CASIO G-SHOCK
by Char Baby. 04/18/19 05:23 AM
Castrol Magnatec $19.44 5QT
by Nickdfresh. 04/18/19 05:15 AM
Semi Synth Gear Oil Seperation?
by J_ODIE. 04/18/19 04:26 AM
Acura/Honda Oil Consumption
by artbuc. 04/18/19 04:15 AM
xW-HTHS grade selection
by OilUzer. 04/18/19 03:28 AM
Oil color different cool versus hot?
by FordCapriDriver. 04/18/19 02:56 AM
Oil Choices
by tiger862. 04/18/19 01:12 AM
Honda/Acura HTO-06
by blackdiamond. 04/17/19 11:24 PM
Remote transmission filter newbie questions
by Zahndkile. 04/17/19 09:31 PM
Ford 3.0L transmission problem
by taztheman. 04/17/19 08:24 PM
PQIA Tax Day 2019 VOA's
by UG_Passat. 04/17/19 08:21 PM
bubbling paint/rust repair
by greenjp. 04/17/19 07:32 PM
2016 ford fusion lug nut size and torque spec?
by Corollaman. 04/17/19 07:32 PM
Better, Worse, or All The Same?
by 2015_PSD. 04/17/19 06:55 PM
Uber/Lyft Destroyed The Taxi Industry.
by Willclark. 04/17/19 06:39 PM
2012 Accord,Pennzoil Platinum High Mileage 10W30
by aquariuscsm. 04/17/19 06:26 PM
Kohler Command Twin 18HP - not charging
by 92saturnsl2. 04/17/19 06:26 PM
W_huisman, Arcoril, SpeedThrills, Lg9977, Slikk726
67838 Registered Users
52 registered members (2015_PSD, Anthony, A1O, bbhero, Bailes1992, 6 invisible), 673 guests, and 27 spiders.
Topics287,673
Posts4,932,031
Members67,838
Most Online2,967
Mar 10th, 2019
Page 1 of 3 1 2 3
Rotella T15W40 22K on the oil (making metal) #4442165
06/26/17 05:58 PM
06/26/17 05:58 PM
Kelowna, BC, Canada
A310 Offline OP
A310  Offline OP
Kelowna, BC, Canada
Well not happy with these results at all, Blackstone is recommending I drop the oil as iron is now at 95 ppm. Most of the miles are city/highway and towing in the west coastal mountains. As a comparison my sister's 6BT has very similar miles on the oil and is 12 ppm (no towing). I've got no signs of trouble at all from the engine, no smoke, blow-by is low and fuel economy is excellent. What do you guys think, dump the oil or keep using? I'm inclined to dump it, change the full and add 15 quarts of Amsoil AME 15W40 and see if that helps the wear numbers.
Here's the report:
2009 Ford F-350 (Detroit 4-53T)
2000 Ford Excursion (Triton V10)
1993 Dodge D250 (Cummins 6BT)
Re: Rotella T15W40 22K on the oil (making metal) [Re: A310] #4442176
06/26/17 06:17 PM
06/26/17 06:17 PM
snow and sun
oliveoil Offline
oliveoil  Offline
snow and sun
From using .5-1qt to 6. There is a problem starting to happen. It's not the oils fault.
Re: Rotella T15W40 22K on the oil (making metal) [Re: A310] #4442181
06/26/17 06:18 PM
06/26/17 06:18 PM
'murica
Ethan1 Offline
Ethan1  Offline
'murica
At what point in your OCI did it start using oil? That's probably when you should change it. I've had a passenger car that would use zero oil, hit 7k on the OCI, and then start to use a little bit.
Re: Rotella T15W40 22K on the oil (making metal) [Re: A310] #4442184
06/26/17 06:20 PM
06/26/17 06:20 PM
East Texas
mitsuman47 Offline
mitsuman47  Offline
East Texas
Here's the report:
What oil was used for the previous OCIs?
Edit: interesting that back at 248,000km it used 5qts make up oil in 8,000km. Then went down to none over 17,000km. Now up to 6qt in 35,000km. Are those numbers correct?
Re: Rotella T15W40 22K on the oil (making metal) [Re: A310] #4442191
06/26/17 06:26 PM
06/26/17 06:26 PM
Sav ga
NStuart Offline
NStuart  Offline
Sav ga
I ran Rotella T6 for 40000 miles in my Detroit and was it 75 PPM iron, that was before I started playing around with bypass filters I did swap the full flow filters at least once which added 2 Fresh gallons of oil, I have a bypass on three trucks only 2 of them have regular sampling done right now. My one suggestion would be to possibly use oil to flush out that high mileage oil (shot oci), just a thought because one truck had more frequent oil changes than the other and my samples and tbn reflect that. My 200,000 Mile motor versus my 1 million mile motor the samples look better on the 1 million mile motor. The 200,000 Mile motor oil change interval with 40K prior to the bypass install and regular sampling the 1 million mile motor had a 15000 mile change and an oil pan dump and cleaning just prior to the bypass install. I think the residual oil from the 40K change is causing me to see a 5.2 TBN in that motor versus a 5.8 in the other motor at the same mileage sample. Just some interesting thoughts so far I'm very happy with the Shaeffer 9000 and fuel mileage I'm receiving from it
Re: Rotella T15W40 22K on the oil (making metal) [Re: A310] #4442194
06/26/17 06:27 PM
06/26/17 06:27 PM
Kelowna, BC, Canada
A310 Offline OP
A310  Offline OP
Kelowna, BC, Canada
Sorry guys I forgot to mentioned that this truck has an Amsoil Dual Gard and a Frantz in series after the Dual Gard. The 6 quarts of oil are used from 4 toilet paper rolls changed, a full flow filter changed, and the oil burned is around 2-3 quarts burned.
Re: Rotella T15W40 22K on the oil (making metal) [Re: A310] #4442207
06/26/17 06:37 PM
06/26/17 06:37 PM
East Texas
mitsuman47 Offline
mitsuman47  Offline
East Texas
Is this the same filter setup as previous OCIs?
Re: Rotella T15W40 22K on the oil (making metal) [Re: mitsuman47] #4442228
06/26/17 07:11 PM
06/26/17 07:11 PM
Kelowna, BC, Canada
A310 Offline OP
A310  Offline OP
Kelowna, BC, Canada
Yes, with the exception of adding the Frantz unit, this was added 12000 miles ago.
Re: Rotella T15W40 22K on the oil (making metal) [Re: A310] #4442239
06/26/17 07:22 PM
06/26/17 07:22 PM
Sav ga
NStuart Offline
NStuart  Offline
Sav ga
I'd be interested to see a particle analysis on that, Blackstone told me it's only $15 if the oil is clear enough to do so
Detroit14l 1m75k mi bp schaffer9k 30k oil
96 ram 5.9 gas 80k built tranny 5k m1
85 cj7 4.2 performance build. Schaeffer 9000
08 cbr600rr graffiti. T6
08 husky sm610 t6
Re: Rotella T15W40 22K on the oil (making metal) [Re: NStuart] #4442273
06/26/17 08:13 PM
06/26/17 08:13 PM
Kelowna, BC, Canada
A310 Offline OP
A310  Offline OP
Kelowna, BC, Canada
Well I tried that with the previous sample and they could not read it, have to be able to see through the oil.
Re: Rotella T15W40 22K on the oil (making metal) [Re: A310] #4442287
06/26/17 08:26 PM
06/26/17 08:26 PM
East Texas
mitsuman47 Offline
mitsuman47  Offline
East Texas
I know it may sound counter-intuitive, but is there any way to bypass your frantz filter setup for the next change?
So, bypass your bypass filter.... crzy
I'm just trying to cancel out any obvious variables that may have changed AND affected your UOAs before we blame the oil.
Re: Rotella T15W40 22K on the oil (making metal) [Re: A310] #4442356
06/26/17 09:09 PM
06/26/17 09:09 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
35,600 miles or kilometers on the oil?
Re: Rotella T15W40 22K on the oil (making metal) [Re: A310] #4442366
06/26/17 09:20 PM
06/26/17 09:20 PM
AZ
Killer223 Offline
Killer223  Offline
AZ
oils cheap, engines are not.
08 6.7 cummins G56
04 5.9 cummins
95 12V NV4500.
11 ranger 4.0
18 crf450RX
Re: Rotella T15W40 22K on the oil (making metal) [Re: A310] #4442401
06/26/17 10:14 PM
06/26/17 10:14 PM
Kelowna, BC, Canada
A310 Offline OP
A310  Offline OP
Kelowna, BC, Canada
Thanks for the responses guys, I've decided to change filters and oil and get another sample in 5000 miles.
Re: Rotella T15W40 22K on the oil (making metal) [Re: A310] #4442631
06/27/17 09:25 AM
06/27/17 09:25 AM
Canyon County Idaho
CT8 Offline
CT8  Offline
Canyon County Idaho
Something is failing.
2015 F150 2.7
2018 F350 6.2
Page 1 of 3 1 2 3
