High Performance Motorcycle oil...which one?
by Neiz15. 09/18/18 06:50 PM
Need help High Performance Motorcycle oil?
by Neiz15. 09/18/18 06:38 PM
MC FL-500S CUT OPEN
by 53' Stude. 09/18/18 05:15 PM
FORD FACTORY FILTER CUT OPEN
by 53' Stude. 09/18/18 05:06 PM
2019 Harley Davidson FXDR 114
by DuckRyder. 09/18/18 04:59 PM
USS Forrestal question
by cjcride. 09/18/18 03:52 PM
Breaker Box
by Throt. 09/18/18 03:00 PM
Honda metal fuel tank seam leak
by wing0. 09/18/18 02:49 PM
Cracked single stage paint
by JHZR2. 09/18/18 01:45 PM
Options versus dealer oil changes
by Schmoe. 09/18/18 01:34 PM
Longevity of Mercon LV in a 2017 Ford Escape?
by mrdctaylor. 09/18/18 01:24 PM
I'm on a Lawn Boy jag
by andyd. 09/18/18 01:13 PM
Old (New) Tires
by ET16. 09/18/18 12:05 PM
iOs 12 for Apple
by madRiver. 09/18/18 12:01 PM
Synthetic oil overrated??
by Ablebody. 09/18/18 12:01 PM
Ferrari Monza SP 1/2
by DeepFriar. 09/18/18 11:58 AM
Any option to "Mark all forums read"
by Rick505. 09/18/18 11:54 AM
1981 280ZX Turbo
by 16HC. 09/18/18 11:12 AM
tomkat22, tabar2004, SierraMan, Rennmeister, KeithCoates
66004 Registered Users
95 registered members (BAJA_05, 2010Civic, Audios, AVB, 13 invisible), 1,677 guests, and 38 spiders.
Topics290,605
Posts4,847,355
Members66,004
Most Online3,590
Jan 24th, 2017
Raising Vehicle #4442118
06/26/17 04:49 PM
06/26/17 04:49 PM
Iowa
mickalo Offline OP
mickalo  Offline OP
Iowa
I got a 2010 ford explorer xlt 4wd and was wondering if anyone has done something like this to raise up their vehicle. I have 2 pair of Rhino Ramps and was thinking of using them, one under each wheel and drive up, or back onto, each one.
It would be really be nice to have the extra room underneath and could actually use a creeper instead of sliding around on an old rug to check fluid, change oil, etc. Is this something that maybe feasible or ,maybe not worth trying? I don't have a garage just apt. parking lot. It very level.
2010 Ford explorer 4.0L sohc 4wd 5w-30 Full Syn.
Re: Raising Vehicle [Re: mickalo] #4442120
06/26/17 04:55 PM
06/26/17 04:55 PM
WI
HoosierJeeper Offline
WI
Yeah you could do that. I'd drive up on them. Easier than jacking it up and less obvious in an apartment setting!
15 Jeep KL Limited V6: Formula Shell 5W20
07 LR3 SE V8: Maxlife 5W30
05 Jeep KJ Limited: PHM 5W30
96 Jeep XJ Country: STP HM 5W30 (winter)
Re: Raising Vehicle [Re: mickalo] #4442122
06/26/17 05:01 PM
06/26/17 05:01 PM
Iowa
mickalo Offline OP
mickalo  Offline OP
Iowa
that's what i was thinking got a floor jack with a pair of jack stands but it is a real pain jacking it up one side at time. We have these high curbs that run along the parking lot parking stalls could put one pair up against the curb, help keep from sliding, then place the other pair in front of the other wheels. Yep this is much better grin
Re: Raising Vehicle [Re: mickalo] #4442137
06/26/17 05:17 PM
06/26/17 05:17 PM
NY
demarpaint Offline
demarpaint  Offline
NY
Ramps are great for raising a vehicle, nice and level for certain tasks. I put my Jeep in 4L and put one ramp at each of the 4 wheels. I pop it in D, take my foot off the brake and up it goes with ease. It makes transmission, or transfer case service very easy since the vehicle is high enough off the ground, and level.
God Bless Our Troops
Re: Raising Vehicle [Re: mickalo] #4442157
06/26/17 05:42 PM
06/26/17 05:42 PM
ME
eljefino Online content
eljefino  Online Content
ME
I think you'd be better off driving the front axle on a set of ramps then jacking on the center diff and putting the rear outer frame on stands. I'd be worried about getting one axle an inch or two "off center" putting all four corners up on ramps, with the resultant instability.
Re: Raising Vehicle [Re: eljefino] #4442166
06/26/17 05:59 PM
06/26/17 05:59 PM
Iowa
mickalo Offline OP
mickalo  Offline OP
Iowa
good point I will need to watch this if it a problem may need to try a different approach.
thanks,
Re: Raising Vehicle [Re: eljefino] #4442180
06/26/17 06:18 PM
06/26/17 06:18 PM
NY
demarpaint Offline
demarpaint  Offline
NY
I see what you're saying. I've done it a few times now w/o any problems. I make sure all 4 wheels are cradled on the ramps rock the Jeep to be sure, and slide jack stands under it to play it even safer. Honestly it feels very stable on the 4 ramps. But I would caution people to check everything over before going under. You can never be too cautious about going under a vehicle.
Re: Raising Vehicle [Re: demarpaint] #4442186
06/26/17 06:22 PM
06/26/17 06:22 PM
Iowa
mickalo Offline OP
mickalo  Offline OP
Iowa
most definitely safety should always be a priority.
Re: Raising Vehicle [Re: mickalo] #4442258
06/26/17 07:49 PM
06/26/17 07:49 PM
'murica
Ethan1 Offline
Ethan1  Offline
'murica
I'm confused by the question. Yes, Rhino Ramps exist. Yes, they do work. Coffee2
Re: Raising Vehicle [Re: mickalo] #4442280
06/26/17 08:19 PM
06/26/17 08:19 PM
San Antonio, TX
Nyogtha Offline
Nyogtha  Offline
San Antonio, TX
I put my 2012 4WD Ram up on 4 Rhino Ramps when I mess with the transmission, differentials, or transfer case.
I use only 2 Rhino Ramps on the front wheels for oil & filter change.
YMMV
"No matter how paranoid you are you're not paranoid enough. Tell the truth. Reach as many people as you can with it. That's your weapon." - Susanne Modeski, aka "Holly" to The Lone Gunmen
Re: Raising Vehicle [Re: mickalo] #4442294
06/26/17 08:30 PM
06/26/17 08:30 PM
Virginia
glock19 Offline
glock19  Offline
Virginia
I've used my Rhino ramps a lot. I do throw some jacks stands under there just to be safe.
2017 GMC Sierra SLT Z71 Crew Cab - His
2016 Toyota Highlander Limited - Hers
Re: Raising Vehicle [Re: mickalo] #4442405
06/26/17 10:25 PM
06/26/17 10:25 PM
Marshfield , MA
andyd Offline
andyd  Offline
Marshfield , MA
I use blocks and dunnage. I shored up ships as they were built. There are a few basic methods that translate well to a smaller scale. The main thing about cement blocks is to use them holes up , on wood to spread the weight. On a gravel or asphalt surface, plywood is used to keep the ramps from digging in. However you have a car up, make sure it is stable before getting under it.
Thick oil is better grin2
Re: Raising Vehicle [Re: mickalo] #4442546
06/27/17 07:22 AM
06/27/17 07:22 AM
Iowa
The_Eric Offline
The_Eric  Offline
Iowa
Whenever and wherever you use ramps, ESPECIALLY Rhino ramps, always make sure they're on FLAT, SMOOTH ground. If it is uneven, they can flex and twist- or in the case of a Rhino ramp, crack.
2005 Lincoln Aviator 4.6 DOHC
2000 Honda Accord 2.3
2001 Hyundai Elantra 2.0
1979 Ford F-150 351M
Re: Raising Vehicle [Re: andyd] #4442555
06/27/17 07:33 AM
06/27/17 07:33 AM
Texas
4WD Offline
4WD  Offline
Texas
One of the main reasons for my wood, glue, & 3" screw versions - sometimes I'm on concrete, sometimes on gravel.
I also find the 1-1/2" staggering easy on the vehicle - whether going up two or four of them.
The wood grips the underside well - and you can make the first stagger longer so the tire pins the ramp early on ...
