Drain/refill vs diy flush?
by Back40. 03/20/19 05:59 AM
Valvoline 5w30 Synpower HSTS?
by avi1777. 03/20/19 05:05 AM
Castrol Edge 5W50 "Supercar Titanium FST"
by Berto. 03/20/19 02:43 AM
The power of reaching out
by SlavaB. 03/20/19 12:57 AM
Used brake fluid
by OilUzer. 03/19/19 11:26 PM
Look what I found
by deven. 03/19/19 11:23 PM
91 E-free, or 91 "up to 10%" for GDI?
by Ws6. 03/19/19 11:12 PM
Ford 2019 F350 oil
by arowbat. 03/19/19 11:04 PM
Royal purple discontinuing 30-1218 ?
by jmj540. 03/19/19 10:02 PM
Nissen Radiator Review
by zmelli. 03/19/19 09:01 PM
March madness
by gman2304. 03/19/19 08:36 PM
Shell Rotella T6 5W-30 Multi
by kstanf150. 03/19/19 08:21 PM
New Toyota Tacoma oil recommentation
by Moondawg. 03/19/19 08:11 PM
Which oil for modified turbo engine?
by headoff93. 03/19/19 08:02 PM
Problems After Adding 2 Stroke To Diesel
by InfernoRedBeast. 03/19/19 07:47 PM
Amsoil filter
by Bill_W. 03/19/19 07:01 PM
My $1 ocod 4k
by Pinoak. 03/19/19 06:58 PM
GMC tailgate latch repair question
by aquariuscsm. 03/19/19 06:49 PM
Can I Use Maple Syrup Instead Of Oil ?
by Warstud. 03/19/19 06:09 PM
Washoe_Mark, CG_BrianM, TBF, mm2020, emepher
67563 Registered Users
76 registered members (alarmguy, aquariuscsm, bcossa2001, avi1777, Back40, Astro_Guy, 8 invisible), 991 guests, and 49 spiders.
Topics286,106
Posts4,902,702
Members67,563
Most Online2,967
Mar 10th, 2019
2012 yaris flush? #4443147
06/27/17 08:15 PM
06/27/17 08:15 PM
Alabama
macdole99 Offline OP
Alabama
Hey guys i just picked up a 12 yaris with 113k on the clock. I contacted the dealer and was told the transmission fluid does not need to be changed but it looks dark. it has a dipstick so i'm assuming it also has a drain bolt beneath, any recommendations on a fluid? dealer said it uses the toyota ws fluid. i was considering doing 3 to 4 drain and fills but unsure of what fluid to use. any recommendations? thanks
2002 qx4 107k
1999 altima 235k
2002 tahoe 275k
Re: 2012 yaris flush? [Re: macdole99] #4443157
06/27/17 08:22 PM
06/27/17 08:22 PM
Specific Ocean
Kibitoshin Offline
Kibitoshin  Offline
Specific Ocean
Stick with WS if you are doing drain/refills instead of a complete fluid exchange. If doing a complete fluid exchange I would use Maxlife. I would recommend changing the ATF filter since it hasn't been changed.
Shin Gekiretsu Shin'ou'hou
01 Toyota Tundra 2WD V8 4.7L
02 Chevy Silverado C1500 V8 5.3L
Re: 2012 yaris flush? [Re: macdole99] #4443172
06/27/17 08:41 PM
06/27/17 08:41 PM
BC Canada
Farmer Offline
Farmer  Offline
BC Canada
10MM Allen head. Remember to replace the crush washer.
Re: 2012 yaris flush? [Re: macdole99] #4443208
06/27/17 09:17 PM
06/27/17 09:17 PM
Seattle-ish, WA
Oro_O Offline
Oro_O  Offline
Seattle-ish, WA
WS is a pefectly mediocre dino fluid, and with better, cheaper options availabe it wouldn't be the best move to refill with it. Castrol, Pennzoil, and Valvoline all make LV synthetics that are more robust and are good in WS applications.
At that mileage, I'd do a cooler line exchange and replace it with MaxLife or similar. Dropping the pan to check things out, if you can, is not a bad idea but I don't think 100% necessary. Don't forget your PS system, too. And you do the brakes periodically too, right?
Re: 2012 yaris flush? [Re: macdole99] #4443221
06/27/17 09:35 PM
06/27/17 09:35 PM
Alabama
Alabama
i literally just got it this morning. i was thinking of using maxlife but was going to do multiple drain and fills. instead of the cooler line flush. is there a filter there or is it a screen? and good call on the power steering fluid i totally forgot thanks.
2002 qx4 107k
1999 altima 235k
2002 tahoe 275k
Re: 2012 yaris flush? [Re: macdole99] #4443267
06/27/17 10:33 PM
06/27/17 10:33 PM
socal
barkingspider Offline
socal
You are good to go doing drain and fills. Trans filter should be cheap so I would replace it. Use whatever compatible fluid you like best. I went with castrol transmax import when I did my daughter's Camry.
06 Cadillac Escalade Ext
17 Cadillac ATS (wife)
05 Toyota Camry (daughter)
11 GMC Canyon off-road (daily)
Re: 2012 yaris flush? [Re: macdole99] #4443373
06/28/17 01:50 AM
06/28/17 01:50 AM
NY
DdDd Offline
DdDd  Offline
NY
Drain and fill over a few thousand miles. Give the new fluid time to remove deposits and then swap again.
Three should be more than enough. The third being permanent
Re: 2012 yaris flush? [Re: macdole99] #4443531
06/28/17 08:23 AM
06/28/17 08:23 AM
Occupied Virginia
Bottom_Feeder Offline
Occupied Virginia
Unless you're 100% sure that that trans uses an actual filter and not just a screen, don't even crack the pan. Drain and fill is more than fine.
That said, doing multiple drains and fills is a waste unless you spread them out a bit. Doing them every few thousand miles, like when you're under there to change your oil anyway, is your best bet.
Personally, I would D/F it at your next oil change, then once more at the following one and never touch it again. Doing it 3 or 4 times is overkill and a waste of money and materials.
Re: 2012 yaris flush? [Re: macdole99] #4444121
06/28/17 04:59 PM
06/28/17 04:59 PM
USA
slacktide_bitog Offline
USA
first choice is Maxlife ATF, a BITOG favorite.
Second choice, Castrol Full Synthetic ATF
Third choice, any modern synthetic LV multi-vehicle ATF
