Be careful what you wish for...
by Shannow. 09/20/18 04:40 AM
Debating repowering my tower.
by Colt45ws. 09/20/18 01:10 AM
Oil filter for GM 8.1l V8?
by KenO. 09/19/18 11:10 PM
Help! No high beam
by wolf_06. 09/19/18 11:02 PM
Heading for divorce
by barkingspider. 09/19/18 11:02 PM
Oil recommendation: 1991 Nissan D21 truck
by RDY4WAR. 09/19/18 10:04 PM
Cold starting and CCS etc.
by CT8. 09/19/18 10:03 PM
Whine->Dead car(electrical)
by madRiver. 09/19/18 09:59 PM
Differential Allen Drain Bolt Buggered
by Gebo. 09/19/18 09:41 PM
Pick my oil. 25k miles a year
by Serge. 09/19/18 09:41 PM
Ok to use in Kubota? Pennsoil 0w-40
by racinjason. 09/19/18 09:35 PM
Road Hugger GTP A/S Tires
by Bud_One. 09/19/18 09:16 PM
Gravity Bleeding Clutch?hel
by Spetz. 09/19/18 09:10 PM
Drunken Watch?
by StevieC. 09/19/18 09:01 PM
New Forum Member New Truck Owner
by FarmerDude. 09/19/18 08:35 PM
Valvoline DOT 3/4?
by DJ. 09/19/18 08:22 PM
Best grease for AWD actuator disconnect?
by Bman90. 09/19/18 08:14 PM
Reconditioning a 2-Stroke Snow Blower
by Finz. 09/19/18 07:55 PM
Liquimoly Anti Friction - $6.83 Shipped/ Can
by ad244. 09/19/18 06:57 PM
ACEA spec for old Toyota??
by alexmarjanovic98. 09/19/18 06:54 PM
FarmerDude, Bman90, Alday714, Joephoto, tlelectric
66021 Registered Users
45 registered members (alarmguy, Bandito440, 2015_PSD, Bailes1992, Ablebody, biggusblockus, 3 invisible), 915 guests, and 41 spiders.
Topics290,699
Posts4,848,500
Members66,021
Most Online3,590
Jan 24th, 2017
Engine vibrates and idle RPM lowers using window #4443389
06/28/17 02:57 AM
06/28/17 02:57 AM
San Antonio, TX
Datarock Offline OP
Datarock  Offline OP
San Antonio, TX
I have a 2008 Nissan Versa. Over the past few months I have began to notice that when at an idle either parked or at a stop light etc. If I roll down/up the window the RPM lowers (usually about 200 RPM) and the engine vibrates heavily. Any idea why this electrical draw would do this? I do have bad engine mounts and actually am picking them up tomorrow as I had them ordered in but not sure why the window would do this.
Re: Engine vibrates and idle RPM lowers using window [Re: Datarock] #4443407
06/28/17 04:42 AM
06/28/17 04:42 AM
Slovenia EU
Kamele0N Offline
Kamele0N  Offline
Slovenia EU
Thats normal...
Also check how much life is left in your battery...
2011 Hyundai i30 1.4 CVVT Shell Helix Ultra 5w40
1997 Toyota Landcruiser KZJ95 3.0 TD Shell Rimula R6M 10w40
Re: Engine vibrates and idle RPM lowers using window [Re: Datarock] #4443425
06/28/17 05:42 AM
06/28/17 05:42 AM
Caribbean
Nissan101 Offline
Nissan101  Offline
Caribbean
Make sure there is no corrosion on your battery poles :-)
Clean them up and you will be fine
Nissan N16 -10w30
Nissan S13 -20w50
Royal Purple HPS smile
Re: Engine vibrates and idle RPM lowers using window [Re: Datarock] #4443473
06/28/17 07:16 AM
06/28/17 07:16 AM
Ontario, Canada
mightymousetech Offline
Ontario, Canada
Just sounds like you have a weak battery.
Mighty Mouse Tech
BMW Tech, Former Acura Tech
2010 Civic Si Castrol 0W40, Redline MTL
2013 BMW 135i M Sport Edition Castrol 0W40, Redline MTL
Re: Engine vibrates and idle RPM lowers using window [Re: Datarock] #4443507
06/28/17 07:55 AM
06/28/17 07:55 AM
PA
MarcS Offline
MarcS  Offline
PA
That is indeed what happens when you put a load on the alternator. there's nothing concerning unless it does it while you're just sitting there or if your windows are really slow
Re: Engine vibrates and idle RPM lowers using window [Re: Datarock] #4443516
06/28/17 08:04 AM
06/28/17 08:04 AM
Margate England
Claud Offline
Claud  Offline
Margate England
I'm surprised the ecu doesn't contol this. Does the idle speed drop when you turn on the A/C?.
Claud.
Re: Engine vibrates and idle RPM lowers using window [Re: Datarock] #4443720
06/28/17 11:17 AM
06/28/17 11:17 AM
South Texas Rancho
TexasVaquero Offline
South Texas Rancho
You may need a new battery. I recommend buying the ones at Nissan. They really are quality (surprisingly).
2014 NISSAN VERSA 5spd M/T- M1 EP 5w30 and M1 EP Filter. 5k OCI.
2011 CHEVY IMPALA 3.5ltrs - M1 HM 5w30 and M1 EP Filter. 3k OCI.
Re: Engine vibrates and idle RPM lowers using window [Re: Datarock] #4443761
06/28/17 11:42 AM
06/28/17 11:42 AM
Canada
Lolvoguy Offline
Lolvoguy  Offline
Canada
And Nissan motor mounts too.
06 Lexus IS350- Wife
88 BMW 325is- Mistress
Re: Engine vibrates and idle RPM lowers using window [Re: Datarock] #4448116
07/03/17 08:50 AM
07/03/17 08:50 AM
San Antonio, TX
Datarock Offline OP
Datarock  Offline OP
San Antonio, TX
Just a quick update. I replaced my torque (Bone) mount on the upper portion of the engine and the lower engine mount. I also removed the battery terminals and scrubbed them down. Seems the issue has greatly improved and both of the mounts were torn. When looking for a replacement mount, walmart of all places had the upper mount on clearance from Motor King for $10.87!!
Thanks everyone
Re: Engine vibrates and idle RPM lowers using window [Re: TexasVaquero] #4454515
07/09/17 06:05 PM
07/09/17 06:05 PM
Florida
ToadU Offline
ToadU  Offline
Florida
There are only 3 manufacturers of automotive batteries in the whole country. They are all just repackaged, labeled and branded at different price points and designed to different lonegricy points.
Probably can get the same battery for less without the Nissan name.
""As of May 1, 2013, there are three major automotive starting flooded battery manufacturers in the United States. There are four absorbed glass-mat (AGM) starting battery manufacturers and there are four flooded deep cycle battery/major deep cycle battery manufacturers in the United States.""
Per bumpertobumperradio.com
Re: Engine vibrates and idle RPM lowers using window [Re: Datarock] #4454527
07/09/17 06:23 PM
07/09/17 06:23 PM
Texas
WyrTwister Offline
WyrTwister  Offline
Texas
Would a " Nissan " battery be made in the USA or over seas ?
Wyr
God bless
Re: Engine vibrates and idle RPM lowers using window [Re: WyrTwister] #4454532
07/09/17 06:27 PM
07/09/17 06:27 PM
Florida
ToadU Offline
ToadU  Offline
Florida
I have no idea but I'll make a couple of points.....guesses......most Nissans are manufactured in the USA, shipping batteries is difficult but making them here in the USA 🇺🇸 involves more strict environmental regulations.
So I have no idea.
Re: Engine vibrates and idle RPM lowers using window [Re: Datarock] #4454533
07/09/17 06:29 PM
07/09/17 06:29 PM
Florida
ToadU Offline
ToadU  Offline
Florida
Thanks to a little known search engine called Google Nissan batteries are made and branded for them by Johnson Controls.
**my attempt at humor.
