Good Purchase?
by FordBroncoVWJeta. 03/19/19 11:33 AM
not sure what spark plugs to buy now
by MrTruckDriver. 03/19/19 11:33 AM
Tires on a Lease Return
by clarkflower. 03/19/19 11:25 AM
Auto-Rx now available on Amazon
by LarryD. 03/19/19 11:14 AM
Best place to advertise used car for sale?
by Ed_Flecko. 03/19/19 10:51 AM
A little help with a 2010 Santa Fe
by nicholas. 03/19/19 10:50 AM
Lawn Mower Battery - What's Up with That?
by Astro_Guy. 03/19/19 10:34 AM
This makes me sick
by SLO_Town. 03/19/19 10:32 AM
Slanderous Fram Orange Can Review
by doitmyself. 03/19/19 08:39 AM
MRV of PP EURO 0W40 an anomaly?
by 21Rouge. 03/19/19 08:39 AM
The Beater is Even Uglier Now!
by Delta. 03/19/19 08:28 AM
Oil viscosities at 200 to 225 F
by Snagglefoot. 03/19/19 07:35 AM
What would you do...
by Bailes1992. 03/19/19 05:28 AM
'65 Mini.
by Silk. 03/19/19 02:08 AM
Our trash guy is getting on my nerves.
by Chris142. 03/19/19 01:20 AM
Ecogard trans filter
by pda1122. 03/19/19 12:11 AM
4.3 vortec issues
by mobilaltima. 03/18/19 09:17 PM
Recommendation for filter for Alfa Romeo 4C?
by phaphaphooey. 03/18/19 09:17 PM
tbann, LisaMC, chops, drsoils, Gbear
67554 Registered Users
105 registered members (77GrandPrix, AandPDan, AdditiveOCD, 28oz, 11 invisible), 2,144 guests, and 67 spiders.
Topics286,063
Posts4,901,778
Members67,554
Most Online2,967
Mar 10th, 2019
diesel engine oil seems to be failing at 5000 mile #4443188
06/27/17 08:58 PM
06/27/17 08:58 PM
michigan us
perplexed Offline OP
michigan us
ive got a 1995 series 60 detroit i bought used.miles unknown.until last month the oil pressure was constant at 51 pounds when warm.it might drop a little when id pull a hill.suddenly its dropping below 48 and when it does my engine gets hot.i had an engine oil analysis done that showed good viscosity and normal metal wear.i changed the oil and the overheating went away.another 5000 miles and the same thing is happening to rotella 15-40.just to see what happens i added a fresh gallon of oil.the pressure and temp returned to normal.500 miles later im back to the same problem.with no evidence of contamination or failing engine parts im perplexed
Re: diesel engine oil seems to be failing at 5000 mile [Re: perplexed] #4443198
06/27/17 09:09 PM
06/27/17 09:09 PM
Deplorable in apple valley, ca
Chris142 Online content
Chris142  Online Content
Delo has a huge following here. Every truck I ever drove had it including detroits like yours. But I never paid THAT much attention to the oil pressure. As long as it was where it should be I drove it. Never seen any oil related failures myself.
02 Wrangler carlube 5w30
87 F250 traveler 15w40
07 fjcruiser Chevron 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
Re: diesel engine oil seems to be failing at 5000 mile [Re: perplexed] #4443210
06/27/17 09:18 PM
06/27/17 09:18 PM
Minnesota
bioburner Offline
bioburner  Offline
Minnesota
When I switched to Delo my consumption dropped from Rotella. Reminds me to tell the new owner of my 91 Ford 250 diesel to not fill all the way to the top of the dip stick.
97 Ford E350 D,99 F350 dually D
13 Scion Xb
12 Ford Transit Connect
06 Nissan Xterra
03 K1200 BMW
07 Kawasaki KLR650
13 Madass
Re: diesel engine oil seems to be failing at 5000 mile [Re: perplexed] #4443224
06/27/17 09:40 PM
06/27/17 09:40 PM
out there
spasm3 Offline
spasm3  Offline
out there
While i'm not a diesel mechanic, i have to wonder if you are having an intermittent overheating condition. Perhaps its not a 3psi drop in oil pressure causing the overheat. It might be that you are seeing the psi drop as a result of the engine getting hot and that affecting oil viscosity.
I really don't think oil pressure going from 51 psi to 48 is going to cause over heating.
13 elantra 75k 5w30 QSUD
03 chevy avalanche 80k synpwr 5w30
17 mazda cx-5 9500 miles m1 0w30
Re: diesel engine oil seems to be failing at 5000 mile [Re: spasm3] #4443235
06/27/17 09:51 PM
06/27/17 09:51 PM
Taiwan
Ducked Offline
Ducked  Offline
Taiwan
Above sounds plausible, but just in case it is oil related (which you do seem to have circumstantial evidence for) perhaps you could try topping-up with a comparable straight weight 40?
Perhaps in Minnesota you can't run a straight weight through the winter, but topping-up should be do-able.
Re: diesel engine oil seems to be failing at 5000 mile [Re: perplexed] #4443241
06/27/17 09:54 PM
06/27/17 09:54 PM
Canyon County Idaho
CT8 Offline
CT8  Offline
Canyon County Idaho
How many miles are on the engine. I guess it once was rebuilt. When your engine gets hot the oil pressure drops ? What does the factory recommend for oil pressure?
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: diesel engine oil seems to be failing at 5000 mile [Re: CT8] #4443249
06/27/17 10:03 PM
06/27/17 10:03 PM
michigan us
michigan us
i have no idea how many miles its got.its served me well for two years.im leaning towards fuel dilution.the oil analysis done by speedco states its ability to detect fuel in the oil isnt very good.btw the engine doesnt smoke except for a small puff on start up.one mechanic i spoke with yesterday suggested lucas.his theory is if its worn bearing the lucas should stabilize it if it doesnt i need to find a better lab to tell me whats happening to the oil
Re: diesel engine oil seems to be failing at 5000 mile [Re: perplexed] #4443365
06/28/17 01:34 AM
06/28/17 01:34 AM
Fort Lauderdale, FL
DoubleWasp Offline
DoubleWasp  Offline
Fort Lauderdale, FL
First of all, stay away from the Lucas. Lucas has never solved a problem in the universe, other than allowing shady used car dealers to bump up oil pressure on worn out engines to sell a clunker. It's not going to do any good for your engine. There's nothing in your oil that needs to be stabilized, and Lucas doesn't stabilize anything aside from the company's market position.
Secondly, it sounds as if the overheating is knocking down the oil and not vice versa. Think about it. If something was going so wrong with your oil that your engine were overheating (which would have to be through friction), your engine would be dead.
Heat shear is real. I watched my old boat overheat one time. This engine, which always puts up 40 psi under any circumstances, dropped to 25 psi at 2500 rpm.
You need to be looking at why your engine overheats. It isn't because of your oil. Refreshing your oil makes it less prone to heat shear, but it isn't your oil doing this.
If you insist on pursuing an oil remedy, try Schaeffer synthetic diesel oil. Schaeffer and Amsoil synthetic oils usually deliver solid reductions in engine oil temperature in our experience, and the experience of others.
Re: diesel engine oil seems to be failing at 5000 mile [Re: perplexed] #4443409
06/28/17 04:52 AM
06/28/17 04:52 AM
Sav ga
NStuart Offline
NStuart  Offline
Sav ga
I have multiple Detroit's running Schaeffer's 5w40 at hot idle I see about 21 to 25 psi on the engines varying 200,000 to a million miles. It's starting to warm up outside obviously rinse out the radiator air-to-air and condenser with a hose. When was the last time the thermostats were replaced, it is my understanding that the oil cooler has a thermostat as well, what is your oil pressure at hot idle, what do you consider overheating
Detroit14l 1m75k mi bp schaffer9k 30k oil
96 ram 5.9 gas 80k built tranny 5k m1
85 cj7 4.2 performance build. Schaeffer 9000
08 cbr600rr graffiti. T6
08 husky sm610 t6
Re: diesel engine oil seems to be failing at 5000 mile [Re: perplexed] #4443475
06/28/17 07:21 AM
06/28/17 07:21 AM
Sav ga
NStuart Offline
NStuart  Offline
Sav ga
Btw my oil temp runs 190 degrees always. Truck never gets over 200 degrees.
My factory thermostats had 1m miles on them, huge difference in temp after replacement
08 husky sm610 t6
Re: diesel engine oil seems to be failing at 5000 mile [Re: perplexed] #4443503
06/28/17 07:51 AM
06/28/17 07:51 AM
Michigan
64bawagon Offline
64bawagon  Offline
Michigan
I think youre looking at the oil instead of the overheating. I would start with a good oil analysis right after I went through the cooling system including the thermostats, they are relatively easy to replace. Does the engine have a coolant filter in the system ?
Every S60 I ever dealt with was pretty easy on oil.
64 Chevy wagon, 10 Jeep Wrangler, 18 Silverado 1/2 ton
Re: diesel engine oil seems to be failing at 5000 mile [Re: perplexed] #4444550
06/29/17 06:17 AM
06/29/17 06:17 AM
Central Iowa
TiredTrucker Offline
Central Iowa
Delo may have a huge following here, but I am not one of them. My 2000 S60 12.7 hates the stuff. Tried it for a while and got UOA's I really didn't like. My S60 has a preference for Schaeffer primarily or Delvac sometimes. I typically use 10w30 in winter and 15w40 in summer. Both syn blends.
Freedom is not about having the choice to do what you want, but the choice to do what you ought.
Re: diesel engine oil seems to be failing at 5000 mile [Re: perplexed] #4453743
07/08/17 07:51 PM
07/08/17 07:51 PM
Michigan
A_Harman Offline
A_Harman  Offline
Michigan
Sounds to me like your coolant is overheating, allowing the oil to run hotter, thereby putting it at a lower viscosity. I don't think that a 15w40 will be sheared in a heavy-duty diesel.
1985 Z51 Corvette track car
2002 Camaro Z28 LS1/6-speed
2001 Dodge Ram 2500 diesel
1972 GMC 1500 shortbed project truck
