Maxima Pro Plus 20/50 syn bike oil
by Truckedup. 03/21/19 04:54 PM
CHAMPION COS 3593A **NEW** CUT OPEN
by 53' Stude. 03/21/19 04:28 PM
NAPA PROSELECT 21348 CUT OPEN
by 53' Stude. 03/21/19 04:21 PM
Atlanta No Nonsense Honda dealer
by DuckRyder. 03/21/19 04:16 PM
Echo (PAS) - Good, Bad, Other?
by GemStater. 03/21/19 04:06 PM
Serpentine Belt - When To Change?
by Propflux01. 03/21/19 03:08 PM
Magnetic Out, ST in at Wally Auto Care Center.
by csandste. 03/21/19 02:26 PM
One license plate in a Two-Plate State
by bunnspecial. 03/21/19 02:07 PM
TPMS Units Honda
by Chester11. 03/21/19 01:58 PM
Another brake question
by supton. 03/21/19 01:54 PM
BOUGHT WRONG OIL FILTER
by IBelieveinlube. 03/21/19 01:47 PM
miscible ester, using is as oil additive ?
by pep808. 03/21/19 01:23 PM
LT Oil Temps
by StillLearning. 03/21/19 12:44 PM
What kind of lug nut is this?
by LeakySeals. 03/21/19 12:38 PM
Need help finding a riding mower with $1,500 budget
by MetalSlug. 03/21/19 11:55 AM
Volvo 2.0 Turbo
by Ddub. 03/21/19 11:43 AM
Got a busted crankshaft!
by Chris142. 03/21/19 11:18 AM
Paperboy, Flinch, AlanGonzales, Jrealstreeter, DarkFrontier
67576 Registered Users
114 registered members (53' Stude, addyguy, 240_Ed, 38Chevy454, 77GrandPrix, Aero540T, 14 invisible), 2,011 guests, and 67 spiders.
Topics286,203
Posts4,904,125
Members67,576
Most Online2,967
Mar 10th, 2019
Page 1 of 10 1 2 10
Wear vs. oil-filter efficiency: SAE/Amsoil paper #4442189
06/26/17 06:25 PM
06/26/17 06:25 PM
Los Angeles, California
Gokhan Online content OP
Gokhan  Online Content OP
This is a good summary by Amsoil of a SAE paper (PDF link) on how engine wear correlates with oil-filter efficiency.
Engine wear is especially affected by oil-filter efficiency in diesel engines but the effect is also strong in gasoline engines. The long story short, it's very important to have a high-efficiency oil filter if you want to keep the engine wear as little as possible. Since the engine wear is caused by particles ranging in size mostly from 2 to 25 microns, removing such particles necessitates a premium synthetic or synthetic-blend oil filter with a high-efficiency micron rating.
See the table and graph for the efficiency ratings of the oil filters and the two charts for the engine-wear rates. Note that higher-efficiency oil filters were used for the diesel engine.
1985 Toyota Corolla LE, 4A-LC engine, ~ 273,000 M
Mobil 1 Extended Performance 0W-20 SN PLUS (PAO-based)
Fram Ultra XG3600 filter (full synthetic), 90430-12031 drain gasket (rubber on aluminum)
Re: Wear vs. oil-filter efficiency: SAE/Amsoil paper [Re: Gokhan] #4442208
06/26/17 06:38 PM
06/26/17 06:38 PM
MD
AirgunSavant Offline
MD
There is concern from some that glass enhanced filter media residue may also
result in increased wear as well since it is very abrasive itself. I believe Fleetguard
does mention this in their literature.
Re: Wear vs. oil-filter efficiency: SAE/Amsoil paper [Re: Gokhan] #4442209
06/26/17 06:38 PM
06/26/17 06:38 PM
Where the wind comes sweepin'
Reddy45 Offline
Reddy45  Offline
What concerns me is that new cars roll off the assembly line with what are essentially lowest bidder OEM oil filters. Those cars then sit on a lot and are short tripped and run hard during test drives until the car is sold.
By the time you get the car, the damage has been done. Wear metals are almost always high during break in.
Re: Wear vs. oil-filter efficiency: SAE/Amsoil paper [Re: Reddy45] #4442212
06/26/17 06:43 PM
06/26/17 06:43 PM
MD
MD
At least Ford factory installed new car filters are better then you get later on from MC.
Re: Wear vs. oil-filter efficiency: SAE/Amsoil paper [Re: Reddy45] #4442214
06/26/17 06:44 PM
06/26/17 06:44 PM
East Texas
mitsuman47 Offline
mitsuman47  Offline
East Texas
In regards to this scenario (and with Honda's especially) I've wondered if one should change the factory filter to a fram ultra or similar as soon as the car makes it home. Honda recommends to leave the factory fill in for the full OCI as indicated by the MM, which is fine. But the Honda A02 filter is basically a rock catcher.
Re: Wear vs. oil-filter efficiency: SAE/Amsoil paper [Re: Gokhan] #4442219
06/26/17 07:00 PM
06/26/17 07:00 PM
San Antonio, TX
E150GT Offline
E150GT  Offline
San Antonio, TX
lets everybody go get a bypass filter setup
1984 Mercedes-Benz 300SD - 100k
1995 F150 XL 4.9 reg cab 5MT - 251k 5w30
2016 Mazda6 Touring 6MT - 57k 10w30
2006 Buick Lucerne CXL 3.8 31k 5w30
Re: Wear vs. oil-filter efficiency: SAE/Amsoil paper [Re: Gokhan] #4442222
06/26/17 07:02 PM
06/26/17 07:02 PM
MI
doitmyself Offline
doitmyself  Offline
MI
The SAE paper proves that larger particles cause more wear than smaller particles. One has to ask if the testing correlates to real world engine operation.
It doesn't.
Re: Wear vs. oil-filter efficiency: SAE/Amsoil paper [Re: Gokhan] #4442260
06/26/17 07:55 PM
06/26/17 07:55 PM
South Texas Rancho
TexasVaquero Offline
South Texas Rancho
I use M1 EP filters. Good stuff.
2014 NISSAN VERSA 5spd M/T- M1 EP 5w30 and M1 EP Filter. 5k OCI.
2011 CHEVY IMPALA 3.5ltrs - M1 HM 5w30 and M1 EP Filter. 3k OCI.
Re: Wear vs. oil-filter efficiency: SAE/Amsoil paper [Re: Gokhan] #4442262
06/26/17 07:56 PM
06/26/17 07:56 PM
Taiwan
Ducked Offline
Ducked  Offline
Taiwan
"the threat they pose is diminished since they are still larger than many of the clearances within an engine. Their size will not allow them to enter the contact areas..."
Trying to picture how that would work, and can't.
Lets say a particle is small enough to get into the oil pump, but arrives somewhere where its too big. Anywhere it arrives it seems likely to be a problem, either due to blockage, abrasion, or both.
For example, say it gets to a bearing but is too big to enter. It can be too big only because it is in contact with a rotating shaft jourmal surface, and it is partially blocking the oilway where it enters the bearing. This does not seem a benign situation.
Re: Wear vs. oil-filter efficiency: SAE/Amsoil paper [Re: Gokhan] #4442275
06/26/17 08:15 PM
06/26/17 08:15 PM
OH
fdcg27 Online content
fdcg27  Online Content
OH
Your opening post sounds good, as is often the case with your topics, but when subjected to the reality test it makes no sense.
First off, gasoline engines have been running 200K+ for decades using no more than OEM rocks-catcher filters.
Second, the particle range you suggest is huge and there is no full flow filter whether labeled as having synthetic media or not that is particularly efficient in capturing particles smaller than twenty microns or so.
Multiple pass efficiency is of little importance since each pass exposes the bearings to the particles the oil filter didn't catch on the first pass.
Lots of folks in warm, mostly dry places like the one in which you live have old Toyotas just like yours with as many or more miles.
The difference is that they worry about neither oil nor oil filters.
They just drive their old cars and worry about the many more important things most of us experience in life.
18 Accord Hybrid FF
17 Forester 18K VME 0W-20
12 Accord LX 96K SSO 0W-20
09 Forester 95K M1HM 10W-30
01 Focus ZX3 118K PP 5W-20
96 Accord LX 104K T5 10W-30
95 318i
Re: Wear vs. oil-filter efficiency: SAE/Amsoil paper [Re: mitsuman47] #4442311
06/26/17 08:41 PM
06/26/17 08:41 PM
Danh Offline
Danh  Offline
Actually, Honda recommends a filter change very other oil change, which could be 20,000 miles or more. And of course Hondas are notorious for early engine failure and short life spans...
Re: Wear vs. oil-filter efficiency: SAE/Amsoil paper [Re: fdcg27] #4442324
06/26/17 08:49 PM
06/26/17 08:49 PM
PNW
ZeeOSix Offline
ZeeOSix  Offline
PNW
Filters rated at 99%+ @ 20 microns are catching quite a pretty decent amount of the particles below 20 microns (ie, FU said to be 80% @ 5 microns). Filters rated at 50% @ 20 microns are letting many more sub 20 micron particles through.
A 99% @ 20 micron filter will stop a much higher amount of particles from making multiple trips around the oiling system, which also helps reduce wear.
Re: Wear vs. oil-filter efficiency: SAE/Amsoil paper [Re: doitmyself] #4442331
06/26/17 08:54 PM
06/26/17 08:54 PM
PNW
ZeeOSix Offline
ZeeOSix  Offline
PNW
The paper said 5 to 25 micron particles create the most wear ... that's not the "larger particles".
Re: Wear vs. oil-filter efficiency: SAE/Amsoil paper [Re: Ducked] #4442339
06/26/17 08:59 PM
06/26/17 08:59 PM
PNW
ZeeOSix Offline
ZeeOSix  Offline
PNW
The particles that are too large to go through a running journal bearing clearance (which is around 5 to 10 microns oil film thickness when the engine is running) probably get spit out the sides of the bearing. Since the particle isn't being "smashed" between two surfaces, then it probably isn't going to cause much if any damage.
Re: Wear vs. oil-filter efficiency: SAE/Amsoil paper [Re: Danh] #4442359
06/26/17 09:13 PM
06/26/17 09:13 PM
East Texas
mitsuman47 Offline
mitsuman47  Offline
East Texas
I bet Fernando Alonso has an opinion on that... grin2
On a more serious note...please see my sig. I understand that Hondas are known to last, and I'm also very familiar with their maintenance schedules.
But, most of us are on this site for the sole purpose of doing what we can to make our vehicles last longer and "run like new" for a higher/longer amount of miles/time.
So, with the fram ultra being a filter that can handle long change intervals AND has a significantly higher efficiency, then wouldn't it stand to reason that the owner may see benefits if they plan to keep the vehicle for the long term?
Are ANY manufacturers "notorious for early engine failure and short life spans" directly caused by oil filter efficiency, or lack thereof? And if not, why are companies still doing tests on the benefits of higher efficiency filters?
Page 1 of 10 1 2 10
