Stick with WSS-M2C946-A?
by BlueFog. 12/14/18 01:42 PM
How engine capacity affects fuel consumption?
by NICAT. 12/14/18 01:12 PM
Pep Boys
by Zee09. 12/14/18 12:41 PM
How early in engines life can I start to extend OCI
by Doublehaul. 12/14/18 12:33 PM
EFB and AGM batteries charge faster?
by slybunda. 12/14/18 11:20 AM
97.5 Regal GS climate control illumination
by 71Chevyguy. 12/14/18 11:04 AM
Cool train site for Canadians
by Papa Bear. 12/14/18 10:09 AM
Putting together a groups 3/4/5 synthetic list
by MrWideTires. 12/14/18 10:02 AM
VW Atlas V6 Oil
by motech. 12/14/18 09:32 AM
Great shakes, it's Yahtzee... or a Taurus
by redhat. 12/14/18 09:03 AM
MWI Micro Wave Ignition
by Danno. 12/14/18 08:52 AM
8k Miles on M1 EP 2017 Subaru 3.6
by BISCUT. 12/14/18 08:47 AM
Wrong ATF Fluid in my 07 Chevy Impala
by CM613. 12/14/18 08:39 AM
Hyundai motor oil
by pbm. 12/14/18 08:16 AM
Which Exhaust Manifold Should I Buy
by Miller88. 12/14/18 08:10 AM
Rotella T5 10w30 Ford 6.7L anyone?
by sw99. 12/14/18 07:49 AM
Advice on spark plugs for 90,000 mile Accord
by Chris B.. 12/13/18 11:24 PM
Elec star kit for predator engine...
by SmokeyBear. 12/13/18 11:07 PM
Mecredes Bosch vs Ngk sparks plug
by Rohan. 12/13/18 09:48 PM
jcr1293, maxwellk, BlueFog, Frank_G35, captobvious
66681 Registered Users
86 registered members (bdcardinal, 53' Stude, AZjeff, bbhero, Anduril, 13 invisible), 1,839 guests, and 40 spiders.
Topics295,064
Posts4,927,140
Members66,681
Most Online2,553
Oct 27th, 2018
Replaced Differential fluid today #4443261
06/27/17 09:24 PM
06/27/17 09:24 PM
socal
barkingspider Offline OP
socal
Based on the dealer records / receipts from the previous owner, it doesn't appear the diff fluid was ever replaced so I decided to do it today.
Removed the full plug first
Removed the drain plug, oil didn't look bad but there was stuff on the magnet
I filled w supertech 80w90, will run for about 3k miles as a rinse then go with a full syn 75w90.
Took it for a drive and it runs normal and no whining.
06 Cadillac Escalade Ext
17 Cadillac ATS (wife)
05 Toyota Camry (daughter)
11 GMC Canyon off-road (daily)
Re: Replaced Differential fluid today [Re: barkingspider] #4443266
06/27/17 09:29 PM
06/27/17 09:29 PM
Northern Kentucky
901Memphis Offline
901Memphis  Offline
Northern Kentucky
Good idea on the extra flush
2012 Chevy Cruze LT 1.4T - 50k
2002 Buick Century 130k - Built 4T65e(Maxlife) - Edge 0w40 + Fram XG3980
Re: Replaced Differential fluid today [Re: 901Memphis] #4443295
06/27/17 10:00 PM
06/27/17 10:00 PM
Marshfield , MA
andyd Offline
andyd  Offline
Marshfield , MA
Why flush? Unless there was a problem.. A few bits of steel dust isn't a disaster.
Thick oil is better grin2
Re: Replaced Differential fluid today [Re: andyd] #4443317
06/27/17 10:29 PM
06/27/17 10:29 PM
SO.CA,USA
hank55 Offline
hank55  Offline
SO.CA,USA
Good Pictures!
Henry
Re: Replaced Differential fluid today [Re: barkingspider] #4443518
06/28/17 07:04 AM
06/28/17 07:04 AM
PA
MarcS Offline
MarcS  Offline
PA
really no need to flush a differential. It's not like there are any small passages to clean
Re: Replaced Differential fluid today [Re: barkingspider] #4443564
06/28/17 08:07 AM
06/28/17 08:07 AM
Malaysia
zeng Offline
zeng  Offline
Malaysia
What's the used oil viscosity grade and its mileage ? ...... looks serviceable btw.
Re: Replaced Differential fluid today [Re: barkingspider] #4443737
06/28/17 10:26 AM
06/28/17 10:26 AM
Canada
Lolvoguy Offline
Lolvoguy  Offline
Canada
Looks good thumbsup
How do you know if you've over/under filled it?
06 Lexus IS350- Wife
88 BMW 325is- Mistress
Say "no" to Turbo!
Re: Replaced Differential fluid today [Re: Lolvoguy] #4443742
06/28/17 10:30 AM
06/28/17 10:30 AM
PA
MarcS Offline
MarcS  Offline
PA
Originally Posted By: Lolvoguy
Looks good thumbsup
differentials have a drain hole and a fill hole. with the vehicle on a level surface, you fill until fluid starts leaking out the fill hole and then cap it when the stream slows down to a drip
Re: Replaced Differential fluid today [Re: zeng] #4443768
06/28/17 10:47 AM
06/28/17 10:47 AM
socal
socal
Used fluid was FF 75w90 (assume GM ac delco) w over 116k miles on it, did not do a uoa on it. It didn't look bad at all.
Re: Replaced Differential fluid today [Re: MarcS] #4443780
06/28/17 10:57 AM
06/28/17 10:57 AM
Ontario, Canada
mightymousetech Offline
Ontario, Canada
Looks good thumbsup
I wish mine had a drain plug. Stupid BMW.
Mighty Mouse Tech
BMW Tech, Former Acura Tech
2010 Civic Si Castrol 0W40, Redline MTL
2013 BMW 135i M Sport Edition Castrol 0W40, Redline MTL
Re: Replaced Differential fluid today [Re: mightymousetech] #4443782
06/28/17 11:00 AM
06/28/17 11:00 AM
PA
MarcS Offline
MarcS  Offline
PA
Looks good thumbsup
what a pain. do they want you to pump it out with a special dealer-only tool? that would be typical for the germans
Re: Replaced Differential fluid today [Re: barkingspider] #4443856
06/28/17 11:53 AM
06/28/17 11:53 AM
Central Virginia
Silverado12 Offline
Silverado12  Offline
Central Virginia
I thought about getting the Ford Racing aluminum pan (with drain plug and fill plug instead of a pan w/o anything) for my 2000 Mustang, but decided against it because I used synthetic 75W-140 and that should last another 100K miles. I had to pump mine in too. FWIW my fluid looked about like yours with a little more shavings on the plug. I wiped a lot of crud off the pan and paper toweled the inside of the diff best I could, so the flush isn't a bad idea since you can't get to the innards of yours.
12 Chevy Silverado ext. cab LS, 2WD 4.3 auto
18 Mustang GT 5.0 auto
07 Harley Dyna Street Bob 96 c.i. 6 sp.
00 Mustang GT auto
Re: Replaced Differential fluid today [Re: MarcS] #4443906
06/28/17 12:28 PM
06/28/17 12:28 PM
Ontario, Canada
Ontario, Canada
BMW considers the fluid "lifetime", so they never change it. Had to suck it out using my brake bleeder.
Mighty Mouse Tech
Re: Replaced Differential fluid today [Re: mightymousetech] #4443925
06/28/17 12:48 PM
06/28/17 12:48 PM
PA
MarcS Offline
MarcS  Offline
PA
As i just commented upon seeing the condition of my "lifetime" transmission fluid at 65k, me and the automakers are operating on a different definition of "lifetime." Theirs is clearly "just past the point where we don't need to pay for warranty claims"
Re: Replaced Differential fluid today [Re: barkingspider] #4443934
06/28/17 12:53 PM
06/28/17 12:53 PM
Katy, Republic of Texas
blupupher Offline
blupupher  Offline
Fluid coming out did not look too bad.
2012 xB: QSUD 0w-20/CQ Blue/5k
2010 Santa Fe: PP 0w-20/P1/8k
2007 Vue: VSP 5w-30/EcoGard/OLM
2004 F150: GTX HM 5w-20/TG2/4k
2002 F150: GTX HM 5w-20/EcoGard/1yr
1994 VT1100c: Peak 15w-40/PSL/5k
