BMW V8 Oil Consumption Fix
by doc540
47 minutes 26 seconds ago
More info on Valvoline Modern Engine Oil
by buster
Today at 11:07 AM
Shelf life of synthetic 2 stroke engine oil ?
by ScottMill
Today at 10:34 AM
Oil sample extraction
by Tikka
Today at 10:30 AM
Re-using building materials esp nails
by andyd
Today at 08:57 AM
Central A/C [censored] out
by TOMJ
Today at 08:43 AM
08 Scion tC under valve cover pics
by Highboy
Today at 08:39 AM
Storing extension ladded in garage?
by maverickfhs
Today at 08:27 AM
Do you let your tool batteries go dead in storage
by Snagglefoot
Today at 07:20 AM
Any news on what happened to this plane?
by Exhaustgases
Today at 02:36 AM
E4OD fluid ?
by Exhaustgases
Today at 02:23 AM
Update password ?
by meadows
Yesterday at 11:59 PM
Delayed Sleep Phase Disorder
by Reddy45
Yesterday at 11:56 PM
Nissan DLR put 0w20 in car that specs 5w30. worry?
by CrAlt
Yesterday at 10:40 PM
revive Nicd battery
by Donald
Yesterday at 10:27 PM
Need help finding an apartment for friend
by RazorsEdge
Yesterday at 10:07 PM
ceratec with redline 5w30?
by 08z06
Yesterday at 09:53 PM
does your COMCAST modem have weak wifi??
by edwardh1
Yesterday at 09:50 PM
I hate stuck thermostats
by jakewells
Yesterday at 09:49 PM
Mag1 75w90
by SavagePatch
Yesterday at 09:32 PM
WtsTacoma01, Orion62, Revd, blinky1041, mostdecent
65262 Registered Users
93 registered (1JZ_E46, AndyB, aquariuscsm, 5AcresAndAFool, 4WD, Artem, 10 invisible), 1664 Guests and 46 Spiders online.
65262 Members
67 Forums
285519 Topics
#4442600 - 06/27/17 08:43 AM 73-74 Torino's Havoline 30wt
gmh101357 Offline
Loc: Phoenix AZ
My father co-owned biz when I was a teenager where they bought 6 4 door grand torino's with 351 2bl
and 3 74 torino 2 door 351 2bl as company cars along with a dozen econoline vans and few f-100 trucks.
at 45k to 50k miles 3 torino's blew the engines...my father was good friends the the owner of the Ford dealer who had to replace them and after the they swap-out motor's they told my father only use Havoline 30wt oil in the cars. So my father went on the Havoline 30wt kick and put it all the the company cars and vans etc...changed every 3k miles
My brother worked for Halliburton in 75 and was told the exact same thing in his 74 torino my Halliburton only use 30 wt Havoline.
My friend in Mustang club bought a 73 2 door Torino 351 4bl that he is rebuilding and told him the story from 40 years ago. Has anybody else ever heard of this?
Oh it was a 351 Widsor's that blew not Cleveland
Edited by gmh101357 (06/27/17 08:44 AM)
#4442605 - 06/27/17 08:48 AM Re: 73-74 Torino's Havoline 30wt [Re: gmh101357]
addyguy Offline
Loc: Canada
Havoline has always been a good oil.
Back in the day, multi-viscosity oils weren't the best, so yeah, in a warm climate a straight grade would probably hold up better to hard use.
2010 Kia Soul 2U - 2.0L I-4, auto; 126k miles.
M1 EP 10W-30; OEM Kia filter.
#4442699 - 06/27/17 11:04 AM Re: 73-74 Torino's Havoline 30wt [Re: gmh101357]
Superflop Offline
Loc: Seattle
Before i switched to using synthetics (which was due to havoline becoming scarce) all i used was that oil and i mainly had Fe and 90V ford engines. I used 10w30 however and never had a problem, oh yeah lol, with fram filters also. Still use fram but havent not so much the havoline.
2002 saab 9-5 2.3t wagon
2014 dodge grand caravan
#4442753 - 06/27/17 12:29 PM Re: 73-74 Torino's Havoline 30wt [Re: gmh101357]
andyd Offline
Loc: Marshfield , MA
I had a '73 Gran Torino Squire Wagon with a 351 Cleveland/ C4. My then 2yr old would say "make it go Dad" and I'd stomp it into passing gear. My favorite V8 even with just a 2150 carb. grin2
Thick oil is better grin2
#4442758 - 06/27/17 12:32 PM Re: 73-74 Torino's Havoline 30wt [Re: gmh101357]
Red91 Offline
Loc: Alabama, United States
Havoline 30wt is still a good choice for those cars. 30wt is my go to grade. If you have a fresh or radically cam'd engine, it wouldn't hurt to add a zinc additive.
'89 Chevy 1500
Napa 20/50
'15 Chevy Cruze
AcDelco syn dexos 5/30
#4442839 - 06/27/17 01:46 PM Re: 73-74 Torino's Havoline 30wt [Re: gmh101357]
HangFire Offline
Loc: Central Maryland
I've heard talk of a bad batch of VII in 10w-40's back in the day, that killed a lot of engines. Or maybe your Dad just got a bad batch of Ford engines.
Also Ford 351 Windsors back then would die after one overheat because of the nylon/steel composite timing gear. I know, happened to mine. I replaced the timing gear with an all-steel one and drove another 100K. Other than that they were good, but unremarkable engines, hobbled as all Fords were back then by tiny exhaust ports in the heads.
Various musings: http://hangfire.net
#4443551 - 06/28/17 08:49 AM Re: 73-74 Torino's Havoline 30wt [Re: gmh101357]
steve20 Offline
Loc: Morris County NJ
A beige/sand colored 73 Torino 4 door was our driver's ed car. I think it had a 302 though
Steve
#4443592 - 06/28/17 09:31 AM Re: 73-74 Torino's Havoline 30wt [Re: gmh101357]
FordCapriDriver Offline
Loc: Balearic Islands , Spain
Nowadays probably the best readily available oil for any kind of old flat tappet engine is a 10W-30 or 15W-40 HDEO, some engines have racked up huge mileages on cheap mix fleet HDEOs.
1975 Ford Capri II Ghia 3000 V6, - Valvoline VR1 20W-50
1988 Ford Escort MkIV 1.6 Xr3i Cabrio, - Shell Rimula R4X 15W-40 HDEO.
#4443603 - 06/28/17 09:42 AM Re: 73-74 Torino's Havoline 30wt [Re: HangFire]
My Capri's British Essex V6 also has a nylon toothed timing gear, but these engines don't have a timing chain, there is a small gear on the crank and a really big oe on the cam, i plan on putting a steel one in at some point, mine never overheats and hasn't in many years, and at 100k+ miles it runs good.
