Moments from disaster.. share your stories
Ohio
We've all had our share of automotive "uh oh" moments where disaster was just a second away, but it was narrowly averted. For example, peeking under the hood of a car with failing hood lift struts - you have your head buried in the engine bay in a pretty compromised position, then get up to grab a tool or something. Moments later, the hood slams shut. That sort of thing. I've had a couple pretty serious moments I wanted to share.
Many years ago. Young and even more ignorant than I am today. I'm driving around in my turbocharged NA-T Toyota Supra. I turbocharged it myself using bits and pieces of the turbo model's parts, but with lots of piping components from Home Depot. Well, an intercooler hose popped off a piece of 90 degree Schedule 40 intake charge pipe. The car started stalling, so I pulled into a parking lot to get the hose back on.
Well sir, the pipe was only accessible from underneath the car, so I set the parking brake, put the car in gear, and jacked it up with a tire jack. Then I stuck my head underneath :)doh:) the car and started wrenching. Not long into the repair, I noticed the car making sporadic creaking noises. Creak. Creeeaaak... creaak.. So I got up out of there just in time to watch the car roll over the spare jack. Yeah, I learned something that day.
Another instance, I had a project supercharged Lexus. I started noticing a fuel smell while idling. I thought nothing of it at first, but after a few days I decided to pop the hood to investigate closely. And there I saw it... right off the rising rate fuel pressure regulator's inlet hose barb, gasoline was dripping.... right onto the exhaust manifold heat shield.. and boiling off on the spot.
In about zero seconds flat I turned the car off and tightened the hose clamp. That could have ended differently.
These days I don't modify cars anymore, they're fast enough for me stock. So life is quite a bit less dramatic on the road.
Any similar stories you'd care to share?
Not really related to me but about 10 years ago I was living in Missouri. I was on my way home from a hardware store and they had this little Honda in front of me. About 30 seconds later I see a tire roll off the car and the car slides into a deep ditch.
Had 2 kids and a girl in it probably 16 or 17 but I asked them what happened and they said they where driving home and while on the interstate the steering wheel had a lot of play in it. They stopped a few times but nothing looked obvious to them so they got back on the road.
The driver didnt know what was going on so they decided to get off the interstate and take a back road home. From what they said they got off the interstate about 2 mins before the wheel came off.
It was rush hour traffic tho, everyone in the car was fine and the vehicle didn't take any noticeable damage and we where able to pull it out of the ditch and find all the lug nuts on the road and got the tire back on before the cops showed up (freshly paved road) and their rotors carved up the asphalt pretty well.
I've thought about it a few times over the years. Being rush hour traffic and all. The area always have 18 wheelers and between that or them sliding into another vehicle someone could have probably lost their life if that happened at 75mph vs the 25 of the back road...
I bought a better turbo from a friend for my 2000 Dodge diesel, and he helped me do the swap. Unfortunately he got distracted at one point, and I never went back and checked all the oil line fittings for tightness. I was almost home when I noticed my oil pressure dropping fast, and I noticed the trail of oil I was leaving down the road. I threw it in neutral and coasted into the nearest driveway. My friend hadn't tightened the bolts for the oil drain hose, and I blew about 10 quarts of oil all over the road. Thankfully I noticed it in time and no known engine (or turbo) damage resulted.
Another time, my wife and I drove down to the lower 48 in my older 1992 Dodge diesel, and pulled into a little truck stop at a place called Amargosa Valley NW of Las Vegas. I pulled into the parking spot and noticed the coolant temp gauge was abnormally high, so I turned the heater on full blast while it idled to try to help it cool down. Unfortunately the heater was blowing cool air, so I immediately shut down the engine. Turned out my water pump was toast and it must've blew out the coolant right before we turned into the truck stop. Again, no damage because I caught it in time.
I try and pay better attention to my gauges these days.
I have a folding engine hoist. I store it by leaving the crane part vertical, then pull the pins for the legs, fold them up too. Normally I secure the legs but I was doing engine-y work and thought I'd need them again. Had one of the heavy metal legs whiz by an inch from my ear/ head. Felt the breeze.
Replaced the belt and tensioner on my Liberty a few weeks ago, had to take out the mechanical fan and efan plus the shroud. Got it all back together, no issues. Had a random thought the next day, did I reconnect the efan? Checked it after running an errand and no I did not!. So thankful it was in the 60s and I didn't have the AC on. Would've been replacing an engine otherwise from over heating.
You'd have been fine with just the mechanical fan. The e-fan is to boost AC performance.
On a 250 mile or so drive a couple of years ago with wife, son, DIL and then about five month old grandson, disaster struck in the form of a serious oil leak. We had stopped in a rest area and my son remarked upon the brownish spots on the rear surfaces of the '12 Accord. I had a good idea of what this had to be. I checked the oil and it was more than a quart down. We drove to the next exit and I bought a few quarts of Kendall SB in a 10W-40, added one, ran the engine briefly and allowed it to sit for a couple of minutes before again checking the oil. The stick showed midway between the add and full marks, so I dumped another quart in. We stopped every fifty or so miles thereafter and I added another three quarts en route.
We made it to my mother's house in Rocky River, a west suburb of Cleveland without incident so she got to see her first great-grandchild.
I was meanwhile on the AAP site gathering what I'd need to get under the car and change the oil, particularly the oil filter, a white-body K&N that had a gasket failure, just as I suspected.
Anyway, my various sisters gathered, I changed oil and crusty with leaked oil filter while I marveled at the fine job of rustproofing the oil spray had done for the bottom of the Accord.
All turned out well, but only because my son had noticed the tiny specs of oil on the rear of the car.
OK, Close Shave Story.....um...bit spoilt for choice, but I find this one hard to forget.
1800 Marina estate. Filled up on the way home and the smell of petrol seemed more persistent than usual. Actually stopped to check, but it was dark and (of course) [censored] down and I couldn't see anything. Home late and forgot about it.
Next day woken by nosey neighbour who complains my car is leaking petrol down the street. Indeed. ALL the way down the street gutter, under lots of much shinier cars.
What to do? Have a couple of large jerricans, but have learned that siphoning petrol out of a tank really only works well in the movies. Decide to remove the tank and decant petrol directly.
Lying under the car in a small river of petrol, I'd unbolted the (still almost full) leaking tank and lowered it onto my chest, where it was soaking my overalls, and had just started to wriggle out with it, when the nosy neighbour (who'd complained about the leak in the first place) stuck her head down over the gutter to check on progress.
Did I mention she was a CHAIN SMOKER?
I couldn't look at first.
Then I looked and couldn't speak.
Then I spoke, but I had to be VERY polite to avoid agitatating the STUPID COW, since the ash didn't look very stable.
One of my nearer death experiences.
Two goof ups I can remember.
Changing the oil in my 3000GT. I "splurged" and bought Castrol Syntec. I was pouring the oil in and with each quart,I noticed this weird splashing sound but didn't think much of it. Finished pouring the last quart and I just had to find out what that splashing sound was. I'd forgotten to put the drain plug back in and all that expensive synthetic oil went into the oil fill hole,right out the drain plug hole,and into the drain pan haha.
Another oil change goof up. I was changing the oil in my 300ZX. I figured I'd have a few coldies and make a fun day of it haha. By the time I finished the oil change and got her all buttoned up,I was lit to the max!! I got in my car to back it off the ramps and noticed this weird grinding sound. I'd forgotten to take the drain pan out from under the car and dragged it all the way down the driveway and into the street,leaving a messy trail of used oil with it haha. Good lord! Yeah,I had WAY too much fun doing that oil change!
Interesting thread.
A number of years ago back in the Seattle area, we lived SE about 30 miles. A winter storm dumped a foot of snow in quick time and my wife was working at WalMart on top of a hill. I picked her up around 10pm in the trusty Mitsubishi Montero Sport with 4wd. We made it down a long freeway hill before they closed it as it was solid ice and then drive a two lane highway back home. Along the way on a curve, it appeared a woman had slid her Honda into the ditch. Another car had stopped and a man was getting out of the driver's door to help. I was doing about 15mph and that guy slipped and fell into the highway right in front of me. I jerked the wheel to the left since there was no incoming traffic and went right around him. I was waiting for that dreadful bump but we missed him. It could not have been by more than a foot or two. I swerved back into the right lane before traffic came and saw him getting up.
I was shaking for a couple of hours after that. I couldn't sleep that night either. I wonder if that guy had to empty his pants?
Haha AWESOME story!!
I can just see her peering her face under your car to start yacking and you're ready to freakin kick her a**! Haha!
Did 4-6 full spins on I93 in terrible winter conditions near Boston during rush hour and hit no one and no one hit me and recovered and kept going speed limit....stunned.
1) My dad had an 30 year old pair of metal car ramps. Sturdy as all get out. Not even 5 seconds after I was done with the oil change, and crawled out from under the car, the car came slamming down, crushing both ramps.
2) While driving, pulled out onto a two lane highway and a semi comes out of nowhere doing like 110mph and almost cleans my clock as it swerves into the other lane. Don't know why he was going that fast, or where he came from. Never saw him until he was flying by me.
3) Working in a prison, escorting one of the most dangerous death row inmates in all of Florida. He is fully shackled, legs, arms, and belly chain. Walking down a hallway, and as if a switch is hit, ALL of his chains fall to the floor. His leg shackles, handcuffs, and belly chain, every last one of them just fall off of him to the floor. The inmate stands there staring at us completely unshackled, and us staring at him. Amazingly, he just shrugs and we put the chains back on without any fight. I dont know how it happened, or why it happened, as everything was inspected afterwards and found to be in good condition.
4) Working in a prison, life sentence inmate who doesn't really care for me, ambushes me in a hallway with a punch to the face. In a split second, I deflected the punch with my left arm, and delivered a most appropriate uppercut with my right arm. He is immediately rendered unconscious. As I am cuffing him, I see that he has a 7 inch shank in his hand. He was attempting to stab me in the face, not punch me. I was micro-seconds from serious injury or death.
In my Iraq deployment from 2008-2009, I was on a Military Transition Team (MiTT) where ten mostly senior guys lived, ate, and shot the **** together for over 15 months together.
Our main "job" was to train and advise an Iraqi army brigade, which meant we also lived, ate, and **** the [censored] with them. We mostly provided oversight along with the Iraqi brigade staff when we went out on patrol, raids, etc... But there were plenty of close calls, especially when the rounds started flying.
But the one that I always think about was the one were NOTHING happened to us. We had left our Combat Outpost (COP) and headed for a small town (name withheld), controlled by the Kurds, a roughly 20 mile one way trip. Nothing happened on the way there or on the way back, but it was the phone call we received the next day.
The local U.S. unit's intel folks gave us a call and asked if we were the unit that traveled to and from that area the previous day. They the informed us that they intercepted communications from the local IED cell leader's phone, and apparently he was pretty upset. The command wire trigger guy was not at this post when we traveled through the area, and therefore were not on the business end of three daisy chained 155mm deep buried artillery shells under the road. We had just received our MRAPs about a month prior, but three 155mm shells daisy chained together would at the very least rung our bell, but most likely would've killed us.
EOD folks were called in a day or two later, located the IED, and neutralized it.
I should be dead four or so times over by now but I'm just happy that me and my team made it out of Iraq all alive and well, but we had plenty of CLOSE calls.
Years ago I had a water well drilling business. I got hired to clean a well. Went in with a sand pump (sorta like a bailler) and pulled a few plugs from the bottom. On the 3rd trip I'd jus got the tube above the table when the hoist line let go. 1000lbs of steel & sand/water came crashing down inches in front of me, missed going down the hole, did a bounce off the table and made a pirouette before heading aft. I was inches from being wiped out.
In November of 2014 I was driving in a snow storm early in the morning to get to work for a meeting. I was on the highway going pretty slow when I came around a bend and hit a very large patch of ice. I went into a spin and there was nothing I could do. Thankfully there were no cars near me! I ended up loosing control and spun off of the highway. I went off a good 10 to 15 feet and hit a bunch of little trees with the side of my truck before coming to a stop about 6 inches from the edge of a 10 foot drop off into the river! I was at a pretty good angle leaning toward the river too. I could have rolled my truck and been killed right then. The truck only suffered a crack to the plastic under the bumper, and needed an alignment. Meanwhile while I sat there almost hanging off over the river, I witnessed a huge pile up of cars just down the road a hundred feet. I could have just as easily been a part of that if I hadn't gone off when I did.
I got so many, but the worst one was leaving a tire place with the lug nuts on one wheel only hand tightened...
Working in an inspection pit, using oxy-acetylene for the first time to weld a new bottom on a box section, I notice a plastic pipe inside the section.
Wonder what that is....traced it back to the fuel tank. That's what it was.
Odd thing is I can't remember what, if anything, I did about it. I'd LIKE to think that I wasn't stupid/irresponsible enough to just carry on, but I can't remember any work-around.
