Michelin jack won't lift a load
by 10WSmuckers. 09/23/18 01:32 AM
Synthetic for a 30 year old engine?
by geissjr. 09/23/18 01:02 AM
Phone Books
by csandste. 09/23/18 12:11 AM
Inside the Fuel Tank / EVAP system
by StevieC. 09/22/18 10:31 PM
Toyota Pink + RMI-25 10 years
by burla. 09/22/18 10:27 PM
Cartridge filter?
by Camprunner. 09/22/18 10:23 PM
Should have changed it?
by parshisa. 09/22/18 10:14 PM
Meijer QSUD Full Syn 10w30 $8.11 5qt jug
by Spartanfool. 09/22/18 08:40 PM
Whats in your beef burger
by CourierDriver. 09/22/18 08:28 PM
Headlight brightness fluctuates on 1987 Golf
by vavavroom. 09/22/18 07:56 PM
"New" Beater
by SilverGt. 09/22/18 07:22 PM
Eschewing computer controls
by buck91. 09/22/18 06:41 PM
Leak/drip left front 13 Ram 4x4?
by irv. 09/22/18 06:22 PM
5w20 oil choices
by 53' Stude. 09/22/18 06:05 PM
site security
by RF Overlord. 09/22/18 06:02 PM
Richmond Raceway
by Warstud. 09/22/18 06:01 PM
Redline D6 ATF substituting for Toyota WS
by Patrick0525. 09/22/18 05:29 PM
XG3614 Cut Open 13,400kms (8,375mi)
by mcwilly. 09/22/18 05:25 PM
Torn Purolators: they DO TEAR!
by 53' Stude. 09/22/18 05:07 PM
HondaTech250, SandCruzer, sbgti96, cosmoblau, Sarrge
66044 Registered Users
25 registered members (BlakeB, ArrestMeRedZ, Billbert, CleverUserName, Astro14, ctechbob, 3 invisible), 760 guests, and 39 spiders.
Topics290,867
Posts4,851,574
Members66,044
Most Online3,590
Jan 24th, 2017
Valvoline ML 5W-30, 5,500, 2006 Infinit M35X, 157K #4441958
06/26/17 01:05 PM
06/26/17 01:05 PM
PA USA
ae7456t Offline OP
ae7456t  Offline OP
PA USA
Here is my 2nd analysis on my '06 Infiniti M35X...Much better results for both iron and viscosity (although I would still like to see it a little lower on the iron), despite using the exact same oil for both samples.
Couple of comments I can't believe I forgot to mention when I posted the first analysis...
1. During the run for the first sample, I had my radiator fail with the expected increase in engine temperature...I caught it before the temperature spiked but it certainly ran significantly higher than normal for ~30-60 seconds...I suspect that could have resulted in some significant viscosity breakdown.
2. Also during the run for the first sample, I was less "diligent" about keeping up with makeup oil...I was more of a hawk during the run for the second sample...As I doubt the car got that much "thirstier" in the last 5,500 miles, I am pretty sure I was running way low on oil. This may also tie into their comment on the high volume of makeup oil "diluting" the metals PPM readings.
Still not thrilled with the oil consumption, so my latest fill was Castrol 10W-40 High Mileage...We will see if the heavier weight has any impact.
As always, all comments and observations are welcome!
2006 Infiniti M35X at 16X,XXX miles
Castrol High Mileage 10W-40
Fram Filter
2011 Buick Enclave with 10X,XXX miles
AC Delco Synthetic 5W-30
AC Delco Filter
Re: Valvoline ML 5W-30, 5,500, 2006 Infinit M35X, 157K [Re: ae7456t] #4442099
06/26/17 04:24 PM
06/26/17 04:24 PM
Slinger, Wisconsin
BrewCityR Offline
BrewCityR  Offline
Slinger, Wisconsin
Keep us posted on the consumption... I just bought an M45 and it guzzled 3/4 qt. in 750 miles, but that was with unknown oil and likely quite old (oil filter that I removed had a hand-written date of 10-26-15).
2006 Infiniti M45 Sport (me) - Castrol Edge 0w40 - Fram FPS7317
2016 Mazda CX-5 AWD Grand Touring (wife) - Castrol Edge 0w20 - Premium Guard PG4612EX
Re: Valvoline ML 5W-30, 5,500, 2006 Infinit M35X, 157K [Re: ae7456t] #4442550
06/27/17 07:26 AM
06/27/17 07:26 AM
PA USA
ae7456t Offline OP
ae7456t  Offline OP
PA USA
Thanks, BrewCityR...Will do.
I have put about 1,000 miles on since this last oil change with the 10W-40, and it definitely looks like it is burning less oil. I should have been down about 0.5 qt, but looks like it is still holding, so far.
I will keep checking and let you know if that continues.
Fram Filter
AC Delco Filter
Re: Valvoline ML 5W-30, 5,500, 2006 Infinit M35X, 157K [Re: ae7456t] #4443073
06/27/17 06:48 PM
06/27/17 06:48 PM
Virginia
bbhero Offline
bbhero  Offline
Virginia
I have the VQ 3.5 in my 08 Altima has well. I just put Valvoline Maxlife full synthetic in my car. My car doesn't use hardly any oil at all between changes. This report does look ok but given two and a half qts of make up oil it is hard to tell if the viscosity is bumped up do to that. But I am glad that you had this done to have an idea of how well this oil could potentially do.
Nissan Altima 3.5 Coupe
Quaker State High Mileage 5w30 Purolator Boss 14610
"Treat your family like your friends and treat your friends like your family."
