09/20/18 11:18 PM
What vehicles are you using Maxlife ATF in?
by BlakeB. 09/20/18 11:10 PM
How a Power Steering Rack Works (Electronic)
by StevieC. 09/20/18 11:00 PM
How a Power Steering Rack Works (Hydraulic)
by StevieC. 09/20/18 10:58 PM
silly wiper problem
by bowlofturtle. 09/20/18 10:33 PM
Canadian Tire Shell Rotella T-6 in Pails
by Snagglefoot. 09/20/18 10:04 PM
Best diesel fuel for cold weather?
by Dickm. 09/20/18 10:03 PM
Type 1 Diabetics - New Research
by StevieC. 09/20/18 10:00 PM
Tire Sizing and Options
by NewEnglander. 09/20/18 09:59 PM
2013 Scion FR-S | Transmission Fluid Questions
by nicknak. 09/20/18 09:47 PM
Meguiar's Liquid Cleaner Wax $5 WalMart, Amazon
by The_Cams. 09/20/18 08:42 PM
Winter oil recommendation
by Neptune. 09/20/18 08:27 PM
M1 0W-40
by CT8. 09/20/18 07:37 PM
What controls timing on my 08 Honda?
by Roland. 09/20/18 07:23 PM
The real culprit about 18k
by Ablebody. 09/20/18 06:04 PM
How not to drain a pool.
by StevieC. 09/20/18 05:50 PM
Direct_Rejection, donatom, Sylent_Snyper, Ajizzle, nicknak
66033 Registered Users
31 registered members (BlakeB, Ablebody, Ag76, Bjornviken, 4 invisible), 867 guests, and 39 spiders.
Topics290,744
Posts4,849,441
Members66,033
Most Online3,590
Jan 24th, 2017
Page 1 of 3 1 2 3
2006 Buick Lacrosse CX 3.8l #4447148
07/02/17 04:27 AM
07/02/17 04:27 AM
Texas
WyrTwister Offline OP
Texas
Bought a used Buick , last Monday , with 37,000 + miles . This correlates with Car-fax .
The dealer did an oil / filter change .
From looking at documentation , the factory OCI appears to be 3,000 miles . I have no problem with that .
My question is , I am thinking the NAPA 5W-30 Dexos synthetic oil I purchased on sale ( a month or two back ) for our Sonic , should be OK for the Buick ?
Bought a Fram PH3387A filter this afternoon at Walmart . To have one on hand . Are those Fram filters OK ?
Plan to order 6 - 12 filters from RockAuto.com , depending on there sale prices & freight .
Thanks , :-)
God bless
Wyr
Wyr
God bless
Re: 2006 Buick Lacrosse CX 3.8l [Re: WyrTwister] #4447156
07/02/17 04:52 AM
07/02/17 04:52 AM
ROCHESTER, NY
Char Baby Offline
Char Baby  Offline
ROCHESTER, NY
Yes, that oil should be perfect. The oil filter(PH3387a) is OK for an oil change but buy a step up or two for the rest of your oil change intervals (OCI). Others will chime in with more info.
"Retired"
'15 Nissan Altima 2.5 SV
'15 Honda Civic LX(17K)
Re: 2006 Buick Lacrosse CX 3.8l [Re: WyrTwister] #4447161
07/02/17 05:31 AM
07/02/17 05:31 AM
Houston, TX
czbrian Offline
czbrian  Offline
Houston, TX
Doesnt't that year model have an oil life monitor? I pulled up a manual using google and it says to use the oil life monitor unless it is accidently reset, in which case change at 3000. If you have an oil life monitor, you should just follow it and if you want to be conservative, just change at 15% or something. I don't think the 3.8 in those was hard on oil and you will using a better oil than originally specified.
Re: 2006 Buick Lacrosse CX 3.8l [Re: WyrTwister] #4447166
07/02/17 05:55 AM
07/02/17 05:55 AM
Minnesota
bmod305 Offline
bmod305  Offline
Minnesota
Replace the coolant elbows. About the only thing on a 3800 that will leave you walking home.
Dave
Re: 2006 Buick Lacrosse CX 3.8l [Re: WyrTwister] #4447189
07/02/17 07:13 AM
07/02/17 07:13 AM
Virginia
bigt61 Offline
bigt61  Offline
Virginia
Any dino SN oil will be fine for 3k - and any cheap filter will work. That 3.8 is almost indestructible. The NAPA Synthetic you have should be good for at least a 6,000 mile OCI, regardless of time or short trips - just keep it topped off. Sounds like a sweet low mileage car to me.
92 Suburban 2500 7.4L 58k M1_0w40 5yr OCI
99 Olds Aurora 4.0L 91K M1_5w30 5yr OCI
13 Dodge Dart 2.0L 30k PP 0w20 OLM OCI
70 Camaro 5.7L 59k
Re: 2006 Buick Lacrosse CX 3.8l [Re: WyrTwister] #4447232
07/02/17 08:26 AM
07/02/17 08:26 AM
socal
barkingspider Offline
socal
If u are going to get the filters in bulk from rockauto, I would just the oem ac delco pf47 filter. They are better than the fram and a tiny bit less expensive. They can be used for the entire olm or less. If u are gonna do 3k oci, use cheap or clearance oil and cheap jobber oil filters
06 Cadillac Escalade Ext
17 Cadillac ATS (wife)
05 Toyota Camry (daughter)
11 GMC Canyon off-road (daily)
Re: 2006 Buick Lacrosse CX 3.8l [Re: czbrian] #4447242
07/02/17 08:59 AM
07/02/17 08:59 AM
Texas
Texas
Yes , I think it has an oil life monitor .
Thanks ,
Wyr
God bless
Wyr
God bless
Re: 2006 Buick Lacrosse CX 3.8l [Re: bmod305] #4447245
07/02/17 09:03 AM
07/02/17 09:03 AM
Texas
Texas
Dave
Is this what you are referring to ?
https://www.rockauto.com/en/catalog/buick,2006,lacrosse,3.8l+v6,1432026,cooling+system,bypass+hose,2155
How many of those are used on the 3.8l engine ?
Planning on replacing the radiator hoses , maybe heater hoses , maybe thermostat / gasket . And coolant ( Dexcool ) . Due to age , not miles .
Can add those elbows to the list , too .
Thanks ,
Wyr
God bless
Wyr
God bless
Re: 2006 Buick Lacrosse CX 3.8l [Re: bigt61] #4447247
07/02/17 09:06 AM
07/02/17 09:06 AM
Texas
Texas
Do not know yet it it uses any oil . So , topping it off may or may not be an issue .
We had 4 Chevy Luminas with 3.1l engines . Is this 3.8l V-6 simular / related to the 3.1l ?
Thanks ,
Wyr
God bless
Wyr
God bless
Re: 2006 Buick Lacrosse CX 3.8l [Re: WyrTwister] #4447253
07/02/17 09:10 AM
07/02/17 09:10 AM
USA
slacktide_bitog Offline
USA
Your Lacrosse should have an OLM that calculates an OCI for you, which can be much longer than 3k.
Nothing wrong with the PH3387A, but I'd rather use an Ultra or a Wix-made filter, such as the ST3387 (or any of Napa's house-brand filters).
Napa Synthetic is rebranded Synpower and a quality synthetic oil at a great price when on sale at Napa. While dexos isn't required in your 2006 Buick, there is certainly nothing wrong with using it, and in fact it's probably better than any oil available when your car was brand new.
Re: 2006 Buick Lacrosse CX 3.8l [Re: WyrTwister] #4447259
07/02/17 09:14 AM
07/02/17 09:14 AM
MN
oil_film_movies Offline
MN
No, completely different origin and evolution since the block was used in https://ateupwithmotor.com/model-histories/buick-special-skylark-rover-v8-3800-v6-history/ many years ago. Chevy V6 is an evolution of the original 2.8L V6 used in Citations from 1980+, completely different. No common parts.
Re: 2006 Buick Lacrosse CX 3.8l [Re: WyrTwister] #4447263
07/02/17 09:18 AM
07/02/17 09:18 AM
MN
MN
In that car, I'd use SuperTech 5w30 Full Synthetic at Walmart for a great value (Warren Oil Company). Although, if NAPA has a $3/quart sale on their synthetic, then go with that, a re-branded sodium-additive Valvoline, a great deal. 5w30
The best oil filter is a Fram Ultra (wire-backed media, silicon ADBV, best filtering performance), again from Walmart, costs about $7 bucks more than cheapo brand oil filters.
Re: 2006 Buick Lacrosse CX 3.8l [Re: WyrTwister] #4447265
07/02/17 09:27 AM
07/02/17 09:27 AM
MN
MN
The Fram PH's are fine. Fram's Ultra is XG3387A (note the "XG" part). Ultra is clearly the better one, but the PH's have good reputations, and the PH's do have some glass fibers mixed into the cellulose paper filtering media which helps performance.
The main thing: Never buy Purolator. They have horrible reputations for ripping holes in the filtering element.
Any oil filter except Purolator will do. (Although the more expensive Purolator Boss model is OK.)
Re: 2006 Buick Lacrosse CX 3.8l [Re: WyrTwister] #4447270
07/02/17 09:31 AM
07/02/17 09:31 AM
MN
MN
That Buick 3.8L is a good one. Iron block, iron heads, all iron. Great torque and MPG. https://en.wikipedia.org/wiki/Buick_V6_engine
GM should have continued making it and they should have put that low-end-torque monster in 1/2 ton pickup trucks as the perfect choice for the low end Work Truck models and cheaper base 1500's.
Re: 2006 Buick Lacrosse CX 3.8l [Re: WyrTwister] #4447274
07/02/17 09:37 AM
07/02/17 09:37 AM
Texas
Texas
Think the NAPA synthetic was about $ 4 a quart . Bought 24 quarts .
Thanks ,
Wyr
God bless
Wyr
God bless
Page 1 of 3 1 2 3
