Which Performance Filter?
by rooflessVW. 09/25/18 03:33 PM
Optimal Compression Ratio for 91 Octane Fuel
by NICAT. 09/25/18 02:01 PM
Anyone used Amsoil DZF 0w40 ?
by ofelas. 09/25/18 01:33 PM
No more Turo - What now?
by dogememe. 09/25/18 01:08 PM
Military small arms ammo
by Camprunner. 09/25/18 12:03 PM
Pennzoil must not be selling , OR ?
by Kjmack. 09/25/18 11:51 AM
New black car, light swirls and water spots
by Redright9. 09/25/18 11:37 AM
Rust Belt vs Sun Belt cars
by ZZman. 09/25/18 11:33 AM
Enginer rebuilder's view of GDI intake issues
by Brigadier. 09/25/18 11:09 AM
Oil for '84 Caddy w/HT-4100
by StillLearning. 09/25/18 10:41 AM
Interesting video of diff with clear cover
by mrdctaylor. 09/25/18 10:15 AM
The death of American footbal
by Brigadier. 09/25/18 10:01 AM
Tire leaking from bead/rim
by Brybo86. 09/25/18 09:39 AM
2000 4Runner 3.4L
by ka9mnx. 09/25/18 08:59 AM
VW 508 Spec 0w20 Updates?
by Zee09. 09/25/18 08:36 AM
Laptop Recommendations
by buster. 09/25/18 08:24 AM
Mac OSX Mojave - vid card requirements
by OVERKILL. 09/25/18 08:05 AM
Peppz, Jfa02, ibsfusion, Fearcat707, Perseo
66069 Registered Users
99 registered members (92saturnsl2, 853okg, 2whlgeezer, 28oz, 53' Stude, 11 invisible), 1,543 guests, and 38 spiders.
Topics290,996
Posts4,854,065
Members66,069
Most Online3,590
Jan 24th, 2017
Red Line 10W-30, 1992 Acura NSX, 3 months #4444331
06/28/17 09:10 PM
06/28/17 09:10 PM
TX
robertcope Offline OP
TX
This comes out of my 1992 Acura NSX. Motor has about 110K miles on it and doesn't use a bit of oil.
This oil has about three months on it and about seven track days. The engine got hot a few times: one day on track a coolant line blew, I drove it about half a lap, slowly, before I figured out what happened; the next attempt to get on track, the radiator failed, it took about a lap to figure out what was going on, also light load. Motor seems fine despite the incidents.
Oxidation looks bad. I will dump the oil and refill. I'm also going to send Polaris some virgin oil at their request.
Re: Red Line 10W-30, 1992 Acura NSX, 3 months [Re: robertcope] #4444351
06/28/17 09:30 PM
06/28/17 09:30 PM
WI.
dblshock Offline
dblshock  Offline
WI.
look like a good oil, probably saved the engine from worse after the two incidents.
16 Civic Coupe Touring 33k
640:1 TCW-3 E091
Edge 0/40 XG7317
Firehawk Indy 500
06 4Runner SR5 141k
640:1 TCW-3
PP 5/30 XG3614
Falken Wildpeak AT3W
Re: Red Line 10W-30, 1992 Acura NSX, 3 months [Re: dblshock] #4444355
06/28/17 09:33 PM
06/28/17 09:33 PM
TX
TX
I've been wondering the same thing, honestly.
Also, I found a VOA of Red Line and the oxidation number was like 105, so I think that's just an artifact of the ester oil.
Re: Red Line 10W-30, 1992 Acura NSX, 3 months [Re: robertcope] #4444375
06/28/17 09:53 PM
06/28/17 09:53 PM
Malaysia
zeng Offline
zeng  Offline
Malaysia
+1
I wouldn't be concerned about oxdn number in this case.
Re: Red Line 10W-30, 1992 Acura NSX, 3 months [Re: robertcope] #4444857
06/29/17 11:42 AM
06/29/17 11:42 AM
down in the park
Jetronic Offline
Jetronic  Offline
down in the park
You'll always get such an oxidation result from Ester based oil. Even fresh oil will show that.
AR Giulietta 2.0 JTDM-2 -- Total Quartz 9000 Energy 0w30
Hankook Ventus Prime 2 215/50R17 (front)
Pirelli P7 Cinturato 225/45R17 (rear)
Re: Red Line 10W-30, 1992 Acura NSX, 3 months [Re: robertcope] #4444860
06/29/17 11:43 AM
06/29/17 11:43 AM
down in the park
Jetronic Offline
Jetronic  Offline
down in the park
I should have read on before replying...
Re: Red Line 10W-30, 1992 Acura NSX, 3 months [Re: robertcope] #4444880
06/29/17 11:53 AM
06/29/17 11:53 AM
TX
TX
FWIW, I'm not so sure I'm dumping and refilling at this point. Unclear how to really make that determination.
Re: Red Line 10W-30, 1992 Acura NSX, 3 months [Re: robertcope] #4445082
06/29/17 03:13 PM
06/29/17 03:13 PM
Oregon
1JZ_E46 Offline
1JZ_E46  Offline
Oregon
With 7 track days I would say its time. Sure you could keep it in there longer, but oil is cheap, bearing replacements aren't.
2007 X5 4.8i: M1 HM 10W-30
2016 Countryman S: EDGE 0W-30
Re: Red Line 10W-30, 1992 Acura NSX, 3 months [Re: 1JZ_E46] #4445088
06/29/17 03:22 PM
06/29/17 03:22 PM
TX
TX
What part of the UOA leads you to this conclusion? Or is this an emotional rather than data driven comment? I'm not saying you're wrong or that it'd hurt, in fact that is kind of my gut reaction, well.
Re: Red Line 10W-30, 1992 Acura NSX, 3 months [Re: robertcope] #4445098
06/29/17 03:34 PM
06/29/17 03:34 PM
Oregon
1JZ_E46 Offline
1JZ_E46  Offline
Oregon
Nothing in the report. Just personal preference. I'm sure the oil is oxidized after running so hot for 7 days. Does the NSX have an oil cooler?
Re: Red Line 10W-30, 1992 Acura NSX, 3 months [Re: 1JZ_E46] #4445156
06/29/17 04:34 PM
06/29/17 04:34 PM
TX
TX
Fair enough. My thought process is that this is the first run of Red Line, so I'd like to get a "clean" run going as soon as possible. Also, the engine did see some strange events (two coolant losses) and probably got abnormally warm because of it. I need to send in a virgin sample so that we can see oxidation levels.
The stock NSX oil cooler is a typical water-oil cooler. Temps on track on a hot day are around 270F, nothing crazy.
Re: Red Line 10W-30, 1992 Acura NSX, 3 months [Re: robertcope] #4445286
06/29/17 07:14 PM
06/29/17 07:14 PM
South OZ
KL31 Offline
KL31  Offline
South OZ
Well if oxidation is indeed a result of the ester based oil then nothing looks out of whack. Plenty of tbn left.
95 MX-3 2.5L|Shell Helix Ultra 5W40|Wix 51356
04 Focus 1.8L|Wesfil Cooper WZ63|Valvoline MST 5W30
05 Kluger 3.3L|Wesfil Cooper WZ418|Magnatec 10W30 Semi Syn
Re: Red Line 10W-30, 1992 Acura NSX, 3 months [Re: KL31] #4445306
06/29/17 07:42 PM
06/29/17 07:42 PM
TX
TX
Here's a VOA from Polaris labs with oxidation at 109: https://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=2635056
And another: https://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=3072806
And Polaris' own notes for "Oxidation" say; "Ester-based lubricants will show high oxidation values."
I'll send my oil in for a VOA just for grins, but yeah, I think it is normal.
Re: Red Line 10W-30, 1992 Acura NSX, 3 months [Re: robertcope] #4452646
07/07/17 07:17 PM
07/07/17 07:17 PM
TX
TX
Had a VOA done: https://bobistheoilguy.com/forums/ubbthreads.php/topics/4452642/Red_Line_10W-30
Worth noting that this was the first fill of Red Line; it had Mobil 1 0W-40 in it previously.
Re: Red Line 10W-30, 1992 Acura NSX, 3 months [Re: robertcope] #4452683
07/07/17 07:56 PM
07/07/17 07:56 PM
Oregon
1JZ_E46 Offline
1JZ_E46  Offline
Oregon
Looks like the oxidation is nothing to worry about then. Magnesium must have come from the M1?
