Redline releases Professional Series
by Marco620. 03/20/19 11:52 PM
M1 HM 10w-30 vs M1 FS 0w-40
by RDY4WAR. 03/20/19 10:04 PM
Need Recommendations For A New SUV
by Dwight_Frye. 03/20/19 08:50 PM
GE dishwasher clicking
by silverrat. 03/20/19 08:20 PM
Every 6 months or one year OCI
by asker123. 03/20/19 07:36 PM
Valu Home Ctr. Peak Oil $9.94/5 qt jugs
by Nickdfresh. 03/20/19 07:32 PM
Chemical fire in texas
by Fitter30. 03/20/19 07:09 PM
PZ 37 CUT OPEN
by 53' Stude. 03/20/19 06:42 PM
Lube Intervals
by NibbanaBanana. 03/20/19 06:41 PM
When to send in oil for testing?
by SnowDrifter. 03/20/19 06:12 PM
ATF vs CHF
by GG16v. 03/20/19 05:40 PM
Landline Answering Machines
by das_peikko. 03/20/19 05:10 PM
Mobil oil on “clearance” at Target
by WiskyBadger. 03/20/19 04:04 PM
Master Mechanic Motor Oil @ True Value
by CG_BrianM. 03/20/19 01:35 PM
Some cars haven't changed much in 30 years...
by addyguy. 03/20/19 01:16 PM
Super Knock - Engineering Explained
by StevieC. 03/20/19 01:11 PM
Mobil Super Synthetic Clearance at Meijer
by Tjbouwhu. 03/20/19 12:53 PM
DarkFrontier, Zuraxus, Burks21, GG16v, fleetwood62
67572 Registered Users
35 registered members (Brad_C, Black_Thunder, carlprop, bbhero, Ag76, 3 invisible), 878 guests, and 59 spiders.
Topics286,170
Posts4,903,521
Members67,572
Most Online2,967
Mar 10th, 2019
CBU from 100% gas vs Ethanol in GDI application #4443740
06/28/17 11:28 AM
06/28/17 11:28 AM
Mississippi
Speak2Mountain Offline OP
Mississippi
Would it seem to be better?
Worse?
Or prolly about the same
Re: CBU from 100% gas vs Ethanol in GDI application [Re: Speak2Mountain] #4443913
06/28/17 01:34 PM
06/28/17 01:34 PM
NE,Ohio
Rand Offline
Rand  Offline
NE,Ohio
What is CBU that's not a common abbreviation.
Re: CBU from 100% gas vs Ethanol in GDI application [Re: Rand] #4443953
06/28/17 02:06 PM
06/28/17 02:06 PM
Mississippi
Mississippi
My bad. Carbon buildup
Re: CBU from 100% gas vs Ethanol in GDI application [Re: Speak2Mountain] #4443955
06/28/17 02:10 PM
06/28/17 02:10 PM
Canyon County Idaho
CT8 Offline
CT8  Offline
Canyon County Idaho
Why would you ask?
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: CBU from 100% gas vs Ethanol in GDI application [Re: CT8] #4444027
06/28/17 03:28 PM
06/28/17 03:28 PM
Mississippi
Mississippi
I've gotta a GDI engine and have access to 100% gasoline (93 octane), just wondering if it MIGHT prevent carbon in an engine known for some really bad buildup
Re: CBU from 100% gas vs Ethanol in GDI application [Re: Speak2Mountain] #4444045
06/28/17 03:45 PM
06/28/17 03:45 PM
Lima, Ohio, USA
earlyre Offline
earlyre  Offline
Lima, Ohio, USA
now I'm no scientist/engineer/mechanic, but to my understanding, the FUEL isn't the problem with DI carbon buildup, it's where the fuel is delivered.
with port, or even tbi, the fuel "washes" the backside of the valves.
if it's really bad, you'd be better off figuring out how to add a single injector after the throttle body...
you'll notice some manufacturers, while never acknowledging there was a carbon problem, have redesigned the next generation of those engines with both port and direct injection...
Mine:
13 Ford C-MAX hybrid: MC 5w20, & FL910s (in theory)
Re: CBU from 100% gas vs Ethanol in GDI application [Re: Speak2Mountain] #4444061
06/28/17 03:54 PM
06/28/17 03:54 PM
Sunny Florida
SteveSRT8 Offline
SteveSRT8  Offline
Sunny Florida
At least two large ones have said that the combined systems are for part throttle cylinder filling issues, evidently some issues with this with DI.
It should also be noted that many many DI owners never have any significant issues from some makes and models. I am not certain this is all engineering expertise but it may be a driver thing.
No one could use a single injector at the throttle body unless they completely redesign the intake to avoid cylinder to cylinder distribution issues.
"In a democracy, dissent is an act of faith."
J. William Fulbright
Best ET-12.79 @ 111 mph
4340 pounds, Street tires
Just like we go to Publix
Re: CBU from 100% gas vs Ethanol in GDI application [Re: Speak2Mountain] #4444252
06/28/17 08:02 PM
06/28/17 08:02 PM
Florida, Cape Coral
Eddie Offline
Eddie  Offline
Florida, Cape Coral
Mazda Skyactv engines seems to have solved the issue by designing a nice oil vapor separator in the PCV system. Mazda also found that running the intake valves at a higher temperature helped. My old Mazda CX7 with DI was doing great when I sold it at ~ 80,000 miles with their "OLD" PCV system. Ed
CX5 Touring 2.5L :-)
Re: CBU from 100% gas vs Ethanol in GDI application [Re: SteveSRT8] #4444588
06/29/17 07:37 AM
06/29/17 07:37 AM
Middle of Iowa
DriveHard Offline
DriveHard  Offline
Middle of Iowa
Huh? Throttle body injection was huge in the 90's...and you can still buy throttle body injection kits for use on SBC's today. I think it would be quite simple to integrate a single injector in these DI systems for part throttle operation and reduced carbon build up.
Smile, it increases your face value
2013 Fiat 500 Abarth mod heavy (my DD)
2018 Alfa Romeo Stelvio TI Sport (wife's)
2011 Silverado Crew Cab LT 6.2L/6spd (tow pig)
2007 Nissan Xterra (trail toy)
Re: CBU from 100% gas vs Ethanol in GDI application [Re: DriveHard] #4444693
06/29/17 09:14 AM
06/29/17 09:14 AM
Sunny Florida
SteveSRT8 Offline
SteveSRT8  Offline
Sunny Florida
Ever since port injection the manifolds are designed for air only. If you examine most manifolds that move fuel and air (carburetor/TB) they are heated and radically different than modern ones for FI. So you cannot just mount an injector behind the TB without redoing the manifold design first.
Re: CBU from 100% gas vs Ethanol in GDI application [Re: Eddie] #4444696
06/29/17 09:15 AM
06/29/17 09:15 AM
Sunny Florida
SteveSRT8 Offline
SteveSRT8  Offline
Sunny Florida
yep, some mfgrs obviously have it figured out. I still think driving style plays a huge part as well, evidenced by the advice to drive them at high rpm for a period to clean the intake valves. Some of us do that every time we drive them!
Re: CBU from 100% gas vs Ethanol in GDI application [Re: Speak2Mountain] #4445068
06/29/17 02:58 PM
06/29/17 02:58 PM
Toronto
PeterPolyol Offline
PeterPolyol  Offline
Toronto
Doubt it will make a lick of difference bud.
There's no replacement...'scosity for natural viscosity
