Coolant Leak '06 300C
by Redright9. 03/25/19 12:40 PM
New truck
by double vanos. 03/25/19 12:26 PM
What pressure washer should I buy?
by wallyuwl. 03/25/19 11:27 AM
Natural Gas from Ohio Valley
by SubLGT. 03/25/19 11:18 AM
CVT Reliability and Durability
by raffy. 03/25/19 11:00 AM
comfortable seats
by redhat. 03/25/19 10:29 AM
walmart evinrude tcw-3 clearance score
by 1978elcamino. 03/25/19 10:15 AM
Mixing SN/d1G1 with SN+/d1G2?
by doyall. 03/25/19 10:14 AM
Best 2nd Phone Number App ?
by LoneRanger. 03/25/19 09:56 AM
Crud! Wix jacking up prices again! :(
by SubieRubyRoo. 03/25/19 09:53 AM
Interior "quick detailer"
by Redright9. 03/25/19 08:21 AM
Seafoam For Last 100 Miles Before Oil Change ?
by ChrisD46. 03/25/19 07:56 AM
WIX 57151XP factory filled with synthetic oil
by Donald. 03/25/19 06:58 AM
BMW Buying Guide: Every Model, Explained
by wemay. 03/25/19 05:43 AM
Double Din Android Auto Advice
by JeffKeryk. 03/24/19 11:25 PM
VW mk5 a/c intermittently works
by ram_man. 03/24/19 11:01 PM
sonusfaber, Rollo, Drifted, Jcar516, gregjr7
67614 Registered Users
128 registered members (benjy, Altima2, Benzadmiral, Bailes1992, aquariuscsm, Alfred_B, 8 invisible), 2,223 guests, and 63 spiders.
Topics286,397
Posts4,907,578
Members67,614
Most Online2,967
Mar 10th, 2019
Striker fired pistol? #4442907
06/27/17 03:13 PM
06/27/17 03:13 PM
MA.
Camprunner Offline OP
MA.
On a striker fired pistol like Glock, S&W M&P, Ruger SR, H&K, XD etc -etc... When the gun is loaded with a round in the chamber is there a firing pin block safety so there is no way the firing pin could contact the bullet primer without trigger pull?
Re: Striker fired pistol? [Re: Camprunner] #4442914
06/27/17 03:23 PM
06/27/17 03:23 PM
TN
TTK Offline
TTK  Offline
TN
Yes.
2010 Volvo V70-3.2
Current Fill:Mobil 1 AP 5w-30
2018 Subaru Forester, 0w-20 Subaru oil
2001 Chevrolet Prism:Castrol Magnatec 5w-30
Re: Striker fired pistol? [Re: Camprunner] #4442922
06/27/17 03:29 PM
06/27/17 03:29 PM
Port Orange, Florida
Panzerman Offline
Panzerman  Offline
The Glock has a worm drive type firing pin. When you pull the trigger it drives the pin back until it get the end of the worm spin and fires. It's interesting. I bought a Glock way back before they were cool.
I can't speak for the rest but would bet they are on the same design due to the long trigger pull they have.
2006 Dodge Ram 2500 Hemi 4x4
2016 Dodge Challenger Scat Pack
Re: Striker fired pistol? [Re: Camprunner] #4442924
06/27/17 03:29 PM
06/27/17 03:29 PM
Philadelphia PA
SKVenture Offline
SKVenture  Offline
Philadelphia PA
That is absolutely correct.
In most striker fired pistols, Glock for example, the firing pin is also not "primed" or pulled back with tension under a spring until the trigger is pulled.
So the firing pin has zero tension and it is completely blocked off by metal from the primer until the trigger is pulled.
It literally can't fire without the trigger being pulled.
Re: Striker fired pistol? [Re: SKVenture] #4443029
06/27/17 05:58 PM
06/27/17 05:58 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
A VERY innovative design, and REALLY set the trend for how new pistols are made & sold.
Re: Striker fired pistol? [Re: Camprunner] #4443184
06/27/17 08:52 PM
06/27/17 08:52 PM
Central Coast, Calif.
tom slick Offline
tom slick  Offline
A Glock's firing pin is under tension when it's in battery but the spring isn't fully compressed. As the trigger is pulled the firing pin block is moved out of the way as the firing pin and the firing pin is pressed rearward until the sear releases.
The S&W M&P functions the same.
You get what you pay for...
So keep in mind how much you paid for this advice.
Re: Striker fired pistol? [Re: Panzerman] #4443310
06/27/17 11:24 PM
06/27/17 11:24 PM
South Eastern, CT
AMC Offline
AMC  Offline
South Eastern, CT
duh
Not sure where you got that info but it is completely wrong.
The glock striker is driven backwards against spring pressure until the sear plate is cammed downward, causing the sear the lose its grip on the edge of striker, releasing it, which allows the striker to slam into the primer under power of the striker spring. There is no turning, spinning or twisting of anything involved.
18 Honda CR-V - Mobil-1 AFE 0w-20
17 Ram 1500 SLT - Napa Synthetic 5w-20
14 Yamaha Super Tenere - Mobil Delvac 15w-40
Re: Striker fired pistol? [Re: Camprunner] #4443931
06/28/17 01:52 PM
06/28/17 01:52 PM
Northern Kentucky
901Memphis Offline
901Memphis  Offline
Northern Kentucky
It's pretty simple, there a striker block (#2 in the picture) between the firing pin and the primer and it's moved up and out of the way when the trigger is pressed by the top of the trigger bar. The trigger bar won't move unless the trigger safety is engaged (#3 in the image).
The Takeup slack in a the striker fired guns is the striker block being pushed up and out of the way before you hit the wall, which is often why people complain about striker fired triggers.
2012 Chevy Cruze LT 1.4T - 59k - Edge 0w30 SL + Mahle OX401D
2002 Buick Century 144k - Built 4T65e(Maxlife) - GTX 5w30 + Fram XG3980
Re: Striker fired pistol? [Re: Camprunner] #4443939
06/28/17 01:57 PM
06/28/17 01:57 PM
Northern Kentucky
901Memphis Offline
901Memphis  Offline
Northern Kentucky
Skip about 3 minutes if you want to see the striker in action but the whole video is interesting.
Re: Striker fired pistol? [Re: 901Memphis] #4444177
06/28/17 06:27 PM
06/28/17 06:27 PM
Elizabethtown, Pa
Al Offline
Al  Offline
Elizabethtown, Pa
Very cool..thanks to much!!
Re: Striker fired pistol? [Re: Panzerman] #4444510
06/29/17 03:50 AM
06/29/17 03:50 AM
Chadds Ford
Toros Offline
Toros  Offline
Chadds Ford
Just no.
Re: Striker fired pistol? [Re: Camprunner] #4452974
07/08/17 02:06 AM
07/08/17 02:06 AM
California, USA
SouthEndCrusher Offline
California, USA
Yes, the Glock pistols do have a firing pin safety. The pistol was designed with three passive safeties: Trigger Safety, Firing Pin Safety and the Drop Safety. All three make up the Glock's "Safe Action System."
Re: Striker fired pistol? [Re: Toros] #4453033
07/08/17 05:30 AM
07/08/17 05:30 AM
Indianapolis, IN
dnewton3 Offline
Global Moderator
dnewton3  Offline
Global Moderator
Indianapolis, IN
Just no.
I can only hope he was kidding.
Because WOW ...
Or course, it might be similar to the planetary gears in my AR trigger?
grin2
The act of preventative maintenance, in and of itself, is FAR MORE important than brand/grade/base choices among lubes and filters.
- under maintaining something is akin to abuse/neglect; that can kill equipment by shortening the lifespan
- over maintaining something has never been proven to be anything but a waste of time and money
Re: Striker fired pistol? [Re: dnewton3] #4453373
07/08/17 12:19 PM
07/08/17 12:19 PM
South Florida
bubbatime Offline
bubbatime  Offline
South Florida
Planetary gears huh? And all this time, I thought they looked more like cog gears with some kind of block and tackle.
17 Chrysler Pacifica Edge Syn 5W30
13 Yamaha XT250 Valv MC 10W40
10 Acura TSX 2.4 SuperTech Syn 5W20
06 GMC Sierra SuperTech 10W30
Re: Striker fired pistol? [Re: bubbatime] #4453446
07/08/17 01:51 PM
07/08/17 01:51 PM
Georgia, USA
HouseTiger Offline
HouseTiger  Offline
Georgia, USA
I think he's referring to the new interlocking granistan joint in the disconnector. The only new principle involved is that it's produced by the modial interaction of magneto-reluctance and capacitive duractance. The original disconnect and safety mechanism had a base plate of pre-famulated amulite surmounted by a malleable logarithmic casing in such a way that the two spurving bearings ran in a direct line with the panametric slide.
The line-up consisted simply of six hydrocoptic marzul vanes so fitted to the ambaphascient striker shaft that side fumbling was effectively prevented. The main winding was of the normal lotus-odeltoid type placed in panendurmic semi-bulloid slots of the striker sleeve, every seventh conductor being connected by a non-reversible tremmy pipe to the differential girdle spring on the up-end of the trigger return.
Moreover, whenever fluorescent skor motion for sighting is required, it may also be employed in conjunction with the drawn reciprocation dingle arm, to reduce sinusoidal depleneration.
bop
