Turn signal bulbs for '15 BMW?
by Benzadmiral. 03/20/19 07:02 AM
Drain/refill vs diy flush?
by Back40. 03/20/19 05:59 AM
Valvoline 5w30 Synpower HSTS?
by avi1777. 03/20/19 05:05 AM
Castrol Edge 5W50 "Supercar Titanium FST"
by Berto. 03/20/19 02:43 AM
The power of reaching out
by SlavaB. 03/20/19 12:57 AM
Used brake fluid
by OilUzer. 03/19/19 11:26 PM
Look what I found
by deven. 03/19/19 11:23 PM
91 E-free, or 91 "up to 10%" for GDI?
by Ws6. 03/19/19 11:12 PM
Ford 2019 F350 oil
by arowbat. 03/19/19 11:04 PM
Royal purple discontinuing 30-1218 ?
by jmj540. 03/19/19 10:02 PM
Nissen Radiator Review
by zmelli. 03/19/19 09:01 PM
March madness
by gman2304. 03/19/19 08:36 PM
Shell Rotella T6 5W-30 Multi
by kstanf150. 03/19/19 08:21 PM
New Toyota Tacoma oil recommentation
by Moondawg. 03/19/19 08:11 PM
Which oil for modified turbo engine?
by headoff93. 03/19/19 08:02 PM
Problems After Adding 2 Stroke To Diesel
by InfernoRedBeast. 03/19/19 07:47 PM
Amsoil filter
by Bill_W. 03/19/19 07:01 PM
My $1 ocod 4k
by Pinoak. 03/19/19 06:58 PM
GMC tailgate latch repair question
by aquariuscsm. 03/19/19 06:49 PM
Washoe_Mark, CG_BrianM, TBF, mm2020, emepher
67563 Registered Users
71 registered members (badtlc, AurionX2, alarmguy, avi1777, aquariuscsm, Astro_Guy, 5 invisible), 1,145 guests, and 48 spiders.
Topics286,107
Posts4,902,713
Members67,563
Most Online2,967
Mar 10th, 2019
Vinegar ok to clean out swamp cooler lines? #4443012
06/27/17 05:34 PM
06/27/17 05:34 PM
CA, USA
paulri Offline OP
paulri  Offline OP
CA, USA
one of the lines that distribute water onto the pads, is clogged up. I've got a snake line going up and starting to get drops of water out of it, but I've also heard that putting vinegar in the water at the bottom is good, to clean away some of the hard water deposits.
Would it be ok to do this? I'd rather not complicate things for myself at this point.
2005 Toyota Sienna LE; 163,000 miles
2006 Toyota Highlander Hybrid 118,000 miles
Re: Vinegar ok to clean out swamp cooler lines? [Re: paulri] #4443020
06/27/17 05:50 PM
06/27/17 05:50 PM
Phoenix, AZ
Nick1994 Offline
Nick1994  Offline
Phoenix, AZ
Just take the line out and use the garden hose to spray the crud out.
Or just get new lines, they're cheap.
2015 Hyundai Sonata 2.4L 92k STP Synthetic HM 10w30 & Wix
2000 Toyota Camry 2.2L 233k Mobil Super HM 10w40 & Fram Ultra
1996 Jeep Cherokee 4.0L 148k Mobil 1 HM 10w40 & Fram Ultra
Re: Vinegar ok to clean out swamp cooler lines? [Re: paulri] #4443023
06/27/17 05:55 PM
06/27/17 05:55 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
White vinegar only.
You could also use (very) diluted muriatic acid
How much lime & scale is built up in the swamp cooler?
Re: Vinegar ok to clean out swamp cooler lines? [Re: Linctex] #4443033
06/27/17 06:02 PM
06/27/17 06:02 PM
CA, USA
paulri Offline OP
paulri  Offline OP
CA, USA
Not sure how much is there, it has taken several pushes up with the snake line to get just one drop coming out.
Originally Posted By: Linctex
White vinegar only.
Re: Vinegar ok to clean out swamp cooler lines? [Re: paulri] #4443045
06/27/17 06:15 PM
06/27/17 06:15 PM
MN
oil_film_movies Offline
MN
Lime-A-Way, green bottle, works
Re: Vinegar ok to clean out swamp cooler lines? [Re: paulri] #4443076
06/27/17 06:48 PM
06/27/17 06:48 PM
Seattle-ish, WA
Oro_O Offline
Oro_O  Offline
Seattle-ish, WA
If it's a flexible line, remove it and coil it up and put it in a pan of vinegar. It will dissolve it pretty quickly. I use vinegar to clean all our shower heads, faucet heads, etc. every year or two. Very, very effective and no need for specialized products.
Re: Vinegar ok to clean out swamp cooler lines? [Re: paulri] #4443103
06/27/17 07:23 PM
06/27/17 07:23 PM
Canyon County Idaho
CT8 Offline
CT8  Offline
Canyon County Idaho
What is the cause of the clogged the lines? I had swamp coolers running well water for the past 17 years, high mineral content,super high . What pads are you using?
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: Vinegar ok to clean out swamp cooler lines? [Re: paulri] #4443106
06/27/17 07:25 PM
06/27/17 07:25 PM
CA, USA
paulri Offline OP
paulri  Offline OP
CA, USA
I think it's just hard water. It is the straw-type pads, so it might be a bit of that that got pushed up the line, although I believe there is a filter that would have caught that...
Re: Vinegar ok to clean out swamp cooler lines? [Re: paulri] #4443133
06/27/17 08:00 PM
06/27/17 08:00 PM
Canyon County Idaho
CT8 Offline
CT8  Offline
Canyon County Idaho
I would have the pad material clog up the lines every once in a while.Have you tried to increase the coolers performance by doubling up the pads?
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: Vinegar ok to clean out swamp cooler lines? [Re: paulri] #4443136
06/27/17 08:02 PM
06/27/17 08:02 PM
Lakeside, CA
Blkstanger Offline
Blkstanger  Offline
Lakeside, CA
I have used CLR.
99 Jeep WJ 4.7 197,000 Maxlife 10w30, Fram Ultra.
Re: Vinegar ok to clean out swamp cooler lines? [Re: paulri] #4443154
06/27/17 08:19 PM
06/27/17 08:19 PM
PV Az @ 5000'
AZjeff Offline
AZjeff  Offline
PV Az @ 5000'
What Nick said. You'll spend 3x longer trying to get it unclogged and replacement lines are cheap. Dump the water once a month or if not difficult twice a month and greatly reduce the mineral buildup on the pads, pump, lines. Do swamp coolers and hard water go together everywhere?
86 Samurai 1.3 leftovers
14 RAV4 2.5 5W-20 PP
16 Silverado 1500 4.3, DI, AFM 5W-30 PP
The most important thing to do in your life is to not interfere with someone else's life. - Frank Zappa
Re: Vinegar ok to clean out swamp cooler lines? [Re: paulri] #4443455
06/28/17 06:31 AM
06/28/17 06:31 AM
Nowhere NM
Smoky14 Online content
Smoky14  Online Content
Nowhere NM
I use an old speedometer cable to clean the spider lines. Flexible enough and big enough to do the job.
Smoky
99 Acura 2.3CL 5speed MT
12 Ford Fusion 2.5S 6speed MT
05 Suzuki Bandit 1200.
