Looking at a cheap commuter!
by ryan2022. 09/21/18 09:46 AM
Does Your 3.5EB Make Oil
by Gene K. 09/21/18 09:07 AM
F150 Front Differential
by hatt. 09/21/18 08:45 AM
EU version of Subaru 2.5 FB engine
by IMPALA08. 09/21/18 08:40 AM
New “rules” changing your choice of car?
by daves87rs. 09/21/18 06:04 AM
WIX51334XP Oil Filters
by CB900F2. 09/21/18 05:14 AM
Signal Oil Company radio advertising
by 21Rouge. 09/21/18 04:07 AM
Anyone "Wim Hof"ing ?
by Shannow. 09/21/18 02:35 AM
New R1250GS and R1250RT
by 02SE. 09/21/18 12:55 AM
Inside Break Booster & Master Cylinder
by StevieC. 09/20/18 11:22 PM
Inside an Alternator
by StevieC. 09/20/18 11:18 PM
What vehicles are you using Maxlife ATF in?
by BlakeB. 09/20/18 11:10 PM
How a Power Steering Rack Works (Electronic)
by StevieC. 09/20/18 11:00 PM
How a Power Steering Rack Works (Hydraulic)
by StevieC. 09/20/18 10:58 PM
silly wiper problem
by bowlofturtle. 09/20/18 10:33 PM
Canadian Tire Shell Rotella T-6 in Pails
by Snagglefoot. 09/20/18 10:04 PM
Best diesel fuel for cold weather?
by Dickm. 09/20/18 10:03 PM
Type 1 Diabetics - New Research
by StevieC. 09/20/18 10:00 PM
Tire Sizing and Options
by NewEnglander. 09/20/18 09:59 PM
2013 Scion FR-S | Transmission Fluid Questions
by nicknak. 09/20/18 09:47 PM
ScottRousell, Direct_Rejection, donatom, Sylent_Snyper, Ajizzle
66034 Registered Users
80 registered members (Auae85, Astro14, advocate, BlakeB, Ag76, 7 invisible), 1,635 guests, and 34 spiders.
Topics290,754
Posts4,849,683
Members66,034
Most Online3,590
Jan 24th, 2017
Chevron Delo 400 LE vs 400 SDE #4443597
06/28/17 09:36 AM
06/28/17 09:36 AM
WA
Sundodger Offline OP
WA
I have been running Chevron Delo 400 LE in my 1999 Ford Superduty with a 7.3 for a while now and pretty happy overall.
At my last oil change I found it a little challenging to find LE, most have been replaced with SDE. A quick look at the specs and I am a little worried to switch over with its lower zinc and phosphorus content.
I was working at a hot rod shop when they were dropping zinc content from automotive oils and saw the impacts onto older hardware (flat tappet cams with aggressive ramp rates and high spring pressures), so I might be a little paranoid here.
What are you guys doing? I am leaning toward changing brands...
LE Specs:
https://cglapps.chevron.com/msdspds/PDSDetailPage.aspx?docDataId=415568&docFormat=PDF
SDE Specs:
https://cglapps.chevron.com/msdspds/PDSDetailPage.aspx?docDataId=481951&docFormat=PDF
Re: Chevron Delo 400 LE vs 400 SDE [Re: Sundodger] #4443643
06/28/17 10:16 AM
06/28/17 10:16 AM
Kalifornia Kollective
BrocLuno Offline
BrocLuno  Offline
Looks like the same graphic for both ...
Re: Chevron Delo 400 LE vs 400 SDE [Re: BrocLuno] #4443682
06/28/17 10:56 AM
06/28/17 10:56 AM
WA
WA
You are right, I screwed up and it's not letting me edit it.
Sorry about that
Here is the SDE graphic:
Re: Chevron Delo 400 LE vs 400 SDE [Re: Sundodger] #4443706
06/28/17 11:12 AM
06/28/17 11:12 AM
Cincinnati, OH, USA
bullwinkle Offline
bullwinkle  Offline
Cincinnati, OH, USA
Anybody in your area carry the Delo SD 15W30? It was on clearance here a while back & I picked up some for my (older IDI) 7.3, I would think in non-arctic conditions it would be good in a Powerstroke engine.
06 Ram 3500 CTD 4X4(FG Venturi), 93 GMC C3500 6.2, 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 18 Transit 3.7, 03 Merc Grand Marquis 4.6 2V(XG2)
Re: Chevron Delo 400 LE vs 400 SDE [Re: bullwinkle] #4443923
06/28/17 01:46 PM
06/28/17 01:46 PM
WA
WA
To me it looks to be a little low on viscosity, but I have never run it. Have you sent any samples in to be analyzed?
Mobil Delvac 1300 is kind of where I am leaning right now.
Re: Chevron Delo 400 LE vs 400 SDE [Re: Sundodger] #4443995
06/28/17 02:43 PM
06/28/17 02:43 PM
upstate NY
dustyroads Offline
dustyroads  Offline
upstate NY
Delvac 1300 has also gone to the lower phosphorus add-pack. The Delvac Elite is still a higher phosphorus oil, but I don't think that it's available in Walmart for a nice price like the 1300 is. Just FYI. I'm personally fine with the new oils, regardless of the brand and additive strategy.
2013 F150 XLT 5.0 4X4 101k miles
Edge 5W-30 / Fram 10575
Re: Chevron Delo 400 LE vs 400 SDE [Re: Sundodger] #4444029
06/28/17 03:30 PM
06/28/17 03:30 PM
Cincinnati, OH, USA
bullwinkle Offline
bullwinkle  Offline
Cincinnati, OH, USA
No, not yet. My IDI 7.3 is actually rated for 10W30 (or straight 30), and given the HEUI/Powerstroke 7.3/6.0/6.4 engines tendency to shear 40 weight oils into 30 weights, why not start with a 30? The Big 3 has been telling everyone that the CK-4 oils are better than the CJ-4 ones, only Ford with the 6.7 has had any issues at all AFAIK.
Re: Chevron Delo 400 LE vs 400 SDE [Re: Sundodger] #4444323
06/28/17 09:06 PM
06/28/17 09:06 PM
Regina, Saskatchewan, Canada
Garak Offline
Garak  Offline
Note that low phosphorus Mobil Delvac 1 LE 5w-30 has Ford's previous specification, their E spec. So, if they thought that one low phosphorus lube was good enough for the 7.3 and most subsequent engines, I wouldn't worry in the least about a CK-4 in a 7.3.
Plain, simple Garak.
2008 Infiniti G37 - Shell ROTELLA T6 Multi-Vehicle 5w-30, NAPA Gold 7356
Re: Chevron Delo 400 LE vs 400 SDE [Re: Sundodger] #4444512
06/29/17 03:58 AM
06/29/17 03:58 AM
MD
claluja Offline
claluja  Offline
MD
LE Specs:
SDE Specs:
Stick with an oil that meets Ford's new spec. Plenty out there. They know more than we do, and have now done extensive testing on the issue. I stick with high phosphorous flavors, given the premature valve train wear some lower phosphorous CK4s have caused to 6.7s.
2014 F250 6.7L PSD
2006 Sequoia 4.7L
2005 E500 5.0L
1997 4Runner 3.4L
Re: Chevron Delo 400 LE vs 400 SDE [Re: claluja] #4444517
06/29/17 04:49 AM
06/29/17 04:49 AM
Garak Offline
Garak  Offline
That still doesn't answer why Ford okayed a low phosphorus 5w-30 HDEO on their previous E spec, which encompassed all the diesels up to the present, excluding the current one. That hardly gives me loads of confidence in them knowing "more than we do, and have now done extensive testing...."
Re: Chevron Delo 400 LE vs 400 SDE [Re: Sundodger] #4444723
06/29/17 09:32 AM
06/29/17 09:32 AM
WA
WA
My experience of when the auto oils started reducing zinc content in their oils and the resulting impact to old hardware is enough for me to call into question "They know more than we do".
Although to be honest, as an engineer myself I can tell you it's always about compromises and weighing them out. If you are trying to make something for a huge range of applications, it will not be optimized for any one and will probably have a few that it's very bad for. Unfortunately old hardware is usually very far down on the weighted priorities.
So with all this concern, what would you guys think is a safe bet for an oil that's not super pricey and relatively easy to come by?
Re: Chevron Delo 400 LE vs 400 SDE [Re: Sundodger] #4445398
06/29/17 09:21 PM
06/29/17 09:21 PM
Garak Offline
Garak  Offline
I would use any ordinary HDEO of the appropriate viscosity in a 7.3. There really has only been cause for concern with one Ford engine, period, and Ford won't even say much beyond that, but used a sky is falling approach for all legacy Ford engines. Do recall that the original specification for HDEO when the 7.3 came out was nowhere near as robust as it is now.
Re: Chevron Delo 400 LE vs 400 SDE [Re: Garak] #4445441
06/29/17 09:59 PM
06/29/17 09:59 PM
Houston, Texas
motor_oil_madman Online content
motor_oil_madman  Online Content
Houston, Texas
Which one? The 6.4? That engine needs needs new rocker arms after about 150,000 miles anyways. Maybe they're just testing and finding their engineering issues and blaming it on the oil. lol
2007.5 dodge cummins 6.7 liter. Chevron Delo400 15w40. 7000 mile or 250-300hr intervals.
Re: Chevron Delo 400 LE vs 400 SDE [Re: motor_oil_madman] #4445480
06/29/17 10:25 PM
06/29/17 10:25 PM
Garak Offline
Garak  Offline
He he. I've been saying that for a while. wink This is the "foaming" Ford was complaining about back in the late 1990s all over again, to get us to buy Motorcraft oil. Is there a specification problem, or are the big players' oils simply too cheap right now, or is the engine just loused up? whistle
Re: Chevron Delo 400 LE vs 400 SDE [Re: Sundodger] #4445913
06/30/17 12:00 PM
06/30/17 12:00 PM
WA
WA
The 7.3 mechanical assemblies are known to be pretty durable, especially in the high wear areas (cam, crank, etc.) So I guess my concern is more on the fuel injection system, HEUIs demand a lot of the oil.
Some older CAT and other International engines use HEUI systems, my google fu seems week today, does anyone have specs on CAT DEO oil or anything similar International recommends?
