Which is more important for low wear HTHS or ZDDP?
by Building3
06/21/18 10:40 AM
Valvoline DuraBlend 80W-90
by dogememe
06/21/18 10:34 AM
Lifter Tick
by Delta
06/21/18 10:28 AM
I Got Locked Up Today
by Zee09
06/21/18 10:24 AM
GM new 2.7 turbo pick up motor
by ZZman
06/21/18 09:45 AM
PUP at Canadian Tire $33 CAN
by Snagglefoot
06/21/18 09:15 AM
How to use up a case of SF?
by atikovi
06/21/18 09:08 AM
Read The Fine Print- Credit Cards
by Zee09
06/21/18 09:06 AM
Employer Exit Interview.
by JustinH
06/21/18 08:53 AM
Ceratec vs. Archoil 9100
by Phishin
06/21/18 08:49 AM
Acclaim radiator ?
by urrlord
06/21/18 08:47 AM
Understanding Idle Control Circuit
by artbuc
06/21/18 07:59 AM
Annual drain on Mobil1 5w20 high mileage?
by ryan2022
06/21/18 07:36 AM
Best Oil For Late Model Toyota V6 Engines ?
by ChrisD46
06/21/18 06:58 AM
Ford 4.6L Durability?
by Auae85
06/20/18 11:00 PM
Mercedes Benz High Mileage Badges
by Snagglefoot
06/20/18 10:46 PM
Lawn Tractor Tire Sealer
by 97K15004WD
06/20/18 10:01 PM
Fireworks Stores
by Warstud
06/20/18 09:36 PM
1994 Ranger fuel tank/frame cleanup & NOS part
by 01rangerxl
06/20/18 09:27 PM
Koreans top J.D. Power qlty; Ford, GM, FCA make strides
by wemay
06/20/18 09:18 PM
wil892, Spddm0n, ronw1309, Suth31, yamahaboy125
65286 Registered Users
94 registered (2015_PSD, 4WD, aquariuscsm, 28oz, andyd, Amenhotep, 7 invisible), 1490 Guests and 84 Spiders online.
65286 Members
67 Forums
285698 Topics
#4443399 - 06/28/17 04:11 AM Are 3/4" 16 UNF and 3/4" 16 UNF-2B the same thread
FordCapriDriver Offline
Loc: Balearic Islands , Spain
Thinking of using either a Bosch, Mahle OC33 or OC42 in place of the Motorcraft EFL-90 ( 74HM 6714 AA ).
1975 Ford Capri II Ghia 3000 V6, - Valvoline VR1 20W-50
1988 Ford Escort MkIV 1.6 Xr3i Cabrio, - Shell Rimula R4X 15W-40 HDEO.
#4443410 - 06/28/17 04:54 AM Re: Are 3/4" 16 UNF and 3/4" 16 UNF-2B the same thread [Re: FordCapriDriver]
ZeeOSix Offline
Loc: PNW
Both are the same diameter and thread pitch. The "2B" specifies how tight the threads will fit together.
From the link: https://en.wikipedia.org/wiki/Unified_Thread_Standard
https://upload.wikimedia.org/wikipedia/commons/4/4b/ISO_and_UTS_Thread_Dimensions.svg
Tolerance classes
"A classification system exists for ease of manufacture and interchangeability of fabricated threaded items. Most (but certainly not all) threaded items are made to a classification standard called the Unified Screw Thread Standard Series. This system is analogous to the fits used with assembled parts.
Class 1 threads are loosely fitting threads intended for ease of assembly or use in a dirty environment.
Class 2 threads are the most common. They are designed to maximize strength considering typical machine shop capability and machine practice.
Class 3 threads are used for closer tolerances.
Class 4 thread fit are even tighter than a Class 3.
Class 5 fit is not a loose thread. It is a interference thread, used on items like spring shackles on an automobile.
The letter suffix "A" or "B" denotes whether the threads are external or internal, respectively. Classes 1A, 2A, 3A apply to external threads; Classes 1B, 2B, 3B apply to internal threads.
Thread class refers to the acceptable range of pitch diameter for any given thread. The pitch diameter is indicated as Dp in the figure shown above."
I'm assuming the 3/4" 16 UNF is a class 1B thread, since there's no designation at the end. A class 1 or class 2 internal thread on the filter base plate should fit fine on the filter mounting center spud.
#4443456 - 06/28/17 06:31 AM Re: Are 3/4" 16 UNF and 3/4" 16 UNF-2B the same thread [Re: FordCapriDriver]
Ok thanks.
#4443514 - 06/28/17 08:00 AM Re: Are 3/4" 16 UNF and 3/4" 16 UNF-2B the same thread [Re: FordCapriDriver]
Claud Offline
Loc: Margate England
I learned something new today. Thanks ZeeOSix.
Claud.
#4443989 - 06/28/17 02:39 PM Re: Are 3/4" 16 UNF and 3/4" 16 UNF-2B the same thread [Re: FordCapriDriver]
ZeeOSix Offline
Loc: PNW
Anytime ... glad to help out.
#4444651 - 06/29/17 08:41 AM Re: Are 3/4" 16 UNF and 3/4" 16 UNF-2B the same thread [Re: FordCapriDriver]
Linctex Offline
Loc: Waco, TX
Most oil filters threads seem pretty "loose"...
but occasionally I run across some that are obviously a lot more snug.
I wonder if it's just poor machining/dull tooling more than anything, though.
