Looking for Fram Ultra XG30 and XG5 cut open
by rubberchicken. 12/12/18 10:27 PM
92 f150 332 code
by ram_man. 12/12/18 10:05 PM
Mixing brands of brake fluid / gear lube
by SureshR. 12/12/18 09:26 PM
45,000 miles in the Caprice.
by ls1mike. 12/12/18 09:21 PM
Quality oils?
by Horsehaulin. 12/12/18 09:16 PM
Exhaust fumes in cabin
by Skater4life27. 12/12/18 08:40 PM
Squeaky sunroof
by dishdude. 12/12/18 08:09 PM
Liqui Moly Top Tec 1800
by Chuckh. 12/12/18 07:56 PM
2006 Pathfinder Transmission Shudder
by Bluestream. 12/12/18 07:10 PM
Maybe E-10 is better? - PentaStar (Flex Fuel)
by StevieC. 12/12/18 06:52 PM
Shipping cost
by Fitter30. 12/12/18 06:45 PM
Purolator P1 14476 CUT OPEN
by 53' Stude. 12/12/18 06:00 PM
Which car to buy?
by jrcowboys. 12/12/18 04:55 PM
New Tire Cracking
by robd. 12/12/18 04:43 PM
SAR B6P - Thoughts?
by 28oz. 12/12/18 03:59 PM
Time to sell the 1-ton Dually
by 02SE. 12/12/18 03:55 PM
Shell Rotella Grease
by WMW0505. 12/12/18 02:27 PM
Need to add attic ladder in stairwell
by Klutch9. 12/12/18 12:51 PM
Horsehaulin, JLew, bmrk1100, Rrrracer, jefe_de_estado
66664 Registered Users
42 registered members (Bullwinkle007, carlprop, CaspianM, CKN, A_User55555, Bailes1992, 2 invisible), 1,153 guests, and 37 spiders.
Topics295,007
Posts4,925,870
Members66,664
Most Online2,553
Oct 27th, 2018
Valvoline Vr1 high zinc 20w50 vs vr1 syn 20w50 #4445806
06/30/17 08:37 AM
06/30/17 08:37 AM
Louisiana
SuzukiGoat Offline OP
Louisiana
I'm on my phone and can't find the oily analysis for each. Can anyone explain what the differences between the two are?
2003 Nissan Xterra 4x4 M1 HM 10w40
2001 Toyota 4runner 4x4 M1 0w40
2016 Yamaha YXZ1000R VR1 20w50
Re: Valvoline Vr1 high zinc 20w50 vs vr1 syn 20w50 [Re: SuzukiGoat] #4445834
06/30/17 09:07 AM
06/30/17 09:07 AM
Balearic Islands , Spain
FordCapriDriver Online content
FordCapriDriver  Online Content
ZDDP concentration is the same for both.
According to the Valvoline PI sheets :
Cst 100c : 20.0 ( SYN ) and 21.1 ( Regular )
Cst 40c : 147 ( SYN ) and 193 ( Regular )
Viscosity Index : 154 ( SYN ) 129 ( Regular )
TBN : 8.5 ( SYN ) and 11.8 ( Regular )
Flash point : 230c ( SYN ) and 228c ( Regular )
Pour pint : -36C ( SYN ) and -33C ( Regular )
The synthetic has a lower viscosity at 40c which is to be expected, higher Viscosity index which would also be expected, slightly better flash point, slightly better pour point...
The regular VR1 20W-50 is already good, the synthetic is just a tad better.
Although if you wanted a stout high ZDDP synthetic 50 grade i'd steer more towards M1 15W-50 just because it's much more readily available in the States.
1975 Ford Capri II Ghia 3000 V6, - Shell Helix HX3 20W-50 w/ 20% Rimula R4X 15W-40 HDEO.
1988 Ford Escort Mk4 Xr3i Cabrio, - Shell Rimula R4X 15W-40, w/ 30% Helix 3 20W-50.
Finnish expat in Spain.
Re: Valvoline Vr1 high zinc 20w50 vs vr1 syn 20w50 [Re: SuzukiGoat] #4445849
06/30/17 09:23 AM
06/30/17 09:23 AM
Oregon
1JZ_E46 Offline
1JZ_E46  Offline
Oregon
+1 on the M1 15W-50. Probably the best value racing/street rod oil out there. Used by many racers with success over much more expensive oils.
2007 X5 4.8i: M1 HM 10W-30
2016 Countryman S: EDGE 0W-30
Re: Valvoline Vr1 high zinc 20w50 vs vr1 syn 20w50 [Re: 1JZ_E46] #4445890
06/30/17 10:29 AM
06/30/17 10:29 AM
Louisiana
Louisiana
Any harm or benefit to running a 2:1 ratio of dino to syn? I have about 60 quarts of one and 30 of the other. Only one unit that takes 20w50.
Re: Valvoline Vr1 high zinc 20w50 vs vr1 syn 20w50 [Re: SuzukiGoat] #4445941
06/30/17 11:33 AM
06/30/17 11:33 AM
I'm sure they are perfectly mixable, you can make whatever frankenbrew you like.
Re: Valvoline Vr1 high zinc 20w50 vs vr1 syn 20w50 [Re: SuzukiGoat] #4445951
06/30/17 11:49 AM
06/30/17 11:49 AM
Fort Lauderdale, FL
DoubleWasp Offline
DoubleWasp  Offline
Fort Lauderdale, FL
Both very good oils.
Avoid the M1 15w-50. It's a knockdown when it comes to shear. Developed a great reputation under its old formula, but is now a weak oil compared to the other 50 weight performance oils on the market.
Re: Valvoline Vr1 high zinc 20w50 vs vr1 syn 20w50 [Re: SuzukiGoat] #4445969
06/30/17 12:19 PM
06/30/17 12:19 PM
I certainly haven't ever heard of anybody having any kind of a problem from using M1 15W-50, many people swear by it, and on paper it still looks good.
Re: Valvoline Vr1 high zinc 20w50 vs vr1 syn 20w50 [Re: SuzukiGoat] #4446007
06/30/17 01:24 PM
06/30/17 01:24 PM
Kalifornia Kollective
BrocLuno Offline
BrocLuno  Offline
Yeah, if you can get VR-1, that's the way I'd go. Been proven in countless drag cars for a long time. No questions about the oil (either one). Dino if you want, or syn if you lean that way smile
Re: Valvoline Vr1 high zinc 20w50 vs vr1 syn 20w50 [Re: FordCapriDriver] #4447990
07/03/17 03:05 AM
07/03/17 03:05 AM
Fort Lauderdale, FL
DoubleWasp Offline
DoubleWasp  Offline
Fort Lauderdale, FL
Well known to run away with heat shear. We've changed M1 15-50 out of engines that started having oil pressure problems when hot and restored 15-30 psi hot oil pressure just by replacing it with VR1 or Schaeffer.
Re: Valvoline Vr1 high zinc 20w50 vs vr1 syn 20w50 [Re: SuzukiGoat] #4448046
07/03/17 06:30 AM
07/03/17 06:30 AM
Didn't know that.
Re: Valvoline Vr1 high zinc 20w50 vs vr1 syn 20w50 [Re: DoubleWasp] #4448208
07/03/17 09:34 AM
07/03/17 09:34 AM
Oregon
1JZ_E46 Offline
1JZ_E46  Offline
Oregon
Wow, good to know.
Re: Valvoline Vr1 high zinc 20w50 vs vr1 syn 20w50 [Re: DoubleWasp] #4448239
07/03/17 10:00 AM
07/03/17 10:00 AM
Oregon
1JZ_E46 Offline
1JZ_E46  Offline
Oregon
Was that VR1 synthetic or mineral? How would you say it compares to royal purple HPS? XPR?
Re: Valvoline Vr1 high zinc 20w50 vs vr1 syn 20w50 [Re: 1JZ_E46] #4464585
07/20/17 05:32 AM
07/20/17 05:32 AM
Fort Lauderdale, FL
DoubleWasp Offline
DoubleWasp  Offline
Fort Lauderdale, FL
I'd like to note that there is a UOA in the motorcycle forum of a Harley Davidson engine running M1 15/50 that held viscosity over 5400 miles. That's an eternity for an oil in a Harley engine. There might have been a change in formulation. Harley engines are usually big time shear monsters of even the best oils. This does not mean the oil didn't undergo heat shear under temp, but is an indicator this oil may have gotten more survivable.
We've used VR1 syn and mineral both. We tend to use the syn in the real heat monsters, such as the engines with smaller or no oil engine oil coolers. Heat where oil temp is concerned. Not engine water/coolant temp. They don't track together in boats. I've seen 155F on the water temp and 250-280 on the oil temp. The high-rpm/high-load does a real numbers on the engine oil. It is worth noting that we haven't had any problems at all with the conventional. Use of the syn may be totally unnecessary.
We don't mess with Royal Purple. I don't doubt that it's a good oil, but there's not enough info out there on it being used in marine applications for us to give it a go.
Re: Valvoline Vr1 high zinc 20w50 vs vr1 syn 20w50 [Re: DoubleWasp] #4465132
07/20/17 03:08 PM
07/20/17 03:08 PM
Louisiana
Louisiana
I have been running a blend this fill. 2 quarts of dino and one quart of syn. I have noticed a little more startup noise (dry sump application) but a slightly lower heat reading at the external oil tank.
Put roughly 500 miles on the fillup earlier this week. Over 7k rpm for the majority of those miles. Only 4 stops throughout that time. Quite a few blasts to 11k rpm.
It will be interesting to see what the next oil analysis says.
Draining and sending at 1500 miles indicated (1725 actual).
