PZ 37 CUT OPEN
by 53' Stude. 03/20/19 06:42 PM
Lube Intervals
by NibbanaBanana. 03/20/19 06:41 PM
When to send in oil for testing?
by SnowDrifter. 03/20/19 06:12 PM
ATF vs CHF
by GG16v. 03/20/19 05:40 PM
Landline Answering Machines
by das_peikko. 03/20/19 05:10 PM
Mobil oil on “clearance” at Target
by WiskyBadger. 03/20/19 04:04 PM
Master Mechanic Motor Oil @ True Value
by CG_BrianM. 03/20/19 01:35 PM
Some cars haven't changed much in 30 years...
by addyguy. 03/20/19 01:16 PM
Super Knock - Engineering Explained
by StevieC. 03/20/19 01:11 PM
Mobil Super Synthetic Clearance at Meijer
by Tjbouwhu. 03/20/19 12:53 PM
FYI: Costco is now stocking the 'good' Techron
by mbz321. 03/20/19 12:32 PM
Auto maintenance advice from a locksmith?
by Variant_S. 03/20/19 12:18 PM
Purolator 12 Pack L25608 $21
by hatt. 03/20/19 12:04 PM
Dealer service and franchise laws.
by BMWTurboDzl. 03/20/19 11:46 AM
Tie rod tapers
by LeakySeals. 03/20/19 11:26 AM
Quality Lug Nuts
by jcartwright99. 03/20/19 10:56 AM
More than one Reality
by beanoil. 03/20/19 10:50 AM
Reusable Oil Storage Container
by BamaE92. 03/20/19 10:37 AM
GG16v, fleetwood62, varalakshmi, AllyMac, Saxman657
67569 Registered Users
130 registered members (01rangerxl, 2015_PSD, 2009Edge, 15 invisible), 1,997 guests, and 61 spiders.
Topics286,162
Posts4,903,342
Members67,569
Most Online2,967
Mar 10th, 2019
Page 1 of 3 1 2 3
Fuel Pump Maintenance Tips #4442800
06/27/17 01:13 PM
06/27/17 01:13 PM
Mississippi
Speak2Mountain Offline OP
Mississippi
Give me some tips (aside from keeping gasoline levels up)on maintaining FP
Re: Fuel Pump Maintenance Tips [Re: Speak2Mountain] #4442810
06/27/17 01:18 PM
06/27/17 01:18 PM
San Antonio, TX
E150GT Offline
E150GT  Offline
San Antonio, TX
Probably not much
1984 Mercedes-Benz 300SD - 100k
1995 F150 XL 4.9 reg cab 5MT - 251k 5w30
2016 Mazda6 Touring 6MT - 57k 10w30
2006 Buick Lucerne CXL 3.8 31k 5w30
Re: Fuel Pump Maintenance Tips [Re: E150GT] #4442815
06/27/17 01:23 PM
06/27/17 01:23 PM
The Northeast
mclasser Offline
mclasser  Offline
The Northeast
Originally Posted By: E150GT
Probably not much
True
2018 Hyundai Elantra VE
2013 Honda Pilot EX-L 4WD
2002 Honda Accord EX-L
Re: Fuel Pump Maintenance Tips [Re: Speak2Mountain] #4442838
06/27/17 01:45 PM
06/27/17 01:45 PM
Boise, Idaho
MRtv Offline
MRtv  Offline
Boise, Idaho
Actually one of the main reasons I use MMO in my fuel. My fuel pump is in the fuel tank and replacing it will be a problem if I ever have to. So I use MMO to lubricate the pump and hopefully, I say hopefully, never have to worry about it.
2014 Nissan Versa Note 1.6 liter engine. 1997 Ford F150 4x4 4.6 liter engine.
Re: Fuel Pump Maintenance Tips [Re: Speak2Mountain] #4442852
06/27/17 01:58 PM
06/27/17 01:58 PM
Somewhere
itguy08 Offline
itguy08  Offline
Somewhere
Nothing. Not even "keeping gas levels up". May have helped in the past (but doubtful) but as long as you don't run it out of fuel there is always something cooling the pump.
Re: Fuel Pump Maintenance Tips [Re: Speak2Mountain] #4442854
06/27/17 01:59 PM
06/27/17 01:59 PM
Northern Kentucky
901Memphis Offline
901Memphis  Offline
Northern Kentucky
Shell gas if you can afford it.
2012 Chevy Cruze LT 1.4T - 59k - Edge 0w30 SL + Mahle OX401D
2002 Buick Century 144k - Built 4T65e(Maxlife) - GTX 5w30 + Fram XG3980
Re: Fuel Pump Maintenance Tips [Re: Speak2Mountain] #4442883
06/27/17 02:41 PM
06/27/17 02:41 PM
Upstate NY
Donald Offline
Donald  Offline
Upstate NY
Forget the MMO for almost anything.
Fuel pumps fail due to lack of cooling. Fuel running through the pump cools it. Suck air and no cooling, possible fuel pump damage.
To avoid fuel pump failures avoid GM vehicles around 1993.
2015 Ford F250 w/Powerstroke
Re: Fuel Pump Maintenance Tips [Re: Donald] #4442904
06/27/17 03:09 PM
06/27/17 03:09 PM
PV Az @ 5000'
AZjeff Offline
AZjeff  Offline
PV Az @ 5000'
Not hard to do really....
86 Samurai 1.3 leftovers
14 RAV4 2.5 5W-20 PP
16 Silverado 1500 4.3, DI, AFM 5W-30 PP
The most important thing to do in your life is to not interfere with someone else's life. - Frank Zappa
Re: Fuel Pump Maintenance Tips [Re: Speak2Mountain] #4442911
06/27/17 03:17 PM
06/27/17 03:17 PM
Waco, Tx.
Syntheticuser Offline
Waco, Tx.
I never run less than 1/4 tank. I ALSO recommend that you change your fuel filter if it has one. The posts above me did not mention it. I can watch the duty cycle of the fuel pump on my vehicles through TP. I have watched it drop by 15% JUST changing the filter. I'm sure it runs hotter on a restricting filter. ...it will push and push trying to Maintain a set pressure, drawing more current little by little and burn itself out when the filter restriction gets to much.
PS the only data I have to back this up is the duty cycle numbers from the TP app. I know some of you guys will try to shoot holes in my theory and not have a valid reason. My numbers are at 105k miles DC = 47%. New filter DC =31%. Same conditions...same day.. just changed the filter= less load on the pump.
Re: Fuel Pump Maintenance Tips [Re: Speak2Mountain] #4442920
06/27/17 03:28 PM
06/27/17 03:28 PM
Upper Midwest
kschachn Offline
kschachn  Offline
Upper Midwest
As others have mentioned I also don't think the "keeping the tank above 1/4" has anything to do with it. My custom is to run right down to empty virtually every time, and my fuel pumps are fine.
1994 BMW 530i, 241K
1996 Honda Accord, 267K
1999 Toyota Sienna, 409K
2000 Toyota ECHO, 280K
Re: Fuel Pump Maintenance Tips [Re: Speak2Mountain] #4442938
06/27/17 03:46 PM
06/27/17 03:46 PM
San Antonio, TX
E150GT Offline
E150GT  Offline
San Antonio, TX
I run down to the point where the light comes on in the Mazda. The truck I don't mess around with because I don't trust the 22 year old fuel gauge. I hate being stranded and I really hate being stranded for dumb reasons.
Re: Fuel Pump Maintenance Tips [Re: Speak2Mountain] #4442960
06/27/17 04:11 PM
06/27/17 04:11 PM
Specific Ocean
Kibitoshin Online content
Kibitoshin  Online Content
Specific Ocean
Plan to change fuel pump as PM. The OEM fuel pump in my 02 Silverado went out at 98,000mi during a mission critical job so I threw in another OEM pump and plan to replace it at 190,000mi. Also replace fuel filter every 3 years.
Shin Gekiretsu Shin'ou'hou
01 Toyota Tundra 2WD V8 4.7L
02 Chevy Silverado C1500 V8 5.3L
Re: Fuel Pump Maintenance Tips [Re: MRtv] #4442998
06/27/17 05:14 PM
06/27/17 05:14 PM
Elizabeth. Colorado
c502cid Offline
c502cid  Offline
Elizabeth. Colorado
+1!
16 Ford F150 2.7 Ecoboost 4x4
15 Chev Trax AWD
02 GMC 3500 8.1/Allison Dually 4x4
00 Blazer 4.3 4x4
97/98 Honda Civics
84 Chev K30 454EFI/T400/NP205 Dually 4x4
71 GMC Jimmy 502 RamJet/T400/NP205 4x4
Re: Fuel Pump Maintenance Tips [Re: Speak2Mountain] #4443002
06/27/17 05:17 PM
06/27/17 05:17 PM
Katy, Republic of Texas
blupupher Offline
blupupher  Offline
Drive it till it fails.
2018 Hyundai Santa Fe: Delo XLE 10w-30, OEM filter, 3k
2012 Scion xB: QSUD 0w-20, CQ Blue, 5k
2002 Ford F150: Magnatec 5w-20, Bosch D+, 1yr
1994 Honda VT1100: Peak 15w-40, PSL, 1yr
Re: Fuel Pump Maintenance Tips [Re: Speak2Mountain] #4443086
06/27/17 06:58 PM
06/27/17 06:58 PM
Toronto
PeterPolyol Offline
PeterPolyol  Offline
Toronto
TWC-3 at ridiculously dilute ratios.
There's no replacement...'scosity for natural viscosity
Page 1 of 3 1 2 3
