Mobil 1 Filter Clearance - Wal Mart
by sdude2k2000. 03/22/19 10:01 AM
STP VI trans fluid
by acme. 03/22/19 09:37 AM
Increased oil capacity = lower pil temps ?
by SavagePatch. 03/22/19 09:15 AM
2007 Corolla - P0441 and P0455 codes
by Bama. 03/22/19 08:44 AM
Oldmoparguy1
by cjcride. 03/22/19 08:23 AM
Check engine light
by rtrdad. 03/22/19 08:21 AM
Super Tech 5W30 Synthetic With GDI Engine ?
by ChrisD46. 03/22/19 07:00 AM
Venol A.M.G brand
by headoff93. 03/22/19 05:51 AM
Anyone use this oil?
by lawnguy. 03/22/19 05:47 AM
Amalie Elixir Full Synthetic ?
by lawnguy. 03/22/19 02:23 AM
All 2's tomorrow or Saturday
by Marco620. 03/22/19 01:28 AM
Mobil 1 0W-16
by The Critic. 03/22/19 01:06 AM
2007 Escape - TCC solenoid?
by Burks21. 03/21/19 11:52 PM
Ac Delco oil on Rockauto
by WiskyBadger. 03/21/19 11:09 PM
Old Laptop - Keeps Freezing - Help!
by reemoe2. 03/21/19 09:52 PM
Cinnamon Cake
by StevieC. 03/21/19 09:43 PM
AMALIE OILS
by kstanf150. 03/21/19 09:41 PM
oem filters
by mobilaltima. 03/21/19 09:34 PM
Magna1 10W30
by mobilaltima. 03/21/19 09:32 PM
Anton93, FrancescoO, russrie, scottjeffrey, Mowata
67582 Registered Users
105 registered members (ARCOgraphite, Ag76, Altima2, AZjeff, acme, 2012AccentSE, 10 invisible), 1,949 guests, and 64 spiders.
Topics286,230
Posts4,904,734
Members67,582
Most Online2,967
Mar 10th, 2019
Current opinions of Donaldson DBL7349 #4446467
07/01/17 06:42 AM
07/01/17 06:42 AM
NC, USA
spencerdiesel Offline OP
NC, USA
Hey everyone, I've been reading around this forum for a while now and finally joined. I have a '92 dodge W250 with the 12 valve Cummins and have been running delo (cj4) and the Donaldson 7349 filter for about the past 3 oil changes.
I got the dbl because of the 99% efficiency @ 15 micron rating, and I like that Donaldson posts micron ratings and data for almost all their filters. However, reading some posts here it sounds as if this filter has no ADBV? I have sent 2 UOA's in (1st w/ Rotella & gold pure one filter) and all wear metals were below average on both analysis.
So what is everyone's opinion on the 7349 and does it have ADBV?
Thanks
Re: Current opinions of Donaldson DBL7349 [Re: spencerdiesel] #4446470
07/01/17 06:51 AM
07/01/17 06:51 AM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
The filter doesn't need an ADBV sits it mounts vertically, just like a small block chevy does.
Re: Current opinions of Donaldson DBL7349 [Re: spencerdiesel] #4446480
07/01/17 07:08 AM
07/01/17 07:08 AM
The Midwest
skyactiv Offline
skyactiv  Offline
The Midwest
I'm a journeyman semi mechanic at UPS. The same engine in your truck was used in yard shifter trucks for years to move semi trailers around the yard.
Those engines last 25K hours. The biggest issue we had on the old ones was it would typically need a head gasket and an injection pump at some point.
Me: 13' VW GTI 3 door 6 speed manual
Re: Current opinions of Donaldson DBL7349 [Re: spencerdiesel] #4446483
07/01/17 07:10 AM
07/01/17 07:10 AM
Sav ga
NStuart Offline
NStuart  Offline
Sav ga
I am using Donaldson bdl3998 on 3 trucks with bypass filters, I will cut open a 30k filter next week
Detroit14l 1m75k mi bp schaffer9k 30k oil
96 ram 5.9 gas 80k built tranny 5k m1
85 cj7 4.2 performance build. Schaeffer 9000
08 cbr600rr graffiti. T6
08 husky sm610 t6
Re: Current opinions of Donaldson DBL7349 [Re: skyactiv] #4446544
07/01/17 09:29 AM
07/01/17 09:29 AM
Houston, Texas
motor_oil_madman Offline
Houston, Texas
How long do the engines that leave the yard last? 25k is impressive, but moving around a parking lot isn't really hard use.
2007.5 dodge cummins 6.7 liter. Chevron Delo400 15w40. 7000 mile or 250-300hr intervals.
Re: Current opinions of Donaldson DBL7349 [Re: spencerdiesel] #4446581
07/01/17 10:20 AM
07/01/17 10:20 AM
Houston, Texas
Houston, Texas
If i remember right b50 is 20,000 hrs on the isb cummins
Re: Current opinions of Donaldson DBL7349 [Re: motor_oil_madman] #4446619
07/01/17 11:39 AM
07/01/17 11:39 AM
Canyon County Idaho
CT8 Offline
CT8  Offline
Canyon County Idaho
Actually is it severe.
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: Current opinions of Donaldson DBL7349 [Re: skyactiv] #4446653
07/01/17 12:34 PM
07/01/17 12:34 PM
Cincinnati, OH, USA
bullwinkle Offline
bullwinkle  Offline
Cincinnati, OH, USA
At 50 MPH, that would be 1.25 million miles. Yard mule is tough, a lot of stop & go, accelerate/decelerate constantly-and most of the drivers don't exactly roll into the throttle, more like STOMP!
06 Ram 3500 CTD 4X4(FG Venturi), 93 GMC C3500 6.2, 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 18 Transit 3.7, 03 Merc Grand Marquis 4.6 2V(XG2)
Re: Current opinions of Donaldson DBL7349 [Re: bullwinkle] #4446751
07/01/17 02:31 PM
07/01/17 02:31 PM
NC, USA
NC, USA
Wow a lot of responses! That makes sense about the upright filter, can oil be pulled from the filter over time after the engine is shut off and cooling? I've changed oil/seen other cummins oil changed and sometimes the filter is only about half full?
To anyone else with a 12v, how long after startup is it when your oil light goes out? Mine is 3 seconds on a cold engine in average ambient temps
My 3.4 Tacoma light goes out in about .5 seconds after startup
Re: Current opinions of Donaldson DBL7349 [Re: spencerdiesel] #4447372
07/02/17 11:43 AM
07/02/17 11:43 AM
Sav ga
NStuart Offline
NStuart  Offline
Sav ga
The amount of maint short haul\ jockey trucks that are run hard need would blow most people mind, several of our trucks run 12 -20 mile routes and do several repetitive tasks generally left for jockey trucks and we put avg of 80k a year on the trucks,on avg we spend about 17k per year per truck
08 husky sm610 t6
