Chevy Commercial Parody
by 02SE. 12/17/18 02:37 AM
Fluctuating Tachometer Fixed!
by jerseyguy123. 12/17/18 02:10 AM
2015 MB GLA250: OEM oil vs Mobil1 Formula M
by SlavaB. 12/17/18 12:39 AM
Shotgun Ammo
by user52165. 12/16/18 10:24 PM
Bought a Model 3 for wifey
by JeffKeryk. 12/16/18 09:01 PM
Maybe I'm crazy.
by TRDPRO85. 12/16/18 07:50 PM
Pacer EON E-11 Synthetic Motor Fluid
by Brandon9797. 12/16/18 07:46 PM
Reuse transmission fluid??
by FFeng7. 12/16/18 07:35 PM
Amsoil SS color change
by BigShug681. 12/16/18 07:21 PM
Why don't owner's manuals specify the oil type
by OilUzer. 12/16/18 07:13 PM
belt tensioner problems
by mobilaltima. 12/16/18 06:57 PM
How bout them Patriots
by 53' Stude. 12/16/18 06:36 PM
Hand held Ham radio suggestions
by littleant. 12/16/18 05:20 PM
Ford 2.3 EB's using 87 vs 91/93 octane
by Whimsey. 12/16/18 04:48 PM
Oil analysis pump tube?
by maximum6. 12/16/18 03:56 PM
Mahle charcoal lined filter..the best!
by TiGeo. 12/16/18 03:45 PM
stantaur, Brandon9797, Landngroove, DanielH, Cpcz9382
66700 Registered Users
32 registered members (bmod305, chrisri, billt460, CB900F2, 53' Stude, 6 invisible), 957 guests, and 50 spiders.
Topics295,172
Posts4,929,131
Members66,700
Most Online2,553
Oct 27th, 2018
LE2 Turbo DI in 2nd Generation Cruze #4446608
07/01/17 10:22 AM
07/01/17 10:22 AM
NE US
PolarisX Offline OP
PolarisX  Offline OP
NE US
Finally traded in our 2010 Malibu LT before it became a total money pit and got a great deal on a 2nd gen Cruze.
The question is the LE2 in the new Cruze is turbo direct injected, and I can't find many people talking about it yet. Of course my biggest concern is LSPI and dilution. We moved to 93 octane off the bat and I still log a bit of KR under boost (1 - 2 degrees) and wrote that off as protection in the tune or maps from running 87 octane. Thing makes some monster torque for such a tiny engine. It's pretty great!
Cruzetalk.com isn't really much help for the newer models. I do understand there isn't nearly as many 2nd gen as 1st in the wild. I know the LE2 is a clean slate engine design from the LUJ/LUV Family 0, so my information is limited.
Anyone had time to play with these engines yet, or even better run different oil?
2017 Cruze LT/RS Hatchback 1.4T | Dealer | Dealer | Hankook Kinergy GT
2016.5 Cruze LT 1.4T | Dealer | Dealer | Continential Extreme Contract DWS06
Re: LE2 Turbo DI in 2nd Generation Cruze [Re: PolarisX] #4446620
07/01/17 10:40 AM
07/01/17 10:40 AM
Michigan
A_Harman Offline
A_Harman  Offline
Michigan
The LE2 is prime candidate for LSPI, so be careful with it. It would be worse in a heavier vehicle, such as the Malibu. High octane fuel, low volatility oil, minimize Calcium content, and PCV foul air catch cans are all possible solutions we talk about on BITOG. How is the programming on the transmission? Does it tend to hold higher gears at low engine speeds, forcing it to lug below 2000 rpm?
1985 Z51 Corvette track car
2002 Camaro Z28 LS1/6-speed
2001 Dodge Ram 2500 diesel
1972 GMC 1500 shortbed project truck
Re: LE2 Turbo DI in 2nd Generation Cruze [Re: PolarisX] #4446630
07/01/17 10:54 AM
07/01/17 10:54 AM
Elizabeth. Colorado
c502cid Offline
c502cid  Offline
Elizabeth. Colorado
Not sure my 2015 Trax 1.4 is the same motor as yours but living in the Rockies the standard grade of regular is 85 octane which we ran for the first couple of years. After re-reading the owners manual recommending 87 octane I started running it. My wife who drives the car and notices nothing at all said the performance was much better (I didn't tell her I changed the fuel octane, I fill the tank each week) and MPG went up between 2-3 MPG. The 6 speed A/T in the Trax is a gem, it keeps the motor in the powerband all the time. Love this motor, it will pull Eisenhower Tunnel at 75mph all day long.
17 SuperDuty 6.2 4x4
15 Chev Trax AWD
02 GMC 3500 8.1/Allison 4x4
00 Blazer 4x4
97/98 Civic's
84 Chev K30 454EFI 4x4
71 GMC Jimmy 502 RamJet
Re: LE2 Turbo DI in 2nd Generation Cruze [Re: PolarisX] #4446641
07/01/17 11:12 AM
07/01/17 11:12 AM
Campbellsville, KY
Alex_V Offline
Alex_V  Offline
Campbellsville, KY
I believe the engine in your Trax is the port-injected 1.4T used since 2011 in the Cruze and Sonic. I wonder what the trans./final drive ratios are like compared to the Cruze? If it's geared lower that could make the 1.4 even more fun. But anyway, don't mean to hijack.
To quote a friend, "Synthetics, man."
'85 GMC C3500, 454, 132K
'82 Mercedes 300CD, OM617 turbo, 173K (totaled 2018, in rehab)
'85 Mercedes 300TD, OM617 turbo, 217K (wife's)
'67 Suburban, 350, 331K
Re: LE2 Turbo DI in 2nd Generation Cruze [Re: Alex_V] #4446665
07/01/17 11:49 AM
07/01/17 11:49 AM
Elizabeth. Colorado
c502cid Offline
c502cid  Offline
Elizabeth. Colorado
My bad, for some reason I always thought it was direct injected. Might have to pay more attention next time I look under the hood!
15 Chev Trax AWD
00 Blazer 4x4
97/98 Civic's
Re: LE2 Turbo DI in 2nd Generation Cruze [Re: A_Harman] #4446670
07/01/17 11:58 AM
07/01/17 11:58 AM
Texas & Global
4WD Offline
4WD  Offline
Texas & Global
On my 2013 the PCV is built into a composite valve cover that's $100 on eBay - think I needed one around 80k but dealer did it for free and changed the hose array too.
Wonder if having a catch can ahead of that would make them last allot longer.
2018 Chevy 1500 Z71 4WD
2017 Chevy Tahoe LT 4WD
2014 Fusion Hybrid Titanium
2013 Cruze LTZ - RS Turbo
Re: LE2 Turbo DI in 2nd Generation Cruze [Re: PolarisX] #4446783
07/01/17 01:57 PM
07/01/17 01:57 PM
Idaho
CT8 Offline
CT8  Offline
Idaho
Boosted engines need a retard under boost. Always have always will.
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: LE2 Turbo DI in 2nd Generation Cruze [Re: A_Harman] #4446851
07/01/17 03:15 PM
07/01/17 03:15 PM
NE US
PolarisX Offline OP
PolarisX  Offline OP
NE US
It does tach very low. It's easy to command a downshift however. I never feel like I'm lugging and have no audible sound that it is experiencing anything. I usually call a downshift on hills, which I'm not sure is the right thing to do.
