Detroit 51 series 2 cycle diesel
by Red91. 03/25/19 01:54 PM
Rust repair cost
by supton. 03/25/19 01:41 PM
MANNOL ATF Multivehicle
by Ether. 03/25/19 01:17 PM
Welcome to Dusseldorf... err... Edinburgh.
by Quattro Pete. 03/25/19 01:07 PM
1NZ-FE Under Valve Cover - 280,000 Miles
by kschachn. 03/25/19 12:44 PM
Coolant Leak '06 300C
by Redright9. 03/25/19 12:40 PM
New truck
by double vanos. 03/25/19 12:26 PM
What pressure washer should I buy?
by wallyuwl. 03/25/19 11:27 AM
Natural Gas from Ohio Valley
by SubLGT. 03/25/19 11:18 AM
CVT Reliability and Durability
by raffy. 03/25/19 11:00 AM
comfortable seats
by redhat. 03/25/19 10:29 AM
walmart evinrude tcw-3 clearance score
by 1978elcamino. 03/25/19 10:15 AM
Mixing SN/d1G1 with SN+/d1G2?
by doyall. 03/25/19 10:14 AM
Best 2nd Phone Number App ?
by LoneRanger. 03/25/19 09:56 AM
Crud! Wix jacking up prices again! :(
by SubieRubyRoo. 03/25/19 09:53 AM
Interior "quick detailer"
by Redright9. 03/25/19 08:21 AM
Seafoam For Last 100 Miles Before Oil Change ?
by ChrisD46. 03/25/19 07:56 AM
WIX 57151XP factory filled with synthetic oil
by Donald. 03/25/19 06:58 AM
BMW Buying Guide: Every Model, Explained
by wemay. 03/25/19 05:43 AM
Double Din Android Auto Advice
by JeffKeryk. 03/24/19 11:25 PM
sonusfaber, Rollo, Drifted, Jcar516, gregjr7
67614 Registered Users
121 registered members (555, 53' Stude, 14Accent, 1nighttrain, 4WD, 928, 12 invisible), 2,276 guests, and 63 spiders.
Topics286,403
Posts4,907,692
Members67,614
Most Online2,967
Mar 10th, 2019
Escape oil filter location #4444627
06/29/17 08:23 AM
06/29/17 08:23 AM
Missouri
chiefsfan1 Offline OP
Missouri
I'm approaching a oil change on my 1.6 EB. After crawling under it the location of the filter is interesting. What was Ford engineering thinking? Usual YT warnings in the comment section.
I will be using the MC 910S filter.
I did go buy oil filter pliers just in case Hercules put the filter on.
https://www.youtube.com/watch?v=nw_lcK4yfX0
Not as bad as replacing the battery.
MacBean Clan Motto: Touch Not A Catt Bot A Targe. (Don't touch this cat without a shield).
2011 Toyota Camry XLE 2.5 I4
2014 Escape SE 1.6 EcoBoost AWD
Re: Escape oil filter location [Re: chiefsfan1] #4444641
06/29/17 08:37 AM
06/29/17 08:37 AM
The Old North State
Sayjac Offline
Sayjac  Offline
The Old North State
Yep, the 1.6 EB Escape OF location has been posted here before at least once with similar comments. It's a dandy, or a doozy as the case may be. Don't know who did the engineering of the location, but it's steller. whistle
Re: Escape oil filter location [Re: chiefsfan1] #4444648
06/29/17 08:40 AM
06/29/17 08:40 AM
MD
AirgunSavant Offline
MD
Been through this twice this month on C-Max's
They are worse- you need ramps. Go get a Fram Ultra and run it for two OCI's
And my last new car had bad orange grommets- that was a 2017- brittle and when I unscrewed the Torx screws the insides came out of them. It may be smart to get a pack from your Ford dealer before you take this on. It's a piece of cake really but I hate under panels. They resonate noise nicely too.
The oil filter was cranked but easily removed with the right tools. I didn't like the drain plug that faces the arse end.
That was a hassle and it was backed into a bracket that required a paper thin wrench. I don't think Ford wants an oil change to be easy unless you own a lift.
Re: Escape oil filter location [Re: chiefsfan1] #4444661
06/29/17 08:49 AM
06/29/17 08:49 AM
Missouri
Missouri
Yeah, it looks like fun. If I take my time it should go OK. I will put it on ramps to give me more room. Even though I can crawl under it without them. Plus I can maneuver so when I pop the filter I wont take a bath in used oil.
That panel is a PITA! I have seen some with it removed and not replaced.
Re: Escape oil filter location [Re: AirgunSavant] #4444751
06/29/17 09:47 AM
06/29/17 09:47 AM
MN
oil_film_movies Online content
oil_film_movies  Online Content
MN
C Max's is easy, it sticks staight down, underneath, easy to reach:
The 1.6L Ecoboost is sticking out sideways deep inside the bay, so I can see how its considered tough:
Re: Escape oil filter location [Re: chiefsfan1] #4444797
06/29/17 10:39 AM
06/29/17 10:39 AM
Baltimore, Maryland, USA
zzyzzx Online sleepy
zzyzzx  Online Sleepy
That oil filter location is almost like it is on a Ford Escort.
Re: Escape oil filter location [Re: chiefsfan1] #4444808
06/29/17 10:53 AM
06/29/17 10:53 AM
Central NY
Miller88 Offline
Miller88  Offline
Central NY
Looks like the 1.6 also has an oil-to-water cooler filter housing - those things are incredibly frustrating to deal with
18 Forester 2.5I 6M
00 Jeep XJ
01 F-350 4x4 5M
Re: Escape oil filter location [Re: chiefsfan1] #4444858
06/29/17 11:42 AM
06/29/17 11:42 AM
N.H, U.S.A.
ARCOgraphite Offline
N.H, U.S.A.
Piece of cake smile I don't like oil dripping on the hoses though. maybe mod a foil drip pan there.
I had a Mazda Protege' that really had an impossible oil filter location. It was just under the intake rams horn which was against the firewall, but then steering components and AC high side plumbing was under it!
It was here where I purchased my first, app specific, filter CAP-style wrench.
2019 VW Jetta S,6M OCI#0 2103mi-Castrol Edge Prof? VW508+OE Filter; '17 Subaru Crosstrek CVT OC#6 43467mi-Valvoline Adv 0w20 + SOA Filter
Re: Escape oil filter location [Re: chiefsfan1] #4444908
06/29/17 12:22 PM
06/29/17 12:22 PM
The Old North State
Sayjac Offline
Sayjac  Offline
The Old North State
Here's another yt of the topic filter location and a link to the 2013 thread where it was posted. My comments about it there stand. https://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=3058337&page=all
Re: Escape oil filter location [Re: zzyzzx] #4444910
06/29/17 12:27 PM
06/29/17 12:27 PM
Canada
Lolvoguy Online shocked
Lolvoguy  Online Shocked
Canada
Agreed. My 97 Escort was in a similar location but without all the hoses around it.
It was also accessible from the top OR the bottom.
06 Lexus IS350- Wife
88 BMW 325is- Mistress
Say "no" to Turbo!
Re: Escape oil filter location [Re: Sayjac] #4444930
06/29/17 12:47 PM
06/29/17 12:47 PM
MN
MN
Saw some of the video. Yes, change oil filter every OTHER oil change on this bad boy, using a double-life Fram Ultra. Plenty of capacity.
Re: Escape oil filter location [Re: oil_film_movies] #4444961
06/29/17 01:08 PM
06/29/17 01:08 PM
The Old North State
Sayjac Offline
Sayjac  Offline
The Old North State
^^^ I don't disagree, perfect application for FU every other oil change fci application. Depending on total oci, some other silicone adbv filters could work too. One caveat consideration would be if the vehicle still under vehicle warranty.
The latter video imo, shows what a pita location the filter is in. And that guy had a nice lift for the job too.
Re: Escape oil filter location [Re: chiefsfan1] #4444984
06/29/17 01:31 PM
06/29/17 01:31 PM
Missouri
Missouri
Yeah, looks like fun. I'm tempted to take it to Ford for a change and see if they change the filter.
It has a Napa ProSelect on it.
Re: Escape oil filter location [Re: Lolvoguy] #4445575
06/30/17 12:35 AM
06/30/17 12:35 AM
CBUS OH
BironDanmum Offline
BironDanmum  Offline
CBUS OH
I've only got experience with the Zetec Escorts, but they seem to be in a similar spot. A lot of people complain about the location on Zetecs but I've never personally had any real issues.
My 1983 Cavalier however, required removing the passenger side tire and dismantling most of the plastic wheel-well guards to get to it. That was one vehicle I was happy to take to a quick lube place.
Re: Escape oil filter location [Re: chiefsfan1] #4445731
06/30/17 08:26 AM
06/30/17 08:26 AM
Houston, Texas
WellOiled Offline
WellOiled  Offline
Houston, Texas
This one looks to be slightly more difficult than the 2002 Grand Marquis. I would not let this stop me from changing the filter.
2004 Ford Ranger 4.0L V6
Valvoline Advanced Full Synthetic HM 5W30 + WIX 51372
