Time for a new Generator... Wisdom desired!
by webfors. 09/24/18 06:36 AM
flat roof weight bearing support
by henni. 09/24/18 06:29 AM
ADD A MARBLE - Make Life Easier
by MasterSolenoid. 09/24/18 06:17 AM
Mobile 1 ESP @ Dowler Karn St. Thomas Ont
by RogerBacon. 09/24/18 05:40 AM
Mobile 1 ESP @ Dowler Karn St. Thomas Ont.
by RogerBacon. 09/24/18 05:37 AM
Direct Injection Valve Cleaning Maintenance
by RayCJ. 09/24/18 05:20 AM
Chattanooga tn ,cycling
by CourierDriver. 09/24/18 04:42 AM
Sunrise, Sunset
by csandste. 09/24/18 02:39 AM
Adding fuel filter- Generator built with no filter
by rubberchicken. 09/23/18 09:57 PM
Clutch Engaging too low
by Spetz. 09/23/18 09:41 PM
SMA - Krown previously, Fluid Film Application
by StevieC. 09/23/18 09:21 PM
First Paint Correction
by RayCJ. 09/23/18 08:33 PM
2011 Dodge Caliber
by dogememe. 09/23/18 07:48 PM
Mixing transmission fluids - partial change
by spk2000. 09/23/18 07:31 PM
Counterfeit MANN filter???
by IllinoisSparky. 09/23/18 06:54 PM
The smell of an oil: VME adds?
by fdcg27. 09/23/18 06:48 PM
Classic road brake pads
by buck91. 09/23/18 06:18 PM
Lilshady, SevenDu, sigpro, RayCJ, yellow97tt6spd
66055 Registered Users
74 registered members (2010Civic, ArrestMeRedZ, Al, 2009Edge, 53' Stude, AndyB, 7 invisible), 1,272 guests, and 41 spiders.
Topics290,929
Posts4,852,633
Members66,055
Most Online3,590
Jan 24th, 2017
What does ACEA A1/B1 mean? #4445691
06/30/17 07:47 AM
06/30/17 07:47 AM
Missouri
chiefsfan1 Offline OP
Missouri
I was at Wally World browsing the motor oils. I was looking at what other 5W20 oils for the Escape. I'm using the Magnatec on my first change that I have on hand.
I noticed on the Castrol EDGE 5W20 it has the A1/B1 spec plus GF-5 and the other GM and Ford specs it meets.
The Magnatec does not list the A1/B1 nor does M1 5w20.
Is the A/B1 a 'better' more stout spec?
MacBean Clan Motto: Touch Not A Catt Bot A Targe. (Don't touch this cat without a shield).
2011 Toyota Camry XLE 2.5 I4
2014 Escape SE 1.6 EcoBoost AWD
Re: What does ACEA A1/B1 mean? [Re: chiefsfan1] #4445713
06/30/17 08:13 AM
06/30/17 08:13 AM
DFW
JustN89 Offline
JustN89  Offline
DFW
The ACEA ratings are the European ratings. Someone correct me if I'm wrong, but I thought the ACEA removed A1/B1 classifications last year? According to oilspecifications.org, it was removed and if that is the case, the new full synthetic Magnatec formulation wouldn't have had the need to get the A1/B1 classification.
I do have a somewhat similar question though:
My Elantra manual states to use an oil that is API SN/GF-5 and that is "A5/B5 or higher". I don't concern myself too much with it as I look mostly at API Specs/Dexos qualifications, but I wasn't exactly sure what it means by "or higher". Would A3/B3 and A3/B4 be considered higher or lower than A5/B5?
Re: What does ACEA A1/B1 mean? [Re: chiefsfan1] #4445714
06/30/17 08:14 AM
06/30/17 08:14 AM
Kendall, FL
wemay Offline
wemay  Offline
Kendall, FL
'18 KIA Sportage LX AWD 2.4L: MSS 10w30
'13 Hyundai Santa Fe Sport 2.0T: EDGE 5w30
Re: What does ACEA A1/B1 mean? [Re: wemay] #4445726
06/30/17 08:19 AM
06/30/17 08:19 AM
Missouri
Missouri
Originally Posted By: wemay
Oh great. Thanks! It just caught my eye when I saw that on the bottle.
Re: What does ACEA A1/B1 mean? [Re: chiefsfan1] #4445727
06/30/17 08:19 AM
06/30/17 08:19 AM
Kendall, FL
wemay Offline
wemay  Offline
Kendall, FL
Dexos1 (Magnatec 5W20 meets this spec) is considered a tougher spec than SN/GF-5, here's how A1/B1 compares to Dexos1...
http://www.centerforqa.com/dexos-brand1/
Re: What does ACEA A1/B1 mean? [Re: wemay] #4445750
06/30/17 08:48 AM
06/30/17 08:48 AM
Missouri
Missouri
Thanks. Interesting.
Re: What does ACEA A1/B1 mean? [Re: chiefsfan1] #4445752
06/30/17 08:51 AM
06/30/17 08:51 AM
America's Dairyland
LotI Offline
LotI  Offline
America's Dairyland
03 Honda Interceptor
11 Kawasaki KLR 650
12 Ford E450
17 VW GTI
[IMG]http://badges.fuelly.com/images/sig-us/803455.png[/IMG]
Re: What does ACEA A1/B1 mean? [Re: LotI] #4445770
06/30/17 09:04 AM
06/30/17 09:04 AM
Missouri
Missouri
Originally Posted By: LotI
Thanks.
Re: What does ACEA A1/B1 mean? [Re: chiefsfan1] #4445844
06/30/17 10:18 AM
06/30/17 10:18 AM
Balearic Islands , Spain
FordCapriDriver Offline
A1/B1 is a fuel economy oriented spec that has been superceded by A5/B5.
A3/B4 is a high performance spec which does not focus on fuel economy at all.
1975 Ford Capri II Ghia 3000 V6, - Shell Helix HX3 20W-50 w/ 20% Rimula R4X 15W-40 HDEO.
1988 Ford Escort Mk4 Xr3i Cabrio, - Shell Rimula R4X 15W-40, w/ 30% Helix 3 20W-50.
Re: What does ACEA A1/B1 mean? [Re: FordCapriDriver] #4445946
06/30/17 12:41 PM
06/30/17 12:41 PM
Missouri
Missouri
Got it. I'm still a noob on what all the oil designations are.
It almost sounds like the A3/A4 would be better for a direct injected turbo like the 1.6
WSS-M2C945-A is Fords spec for 5w20.
Re: What does ACEA A1/B1 mean? [Re: chiefsfan1] #4445953
06/30/17 12:50 PM
06/30/17 12:50 PM
Using A3/B4 oil in an engine speccing A1/B1 , A5/B5 or A3/B3 is fine.
Now i don't think you're gonna find too many 5W-20s with a HTHS of over 3.5 ( required to meet A3/B4 )
To get a A3/B4 oil you'll need a 5W-30 at least.
Re: What does ACEA A1/B1 mean? [Re: FordCapriDriver] #4445964
06/30/17 01:14 PM
06/30/17 01:14 PM
Missouri
Missouri
None I looked at have that spec. Its still under power train warranty so I may need to keep it 5w20 for now.
Re: What does ACEA A1/B1 mean? [Re: chiefsfan1] #4445967
06/30/17 01:17 PM
06/30/17 01:17 PM
That's a good idea, i'm not saying that a 5W-30 A3/B4 oil would necessarily be a better oil than what Ford recomends, but it won't do any harm either.
Re: What does ACEA A1/B1 mean? [Re: chiefsfan1] #4446107
06/30/17 04:47 PM
06/30/17 04:47 PM
Los Angeles, California
Gokhan Offline
Gokhan  Offline
A1/B1 hasn't been superseded by A5/B5. It's a current ACEA category. Most ACEA oils are synthetic or synthetic-blend -- sort of like dexos1 and dexos2 as others pointed out.
A1/B1 is mid-SAPS, while A3/B4 and A5/B5 are high-SAPS. Many car manufactures are recommending low-SAPS (such as ACEA C1 and ACEA C4 and also ACEA C2 and ACEA C3 to some extent) for direct-injection engines, as high-SAPS oils have shown to lead to catastrophic intake-valve deposits in these engines. I don't think it's a good idea to use a high-SAPS (high-ash) oil in a direct-injection engine for that reason. It will probably void your power-train and emissions warranty as well. Stay with what is recommended.
1985 Toyota Corolla LE, 4A-LC engine, ~ 270,000 M
Toyota (TGMO) 0W-20 SN high-moly GTL (new formulation)
Mobil 1 EP M1-103 filter, 90430-12031 drain gasket
Re: What does ACEA A1/B1 mean? [Re: Gokhan] #4446150
06/30/17 06:01 PM
06/30/17 06:01 PM
West Yorkshire, UK
NGRhodes Offline
NGRhodes  Offline
West Yorkshire, UK
ACEA defines all A/B oils are high SAPS, C2/C3/C5 as mid SAPS and C1 and C4 as low SAPS.
