Bad Motorcraft Plug?
by tmorris1. 03/21/19 10:47 AM
SAE 20 non-detergent oil
by fleetwood62. 03/21/19 10:39 AM
PSF3 in older Kia?
by Jetsfan421. 03/21/19 09:48 AM
USB WiFi adapter recommendations?
by Quattro Pete. 03/21/19 09:44 AM
m1,ep and valvoline.
by avi1777. 03/21/19 09:39 AM
540 RAT
by elpcmaster. 03/21/19 09:18 AM
Caliper recommendation?
by supton. 03/21/19 09:08 AM
Honda st1300 LED light
by Zuraxus. 03/21/19 08:26 AM
2001 CRV no restart when hot
by Kurtatron. 03/21/19 07:27 AM
Amazing human feats - free-diving...
by Shannow. 03/21/19 04:59 AM
How long to warm-up an engine?
by OilUzer. 03/21/19 04:58 AM
Disappearance and appearance
by bbhero. 03/21/19 04:38 AM
Big Changes for WIX 51334 - Pics
by tony1679. 03/21/19 04:26 AM
Supertech Synthetic Data Sheets
by The Critic. 03/21/19 04:25 AM
Forester XT filter recommandation
by jbutch. 03/21/19 04:23 AM
Taking the leap to self-employment.....
Eventually
by clinebarger. 03/21/19 01:39 AM
Redline releases Professional Series
by Marco620. 03/20/19 11:52 PM
M1 HM 10w-30 vs M1 FS 0w-40
by RDY4WAR. 03/20/19 10:04 PM
Need Recommendations For A New SUV
by Dwight_Frye. 03/20/19 08:50 PM
AlanGonzales, Jrealstreeter, DarkFrontier, Zuraxus, Burks21
67574 Registered Users
99 registered members (arowbat, addyguy, 928, a2gtinut, 3311, 69GTX, 11 invisible), 1,933 guests, and 59 spiders.
Topics286,183
Posts4,903,721
Members67,574
Most Online2,967
Mar 10th, 2019
What are these AC pressures telling me? #4446731
07/01/17 02:16 PM
07/01/17 02:16 PM
El Oeste
HawkeyeScott Offline OP
El Oeste
This is the wife's 2007 Chrysler Pacifica 4.0 with original AC system components. Seemed to cool rather poorly just as the summer began. It blew some cool air but it was definitely under performing. But, just in the last week or so, it seems to have improved on its own. It's not the coldest it's ever been, but it's not bad.
I put gauges on it today. It was 85 degrees out. At idle, the low side read about 19 and the high side ranged from about 240 to 255. Then, at about 2500 rpm, the high side would surge to 325 with the low side pretty much staying put.
Based on what I see online, the low side is a little low at idle and the high side is normal. But at higher RPMs, the low side remains low while the high side is very high. Again, though, the system is putting out a fair amount of cool air.
Blockage? Dying component? Investigate more? Leave it alone? Thanks.
Re: What are these AC pressures telling me? [Re: HawkeyeScott] #4446742
07/01/17 02:23 PM
07/01/17 02:23 PM
out there
spasm3 Offline
spasm3  Offline
out there
Does the fan work? Condenser clean ? 19 on the low side may be a bit undercharged.
13 elantra 75k 5w30 QSUD
03 chevy avalanche 80k synpwr 5w30
17 mazda cx-5 9500 miles m1 0w30
Re: What are these AC pressures telling me? [Re: HawkeyeScott] #4446745
07/01/17 02:25 PM
07/01/17 02:25 PM
El Oeste
El Oeste
Yep, both fans are running and the condenser is clean.
Re: What are these AC pressures telling me? [Re: HawkeyeScott] #4446753
07/01/17 02:32 PM
07/01/17 02:32 PM
Deplorable in apple valley, ca
Chris142 Offline
Chris142  Offline
Has anyone added refrigerant?
02 Wrangler carlube 5w30
87 F250 traveler 15w40
07 fjcruiser Chevron 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
Re: What are these AC pressures telling me? [Re: HawkeyeScott] #4446761
07/01/17 02:41 PM
07/01/17 02:41 PM
Richmond, VA
DNVDMAX Offline
DNVDMAX  Offline
Richmond, VA
Debris possibly blocking orifice tube or expansion valve.
06 GMC 2500HD DMAX EFILIVE M1 TDT 5w-40 FRAM Ultra
91 GMC K1500 5.7L 5w-30 Quaker State HM Bosch D+
72 Nova 350 SBC 74mm AirWerks Turbo 15w-40 HDEO
Re: What are these AC pressures telling me? [Re: DNVDMAX] #4446762
07/01/17 02:42 PM
07/01/17 02:42 PM
out there
spasm3 Offline
spasm3  Offline
out there
Good suggestion, especially if any " stop leak " has been added.
Re: What are these AC pressures telling me? [Re: Chris142] #4446763
07/01/17 02:43 PM
07/01/17 02:43 PM
Canyon County Idaho
CT8 Offline
CT8  Offline
Canyon County Idaho
Chris is a A/C pro !! this.
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: What are these AC pressures telling me? [Re: HawkeyeScott] #4446766
07/01/17 02:45 PM
07/01/17 02:45 PM
USA
mk378 Offline
mk378  Offline
USA
If the suction line from the evaporator to the compressor is not cold, you have a blockage. I think this will be a TXV system and those valves can get stuck. If stop leak has been added of course all bets are off.
If the line is cold, the air inside the car should be cold too, if it is not the heater may be reheating it.
Re: What are these AC pressures telling me? [Re: HawkeyeScott] #4446796
07/01/17 03:12 PM
07/01/17 03:12 PM
Canada
i_hate_autofraud Offline
Canada
As noted above, put you hand on the exposed pipes near the compressor, the large one ('return' from the evaporator under the dash)
has to be cold.
The small dia pipe off the compressor must be warm/hot.
CHECK your air blend doors & actuators in the dash, they tend to be weak or sticky and won't fully
open to the cold a/c position.
Re: What are these AC pressures telling me? [Re: i_hate_autofraud] #4446823
07/01/17 03:53 PM
07/01/17 03:53 PM
USA
mk378 Offline
mk378  Offline
USA
The discharge pipe is normally hot enough to burn you, and it only gets hotter if the refrigerant charge is low, so touching it isn't advisable. It won't tell you much.
Re: What are these AC pressures telling me? [Re: HawkeyeScott] #4446842
07/01/17 04:09 PM
07/01/17 04:09 PM
El Oeste
El Oeste
Initial plan was to add refrigerant but figured that would automatically send the high side pressures higher. Is that an incorrect assumption?
Re: What are these AC pressures telling me? [Re: HawkeyeScott] #4446857
07/01/17 04:25 PM
07/01/17 04:25 PM
USA
mk378 Offline
mk378  Offline
USA
The high side being that high, with the fans running and ambient of 85, suggests that there is plenty of refrigerant.
