VW mk5 a/c intermittently works
by ram_man. 03/24/19 11:01 PM
DIY alignment done right?
by tookien. 03/24/19 10:03 PM
Cell phone privacy question
by loneryder. 03/24/19 10:00 PM
Ride quality between 45 and 35 sidewall
by bowlofturtle. 03/24/19 09:23 PM
FRAM TG 7317 - 12K miles opened
by crazy_raccoon. 03/24/19 09:01 PM
2014-2017 Toyota Corolla CVT Quiet Recall
by StevieC. 03/24/19 08:11 PM
Finally Found Factory Ammo my 308 Bolt Gun Likes
by Fastzntn. 03/24/19 08:10 PM
Umarex Glock 19 Co2
by Sonic. 03/24/19 07:57 PM
I put in 2 1/2 qts, damage?
by JLawrence08648. 03/24/19 07:21 PM
How to dispose / recycle Li-Ion batteries?
by 92saturnsl2. 03/24/19 06:16 PM
New member of the (automotive) family!
by addyguy. 03/24/19 06:04 PM
6.2 f250 6.4 ram 2500 towing with a gasser
by FLORIDA. 03/24/19 05:55 PM
T5 15w40 for my bike?
by Degreaser. 03/24/19 05:47 PM
Studded tires in warm weather
by y_p_w. 03/24/19 05:28 PM
ST 15W40
by mobilaltima. 03/24/19 05:02 PM
Rollo, Drifted, Jcar516, gregjr7, daveed
67613 Registered Users
76 registered members (4WD, 2015_PSD, 2003f7, 2010Civic, 6 invisible), 1,360 guests, and 63 spiders.
Topics286,366
Posts4,907,108
Members67,613
Most Online2,967
Mar 10th, 2019
More on ASRC Fluid #4442997
06/27/17 05:13 PM
06/27/17 05:13 PM
Sask, Canada
BrianF Offline OP
BrianF  Offline OP
Sask, Canada
So I was passively doing some more digging on this fluid for my AS69RC trans. Again the usual suspects to use are Mobil 3309. I was communicating with Aisin on the matter but they have not been very forthcoming with my questions. Apparently besides the 3309, my trans can also use their Aisin ATF-OT4. Other than it is made by various suppliers and blenders, that was all the information I have received. Now my next step is to see what other transmissions can use this fluid in another attempt to cross check compatibility.
2006 Trailblazer LT. QSUD with Fram Ultra.
2017 Ram 3500 SLT Megacab. Duron SHP 10w30 with Hastings LF608.
1993 GMC 1500. QSAD with Fram PH5
Re: More on ASRC Fluid [Re: BrianF] #4652165
01/31/18 03:27 PM
01/31/18 03:27 PM
Alberta, Canada
All4Traction Offline
Alberta, Canada
I'm also curious about the ATF-0T4 fluid, as that's what my parts store said the cross-reference was for the transmission. BUT, I haven't been able to find that Spec on ANYTHING.
Has anyone nailed down a fluid SPEC that is equivalent to ASRC fluid or Mobil 3309?
I have a 2015 Ram 3500 with Aisin Trans.
My AS69RC Transmission dipstick handle says use "AS68RC" fluid. Then the dipstick says use only Mopar ASRC fluid.
I contacted Mobil, as it appears the Mobil 3309 is discontinued.. I asked if it's still available.
Their reply was that they do not have an ATF for my AS69RC transmission...
I see a few fluids around now that are rated JWS-3309 and Toyota T-IV, and several others. From what I've read, this is what's typically used in import brands with Aisin transmissions. I'm quite sure that the JWS-3309 (aisin-warner) fluid would be the same, but that's just me reading lots of jugs of ATF oil, spec sheets, and internet reading. (No actual testing or previous knowledge of oils)
From what I've read, the Mobil 3309 is generally accepted for this transmission, and is/was a high viscosity fluid. I've compared the spec sheets of other fluids, and have found a few that are very similar. For viscosity at 40 and 100deg, and viscosity index.
Mobil 3309 is rated:
cst @100 celcius = 7.1
cst @40 celcius =33
@-40 celcius=13,000
viscosity index =181
Density 0.8520
Now, I'm no oil expert, but how much difference in these #'s really matters?? Would an oil that meets JWS3309 and T-IV, with ratings of the following be very close?:
40c=33-36
100c=6.9-7.4
-40c=11,000-18,000
VI=165-180
AND, is there more these oils that I'm missing? Maybe certain additives that the AS69RC transmission needs?
I even see some oils now that have the AS68RC rating on their website, as an "equivalent". (ie. Amsoil who claims their oil works everywhere, Petrocan Duradrive MV, Castrol transmax multivehicle, Total MV, liquimoly 1200).
I guess, bottom line.... If I find a fluid that "recommends" the fluid for AS68RC, should I feel confident in that?
Re: More on ASRC Fluid [Re: BrianF] #4652611
01/31/18 09:54 PM
01/31/18 09:54 PM
Sask, Canada
BrianF Offline OP
BrianF  Offline OP
Sask, Canada
Real nice to see that 3309 is no longer available.
I came to the conclusion that ASRC is 3309 is T4 is JWS 3309 which according to Toyota, T4 has been replaced by low viscosity WS which is JWS 3324 and is backward compatible.
I think we are overthinking this transmission and its mystical requirements. I will be pricing out duradrive and looking for other cheaper alternatives to 17$ a liter at the dealer.
Re: More on ASRC Fluid [Re: BrianF] #4652758
02/01/18 12:35 AM
02/01/18 12:35 AM
Fort Worth, Texas
clinebarger Online content
clinebarger  Online Content
Fort Worth, Texas
Mobil 3309
cSt @ 100C 7.1
cSt @ 40C 33
cP @ -40C (-40F) 13,000
Viscosity Index 181
Flash Point, C 185
Pour Point, C -45
Density 0.8520
Color Red
AC Delco Multi Vehicle Transmission Fluid, Fully Synthetic DEXRON III A.T.F.
SUITABLE FOR USE WITH FOLLOWING SPECIFICATIONS: HERE
Appearance Clear Red Fluid
Specific gravity @15 C kg/L 0.849
Viscosity at 40C ASTM D 445 cSt 40
Viscosity at 100 C ASTM D 445 cSt 7.2
Viscosity index ASTM D 2270 150
Pour Point, FLTP* 124 < -45 C
Flash Point, COC ASTM D92 195 C
Castrol Transynd
Density @ 15C, Relative ASTM D4052 g/ml 0.848
Colour Visual - Red
Viscosity, Kinematic 40C ASTM D445 mm/s 38
Viscosity, Kinematic 100C ASTM D445 mm/s 7.4
Viscosity Index ASTM D2270 None 167
Flash Point, COC ASTM D92 C 235
Viscosity, Brookfield @ -40C ASTM D2983 mPa.s (cP) 8500
Pour Point ASTM D97 C -63
2001 Chevy Camaro L92/4L80E
Re: More on ASRC Fluid [Re: BrianF] #4652769
02/01/18 12:51 AM
02/01/18 12:51 AM
Fort Worth, Texas
Fort Worth, Texas
Castrol Transynd has proven itself in "Constant Slip" converter clutches & "Clutch to Clutch" transmissions. I have ran it in Aisin AS69RC units with great success.
Re: More on ASRC Fluid [Re: clinebarger] #4657009
02/05/18 02:56 PM
02/05/18 02:56 PM
Alberta, Canada
Alberta, Canada
Good to know that I could add some other equivalents to my list.
I purchased the Petro-can Duradrive MV Synthetic for my AS69RC transmission. I paid $7/litre, where dodge wanted $13 for the ASRC.
I also bought Amsoil ATF "signature series" ATF for my BW transfer case. I paid $17/litre, vs $33 at Dodge for the BW44-.. fluid!
From all the reading I've done, I believe these are equivalents of the "Mopar" fluids for the Transmission and Transfer Case.
I don't mind paying $ for good oil, but I do mind paying for something that I can't find any specifications for (MOPAR!)
Re: More on ASRC Fluid [Re: BrianF] #4660473
02/08/18 11:19 PM
02/08/18 11:19 PM
Sask, Canada
BrianF Offline OP
BrianF  Offline OP
Sask, Canada
I spoke with a local bulk dealer for Mobil. 3309 was 6.56$ a liter, before tax. Came in 5 liter jugs and minimum 4 jugs per box.
Re: More on ASRC Fluid [Re: BrianF] #4661234
02/09/18 07:05 PM
02/09/18 07:05 PM
Sask, Canada
BrianF Offline OP
BrianF  Offline OP
Sask, Canada
Duradrive is 7.36 a liter before tax.
