Anyone "Wim Hof"ing ?
by Shannow. 09/21/18 02:35 AM
New R1250GS and R1250RT
by 02SE. 09/21/18 12:55 AM
Inside Break Booster & Master Cylinder
by StevieC. 09/20/18 11:22 PM
Inside an Alternator
by StevieC. 09/20/18 11:18 PM
What vehicles are you using Maxlife ATF in?
by BlakeB. 09/20/18 11:10 PM
How a Power Steering Rack Works (Electronic)
by StevieC. 09/20/18 11:00 PM
How a Power Steering Rack Works (Hydraulic)
by StevieC. 09/20/18 10:58 PM
silly wiper problem
by bowlofturtle. 09/20/18 10:33 PM
Canadian Tire Shell Rotella T-6 in Pails
by Snagglefoot. 09/20/18 10:04 PM
Best diesel fuel for cold weather?
by Dickm. 09/20/18 10:03 PM
Type 1 Diabetics - New Research
by StevieC. 09/20/18 10:00 PM
Tire Sizing and Options
by NewEnglander. 09/20/18 09:59 PM
2013 Scion FR-S | Transmission Fluid Questions
by nicknak. 09/20/18 09:47 PM
Meguiar's Liquid Cleaner Wax $5 WalMart, Amazon
by The_Cams. 09/20/18 08:42 PM
Winter oil recommendation
by Neptune. 09/20/18 08:27 PM
M1 0W-40
by CT8. 09/20/18 07:37 PM
What controls timing on my 08 Honda?
by Roland. 09/20/18 07:23 PM
The real culprit about 18k
by Ablebody. 09/20/18 06:04 PM
Direct_Rejection, donatom, Sylent_Snyper, Ajizzle, nicknak
66033 Registered Users
22 registered members (Billbert, Bailes1992, Bman90, 2015Corolla, bmod305, Char Baby, 1 invisible), 755 guests, and 37 spiders.
Topics290,745
Posts4,849,456
Members66,033
Most Online3,590
Jan 24th, 2017
T-Minus 10 Days to Adventure #4442725
06/27/17 11:52 AM
06/27/17 11:52 AM
Philadelphia PA
SKVenture Offline OP
Philadelphia PA
In 10 days time, my wife and I are driving from Philadelphia to Colorado and Utah. We plan to visit some of the most extreme and remote locations the continental United States has to offer. Thanks BITOG for the tips and info as we have just finished all of the maintenance on our 2000 Toyota 4Runner which has 170,500 miles on the clock as of today!
Here is a teaser we put together. Keep an eye out for short vids while on the road and more competed movies afterwards as we document our journey!
Re: T-Minus 10 Days to Adventure [Re: SKVenture] #4442729
06/27/17 11:55 AM
06/27/17 11:55 AM
Colorado Springs
Drew99GT Offline
Drew99GT  Offline
Colorado Springs
Awesome! Where are you going in Colorado??? Just an FYI, we still have a lot of snow pack in the high country, so don't push your luck too far in the high mountains...
Re: T-Minus 10 Days to Adventure [Re: Drew99GT] #4442735
06/27/17 12:04 PM
06/27/17 12:04 PM
Philadelphia PA
Philadelphia PA
We are doing the southern half of Colorado. Planning on hitting the Ouray and Telluride areas. We are *hoping* the passes are opened by the time we get there on July 10th. Imogene and Black Bear where both high on our wish list!
Like you said, the area has been slammed with snow. So we will see. . . Some of the lower passes have been officially opened so we are keeping our fingers and toes crossed!
Re: T-Minus 10 Days to Adventure [Re: SKVenture] #4442777
06/27/17 12:51 PM
06/27/17 12:51 PM
Austin, Texas
Brons2 Offline
Brons2  Offline
Austin, Texas
Might want to consider an intake snorkel as a future modification? You were in some pretty deep water in that video. I'd hate to see you get hydrolocked out in the sticks. Your connecting rods will compress before water in the combustion chamber does.
2012 Hyundai Sonata GLS 6MT 2.4GDI, ProDS 10w30, XG9688 filter, 2018 Mitsubishi Outlander SEL 2.4 CVT, Factory fill still.
Re: T-Minus 10 Days to Adventure [Re: SKVenture] #4442783
06/27/17 12:56 PM
06/27/17 12:56 PM
Fort Worth TX
TheKracken Offline
TheKracken  Offline
Fort Worth TX
What sort of maintenance did you do? I ask because I am tearing into my truck with the same drivetrain, also before a overlanding trip.
2011 Prius 96k miles RLI 5w20
97 Toy T100 4x4: amsoil 0w20 242k Miles
04 Toy Sienna awd: Pennzoil 0w20 281k Miles
Re: T-Minus 10 Days to Adventure [Re: Brons2] #4442803
06/27/17 01:14 PM
06/27/17 01:14 PM
Philadelphia PA
Philadelphia PA
While not for this trip, a snorkel is definitively in the cards for coming months, in adition to raised Diff breathers.
That said, we where in some deep water with the axle well submerged. I did a drain and fill of the diffs a few weeks after that trip and the oils where crystal clear so no water snuck in!
Re: T-Minus 10 Days to Adventure [Re: TheKracken] #4442841
06/27/17 01:48 PM
06/27/17 01:48 PM
Philadelphia PA
Philadelphia PA
If it could be replaced or serviced; we did it.
We spent $4000 on the truck and easily double that in maintenance and upgrades. So it is definitely not the cheapest option to keep these old trucks on the trails long term. But we would not have it any other way!
We bought the truck with 143,000 miles on it last year. It ran great except for a leaking steering rack.
In the past 6 months we:
1. Changed the spark plugs and wires (NGK)
2. Replaced the entire rack and pinion along with inner and outer tie-rods
3. Replaced the lower ball joints with TOYOTA OEM
4. Replaced the Radiator, Belts, and Hoses with TOYOTA OEM.
5. Replaced the Timing Belt, Water Pump, Thermostat, Cam seals, ect. with TOYOTA OEM
6. Replaced the front brakes (Calipers, Rotors, and Pads) with bigger/beefier TUNDRA Front Brakes
7. Replaced rear brake shoes
8. Replaced TPS sensor
9. Cleaned MAF Senors and Throttle Body
10. Replaced all filters including air, fuel, and transmission.
11. Drained and refilled transmission 5x to evacuate old fluid without a "Flush"
12. Bled and flushed brake system with DOT 4 Fluid.
13. Replaced Left and Right Front CV Axles
14. Upgraded suspension to Old Man Emu Springs and Bilstein 5100 Shocks/Struts
15. Brand New BFG Mud Terrain Tires
16. Obviously I have been changing the oil regularly! (RED LINE 5w30)
17. Road Force Balance and Wheel Alignment
18. New extended rear sway bar bushings and links
19. Over the past 5 months I have ran a fuel system cleaner every month. (Changed brands each time so it has seen Redline, Royal Purple, Techron, Lucas Deep Clean, and Gumout Regane)
20. Serviced drive line and greased u-joints every oil change
21. Replace muffler with Flowmaster 60 series
22. Drain and re-fill rear and front diffs as well as the transfer case
23. Flush and fill new Toyota OEM coolant
24. Im sure I am forgetting something and will edit it in later!!!
Soooooooo yea! It was definitely a labor of love!
These trucks are just so well made. Friends and family look at me crazy when I say that considering what I have put into it.
But these trucks have amazingly reliable engines and transmissions. As long as they have been maintained well, are in excellent working order, and the frame of the truck is not rotted out; they are worth fixing IMHO.
For your truck, I would strongly recommend the lower Ball Joints and Radiator as they are the two known killers of our trucks.
The lower ball joint design leaves alot to be desired. Should they fail, the lower control arm slams to the ground and the wheel tucks neatly into the wheel well allowing for the perfect opportunity to flip the vehicle at any common cruising speed.
Regardless of condition, it is strongly recommended by the community as a whole to replace at least every 100,000 miles with ONLY Toyota OEM units.
The Radiator is a dual chamber design that has a main chamber for coolant and small chamber for the trans fluid. Over time the metal inside **can** corrode and allow the trans fluid and coolant to mix. This allows for the infamous "pink milkshake" where the fluids create a foam that completely destroys your transmission.
Some elect to separate the coolers and add a independent trans cooler. Most other just plan to change out the radiator along with the lower ball joints every 100,000 miles to prevent it from ever happening.
If you have any questions, please feel free to ask!!!
Re: T-Minus 10 Days to Adventure [Re: SKVenture] #4443329
06/27/17 11:51 PM
06/27/17 11:51 PM
Michigan
daves87rs Offline
daves87rs  Offline
Michigan
Lots of fun!
Coming together is a beginning; keeping together is progress; working together is success.
Henry Ford
