Michelin jack won't lift a load
by 10WSmuckers. 09/23/18 01:32 AM
Synthetic for a 30 year old engine?
by geissjr. 09/23/18 01:02 AM
Phone Books
by csandste. 09/23/18 12:11 AM
Inside the Fuel Tank / EVAP system
by StevieC. 09/22/18 10:31 PM
Toyota Pink + RMI-25 10 years
by burla. 09/22/18 10:27 PM
Cartridge filter?
by Camprunner. 09/22/18 10:23 PM
Should have changed it?
by parshisa. 09/22/18 10:14 PM
Meijer QSUD Full Syn 10w30 $8.11 5qt jug
by Spartanfool. 09/22/18 08:40 PM
Whats in your beef burger
by CourierDriver. 09/22/18 08:28 PM
Headlight brightness fluctuates on 1987 Golf
by vavavroom. 09/22/18 07:56 PM
"New" Beater
by SilverGt. 09/22/18 07:22 PM
Eschewing computer controls
by buck91. 09/22/18 06:41 PM
Leak/drip left front 13 Ram 4x4?
by irv. 09/22/18 06:22 PM
5w20 oil choices
by 53' Stude. 09/22/18 06:05 PM
site security
by RF Overlord. 09/22/18 06:02 PM
Richmond Raceway
by Warstud. 09/22/18 06:01 PM
Redline D6 ATF substituting for Toyota WS
by Patrick0525. 09/22/18 05:29 PM
XG3614 Cut Open 13,400kms (8,375mi)
by mcwilly. 09/22/18 05:25 PM
Torn Purolators: they DO TEAR!
by 53' Stude. 09/22/18 05:07 PM
HondaTech250, SandCruzer, sbgti96, cosmoblau, Sarrge
66044 Registered Users
17 registered members (dogememe, carviewsonic, BlakeB, dishdude, ArrestMeRedZ, 5 invisible), 723 guests, and 45 spiders.
Topics290,867
Posts4,851,576
Members66,044
Most Online3,590
Jan 24th, 2017
Question on 30wt oils #4444494
06/29/17 02:16 AM
06/29/17 02:16 AM
Western usa
Ammofirst Offline OP
Western usa
I've been looking at options for our 2014 Buick Regal turbo. I do like the characteristics of the oils rated A3. We've had good luck With PP 10w-30 year round. (Took a 2007 Saturn aura with the infamous 3.6L v6 to 164k no issues) I'm just thinking it might be a little thin for this car : gm 2.0T LTG : I believe. Possibly : Mobil 1 10w-30HM ? Are there any other options for a 30wt oil with a HTHS of 3.5 > Thanks
Re: Question on 30wt oils [Re: Ammofirst] #4444508
06/29/17 03:36 AM
06/29/17 03:36 AM
Down Under
SR5 Offline
SR5  Offline
Down Under
You can get things like Castrol Edge 0W-30 or 5W-30 A3/B4 and Pennzoil Platinum Euro 5W-30 that are rated A3, but they may be a little hard to find.
Consider 0W-40 in the form of Castrol Edge or M1 as they are both A3/B4 oils and have a HTHS around 3.6 cP, same with PP Euro 5W-40.
The thick Euro 30's are very close to the thin Euro 40's, as long as they are A3 rated you will be fine.
You could also look at a dual rated HDEO in 10W-30 flavour, as they all have a HTHS of 3.5 cP or more. (API CK-4)
Don't forget the mid-SAPS version of ACEA A3 is ACEA C3 so you could consider oils like M1 5W30 ESP which is a C3 oil with a HTHS of 3.5 cP and a SAPS level of 0.8% (same as many Dexos1 oils). Valvoline SynPower MST in 5W30 or 5W40 are both C3 and would work nicely too. You can get PP Euro L as a C3 oil too.
Lots of choice out there.
Penrite Vantage 10W40 SN & A3/B4 + Wesfil-Cooper Z154
Re: Question on 30wt oils [Re: Ammofirst] #4444519
06/29/17 04:57 AM
06/29/17 04:57 AM
Regina, Saskatchewan, Canada
Garak Offline
Garak  Offline
When you can find it, Shell Rotella Multi-Vehicle 5w-30 would be another option. Of course, it's neither dexos1 nor GF-5 if you're under warranty and that happens to be a concern to you.
Plain, simple Garak.
2008 Infiniti G37 - Shell ROTELLA T6 Multi-Vehicle 5w-30, NAPA Gold 7356
Re: Question on 30wt oils [Re: Ammofirst] #4444557
06/29/17 06:29 AM
06/29/17 06:29 AM
Alabama, United States
Red91 Offline
Red91  Offline
Any SAE 30. Yes, I said it. There is no reason why a modern conventional 30wt wouldn't be suitable for a di and turbocharged modern car engine. They are easily capable of the same OCI as synthetic.
'89 Chevy 1500
Supertech 20/50
'15 Chevy Cruze
AcDelco syn dexos 5/30
Re: Question on 30wt oils [Re: Ammofirst] #4444577
06/29/17 07:15 AM
06/29/17 07:15 AM
Western usa
Western usa
I've noticed the euro 5w-30's do meet a3/b4 I just don't see them at Wally World. They typically end up being about double in price. I guess the Mobil 1 10w-30HM is fine but I lose the dexos cert. for warranty. Thanks for the heads up on ACEA C3. If I go with a mid saps option how much should I dial back the OCI? Was considering 10k on full SAPS. Did I read somewhere about these mid saps oils offering less deposits ?
Re: Question on 30wt oils [Re: Ammofirst] #4444613
06/29/17 08:15 AM
06/29/17 08:15 AM
Austin, Texas
Brons2 Offline
Brons2  Offline
Austin, Texas
The Pennzoil Platinum Euro L 5w30 is available at 4 out of the 5 Walmarts near me. Maybe check the Walmart website for a location near you?
2012 Hyundai Sonata GLS 6MT 2.4GDI, ProDS 10w30, XG9688 filter, 2018 Mitsubishi Outlander SEL 2.4 CVT, Factory fill still.
Re: Question on 30wt oils [Re: Ammofirst] #4444778
06/29/17 10:15 AM
06/29/17 10:15 AM
Kalifornia Kollective
BrocLuno Offline
BrocLuno  Offline
Well, western USA does not really tell us where you are. In LA you could run SAE 30 HD year round. In the Cascades or Yreka or Susanville, prolly not ...
Climate has to do with winter rate (xW) needed. As far as the running viscosity (at op temp), either a stout 30 or a thin 40- would be good smile
Re: Question on 30wt oils [Re: Ammofirst] #4445230
06/29/17 06:02 PM
06/29/17 06:02 PM
Down Under
SR5 Offline
SR5  Offline
Down Under
Yes M1 10W-30 HM is a great oil, I would happily use it. But you will never find an oil that is both A3 and Dexos1, as the Dexos1 oil is low HTHS resource conserving ( about 2.9 to 3.2 cP) while the A3 oil is high HTHS (about 3.5 to 3.6 cP). Also 10W30 is not a Dexos grade, the only 30 grade is 5W30 under dexos. I sure wish they did allow 10W30, it's a great shear stable and low volatility oil grade, but not suitable for very cold climates, and I suspect GM want Dexos oils to be suitable for most expected climates.
If you want a high HTHS Dexos oil, then you should get a Dexos2 oil, as this is close to a ACEA C3 oil by another name. It's not just for diesels, but also petrol/gas engines under high stress or race conditions.
Here is a link to the Valvoline SynPower oil data sheet (Here)
You can see the American ILSAC / Dexos1 oils have a SAPS / SA level of 0.93 %, and for another data point regular M1 5W30 has a SAPS / Sulphated Ash of 0.8 %. This is your regular SAPS level.
Now the Euro A3 oils are true high SAPS oils, with SA of about 1.2 %, for Euro long-life ratings, often used for 20k miles or 2 years in Europe. But the mid-SAPS C3 oils have a SA of 0.78 %, basically 0.8% or a touch under. But this is the same as regular M1 5W30.
In my opinion, anybody using a ILSAC GF-5 or Dexos1 oil, is already using a mid-SAPS oil due to the limits imposed by ILSAC and Dexos. Going to a C3 oil shouldn't make much difference. If you use a Dexos2 C3 oil, you should be able to follow your GM OLM. If you are still concerned change at 20% or 7500 miles.
Re: Question on 30wt oils [Re: BrocLuno] #4445238
06/29/17 06:13 PM
06/29/17 06:13 PM
Western usa
Western usa
I'm located in Central Colorado (boonieville) about 6400 ft elev. temps smilar to Colo. Springs.
Re: Question on 30wt oils [Re: Ammofirst] #4445266
06/29/17 06:52 PM
06/29/17 06:52 PM
Down Under
SR5 Offline
SR5  Offline
Down Under
Here is a link to a UOA (used oil analysis) from a 2013 Chevy Camaro (6.2L LS3) that was tracked on Pennzoil Platinum 5w-30 Euro L (ACEA C3, Dexos2).
https://bobistheoilguy.com/forums/ubbthreads.php/topics/4444127/
It held up fine.
Re: Question on 30wt oils [Re: SR5] #4445287
06/29/17 07:15 PM
06/29/17 07:15 PM
Western usa
Western usa
Thanks very informative. Does Pennzoil consider this a low saps oil. http://mxtradings.com/Pennzoil/PU5w30EuroL.pdf
Re: Question on 30wt oils [Re: Ammofirst] #4445299
06/29/17 07:31 PM
06/29/17 07:31 PM
Down Under
SR5 Offline
SR5  Offline
Down Under
That is the old spec sheet, and yes that looks low SAPS to me (C2, VW 504/507. Porsche C30).
But this is the new spec sheet (here)
And to be honest, I can't quite tell it's SAPS level because it doesn't give much data, but my best guess is a mid-SAPS oil (C3, Dexos2).
Re: Question on 30wt oils [Re: Ammofirst] #4445305
06/29/17 07:42 PM
06/29/17 07:42 PM
Down Under
SR5 Offline
SR5  Offline
Down Under
The big thing is you have a GM car. If you want to step your oil up a level run a Dexos2 oil.
Here in Oz, GM-Australia think the little Cruze with the 1.4 L iTi Turbo Petrol (Gas) engine is very stressful on oil, so they say to run a Dexos2 oil (not a Dexos1 oil). In fact from what I can tell, you void your warranty in Australia if you use Dexos1 in your 1.4 iTi engine. I directly asked and was told that Dexos1 was not approved here.
Dexos1 and Dexos2 have pretty much the same SAPS levels from all the examples I have seen. Just the Dexos2 has higher HTHS and I've only ever seen it as a full synthetic.
Re: Question on 30wt oils [Re: Red91] #4445353
06/29/17 08:29 PM
06/29/17 08:29 PM
North Carolina
4ever4d Offline
4ever4d  Offline
North Carolina
thumbsup thumbsup thumbsup
04 Chevy Colorado 3.5 I5 5w-30 OEF
07 Honda Element 2.4 I4 5w-20 OEM
10 Nissan Rogue AWD 2.5 I4 5w-30 OEF
Amsoil Products & Fram or Wix Filters
Re: Question on 30wt oils [Re: SR5] #4445513
06/29/17 11:11 PM
06/29/17 11:11 PM
Western usa
Western usa
You have got the exact info I was looking for, appreciate it. It's funny you mention the Cruze. (Is that your car?) I'm in a 2017 Cruze 1.4T rental and I'm shocked how much I like this car. It's NOTHING like a compact gm car from 10 years ago. Ride / handling / engine / interior It's very nice thu-out. Does the Acea C3 spec have a 3.5 min. HTHS ?
