Anyone "Wim Hof"ing ?
by Shannow. 09/21/18 02:35 AM
New R1250GS and R1250RT
by 02SE. 09/21/18 12:55 AM
Inside Break Booster & Master Cylinder
by StevieC. 09/20/18 11:22 PM
Inside an Alternator
by StevieC. 09/20/18 11:18 PM
What vehicles are you using Maxlife ATF in?
by BlakeB. 09/20/18 11:10 PM
How a Power Steering Rack Works (Electronic)
by StevieC. 09/20/18 11:00 PM
How a Power Steering Rack Works (Hydraulic)
by StevieC. 09/20/18 10:58 PM
silly wiper problem
by bowlofturtle. 09/20/18 10:33 PM
Canadian Tire Shell Rotella T-6 in Pails
by Snagglefoot. 09/20/18 10:04 PM
Best diesel fuel for cold weather?
by Dickm. 09/20/18 10:03 PM
Type 1 Diabetics - New Research
by StevieC. 09/20/18 10:00 PM
Tire Sizing and Options
by NewEnglander. 09/20/18 09:59 PM
2013 Scion FR-S | Transmission Fluid Questions
by nicknak. 09/20/18 09:47 PM
Meguiar's Liquid Cleaner Wax $5 WalMart, Amazon
by The_Cams. 09/20/18 08:42 PM
Winter oil recommendation
by Neptune. 09/20/18 08:27 PM
M1 0W-40
by CT8. 09/20/18 07:37 PM
What controls timing on my 08 Honda?
by Roland. 09/20/18 07:23 PM
The real culprit about 18k
by Ablebody. 09/20/18 06:04 PM
Direct_Rejection, donatom, Sylent_Snyper, Ajizzle, nicknak
66033 Registered Users
23 registered members (Bailes1992, BlakeB, Billbert, Bman90, 2015Corolla, bmod305, 1 invisible), 727 guests, and 37 spiders.
Topics290,745
Posts4,849,458
Members66,033
Most Online3,590
Jan 24th, 2017
MPG after switched to new Mobil1 FS 0w40 #4444360
06/28/17 09:36 PM
06/28/17 09:36 PM
California
Eugene_Von Offline OP
California
anyone feel MPG is better then before? Does FS mean "fuel saving"? Then is a super saving!
I use idemitsu 5w30 before.
Re: MPG after switched to new Mobil1 FS 0w40 [Re: Eugene_Von] #4444383
06/28/17 10:08 PM
06/28/17 10:08 PM
NY
demarpaint Offline
demarpaint  Offline
NY
My mpgs are up .3 mpg according to my EVIC. No change to anything other than warmer weather. We've been on summer blend gas for a while now.
God Bless Our Troops
Re: MPG after switched to new Mobil1 FS 0w40 [Re: Eugene_Von] #4444398
06/28/17 10:19 PM
06/28/17 10:19 PM
S California
OneEyeJack Offline
OneEyeJack  Offline
S California
No 2 loads of gasoline from the tank farm are exactly alike and with changing weather, traffic and our driving making a mileage judgement is not much more than an accurate guess.
Re: MPG after switched to new Mobil1 FS 0w40 [Re: Eugene_Von] #4444406
06/28/17 10:26 PM
06/28/17 10:26 PM
MN
oil_film_movies Offline
MN
FS means Full SAPS, I think. (Or Full Synthetic maybe.)
The 0w40 is thicker than your SN GF-5 5w30. Thicker oil creates more engine friction viscous drag.
More drag means you have to burn more gas to turn the engine. Physics is cruel man.
Re: MPG after switched to new Mobil1 FS 0w40 [Re: Eugene_Von] #4444432
06/28/17 11:04 PM
06/28/17 11:04 PM
Connecticut
69GTX Offline
69GTX  Offline
Connecticut
I switched from M1 5w-30 to the M1 0w-40 old version last year. That's even thicker than the new FS stuff. Can't say I've seen any change in MPG since the switch. From winter to summer up north here, air density varies from 10-14%. That should be a change you should notice with other variables fairly constant.
2001 Lincoln Cont 4.6L DOHC/ 39K mi / QS HM 5w30 / FUG XG2
1969 Ply GTX/RRs
Re: MPG after switched to new Mobil1 FS 0w40 [Re: oil_film_movies] #4444451
06/28/17 11:44 PM
06/28/17 11:44 PM
California
California
fs 0w40 is not that thick
Re: MPG after switched to new Mobil1 FS 0w40 [Re: Eugene_Von] #4444707
06/29/17 09:22 AM
06/29/17 09:22 AM
Idaho
CT8 Offline
CT8  Offline
Idaho
3 mpg better and the air pressure on all 4 tires hasn't changed. grin
2015 Ford F150 2.7
2018 Ford F350 6.2
