Need help on edit profile
by jetmech1. 09/21/18 06:34 PM
Oil thickness on the dipstick
by Idlewild294. 09/21/18 05:40 PM
Chinese WIX Trans filter bad, let me down..
by jetmech1. 09/21/18 04:47 PM
Gen 8 Accord rear brakes-What tool?
by fdcg27. 09/21/18 04:30 PM
Ammeters?
by buck91. 09/21/18 03:55 PM
Need Help with Double D Knockers
by user52165. 09/21/18 03:41 PM
Opinion needed....
by Duffyjr. 09/21/18 02:56 PM
2017 nissan sentra
by jahwarrior1423. 09/21/18 02:47 PM
I Need A Safe Space- lol
by Zee09. 09/21/18 02:29 PM
Liqui Moly
by dawgn86. 09/21/18 02:10 PM
Valve issues
by kawie_guy. 09/21/18 01:54 PM
2018 Elantra SE
by wolf_06. 09/21/18 01:36 PM
Nasty looking oil filter
by atikovi. 09/21/18 12:43 PM
Laughing hard.
by StevieC. 09/21/18 12:26 PM
Apologies
by Drew99GT. 09/21/18 12:15 PM
Would Like the Manual Transmission to Make a Comeback?
by Speak2Mountain. 09/21/18 11:39 AM
Leaf Mulcher
by kwijibo. 09/21/18 11:32 AM
JRMFt11, Navyretired, aikwae, ScottRousell, Direct_Rejection
66036 Registered Users
106 registered members (ABomb369, 2015_PSD, 2013ecof150, A310, 10ecfarmer, 53' Stude, 12 invisible), 1,510 guests, and 41 spiders.
Topics290,786
Posts4,850,311
Members66,036
Most Online3,590
Jan 24th, 2017
Are these bulbs a waste of money? #4441432
06/25/17 07:46 PM
06/25/17 07:46 PM
NJ
NJ_Car_Owner Offline OP
NJ
Bought my wife's 2016 Edge H11 Philips Xtreme vision +100 bulbs, the clear ones (no blue tint), as H11 are what her low beams are. I got them from Amazon for $25/pair and thought it was a good price. Now that I have them I realize we have the Daytime running lights (DRLs) running that use low beams (no clue why not high beams) and and the car has LED signature lamps.
I am assuming these H11's have a shorter lifespan as they burn differently, I believe I can deactivate the DRLs but I don't think those signature lamps are that bright to make the car visible like DRLs would. On the Philips website it claims they get 300+ hours of life, I think I've read once that standard H11's run for about 450 hours but every halogen bulb I've ever had runs for years. I believe the DRLs running all the time will make the new ones burn out within a very short period of time, probably a couple of months. Which is why they may be a waste of money.
Any thoughts on deactivating the DRLs and only using the signature lamps and/or the possibility that these lights may actually work out OK.
Thanks!
Re: Are these bulbs a waste of money? [Re: NJ_Car_Owner] #4441435
06/25/17 07:51 PM
06/25/17 07:51 PM
USA
slacktide_bitog Offline
USA
Are the low-beam DRL's full voltage or low-voltage? Many DRL systems that use a headlight beam for the DRL function (either high or low beam) will run them at half voltage, or at least something less than full voltage when in DRL mode.
If this is the case with your car, then this will not affect the bulb lifespan at all
Re: Are these bulbs a waste of money? [Re: NJ_Car_Owner] #4441442
06/25/17 08:00 PM
06/25/17 08:00 PM
NJ
NJ
I have not taken a voltage measurement but visually it doesn't look that they get much brighter when switched to "on" vs DRLs. There is a slight increase in brightness but it doesn't look like they get 50% or more brighter.
Re: Are these bulbs a waste of money? [Re: NJ_Car_Owner] #4441462
06/25/17 08:34 PM
06/25/17 08:34 PM
Northern Kentucky
901Memphis Offline
901Memphis  Offline
Northern Kentucky
The DRLs do not not run full voltage and lower voltage running time doesn't hurt the life as much as you think by far.
2012 Chevy Cruze LT 1.4T - 50k
2002 Buick Century 130k - Built 4T65e(Maxlife) - Edge 0w40 + Fram XG3980
Re: Are these bulbs a waste of money? [Re: NJ_Car_Owner] #4441484
06/25/17 09:03 PM
06/25/17 09:03 PM
NJ
NJ
Thanks slacktide_bitog and 901Memphis for your responses!
Good to know that I won't go through these bulbs that quickly. My wife travels two lane roads a lot and I want her car as visible as possible during the day along with getting enough light (hopefully more light than stock bulbs) with these bulbs at night.
Re: Are these bulbs a waste of money? [Re: NJ_Car_Owner] #4441534
06/25/17 09:48 PM
06/25/17 09:48 PM
MTL, CANADA
Rolla07 Offline
Rolla07  Offline
MTL, CANADA
Ive had those bulbs, gimmicky and dont last and nor are they much brighter. Can you find LED replacements? They run cooler so they wont fog the lenses as easily and in my experience are quite bright. If they last over 1 year, they will have outlasted the philips.
2007 Corolla Red Pearl 155k miles
PP 0w20 & ST 4967
Re: Are these bulbs a waste of money? [Re: NJ_Car_Owner] #4441578
06/25/17 11:50 PM
06/25/17 11:50 PM
Lynchburg, VA, USA
SF0059 Offline
SF0059  Offline
Lynchburg, VA, USA
Daytime running lights or not, my guess is that they will last you about a year. In the past I put these in a car and had one burn out every 6 months to a year. I have started only using OEM for headlights and they last sooooo much longer.
2014 Honda Odyssey EX-L/RES: 54K mi, M1 0w-40 & FU, VCMuzzler V2
2017 Mazda 6 Touring 6MT: 22k mi, M1 AFE 0w20, OEM Filter
Re: Are these bulbs a waste of money? [Re: NJ_Car_Owner] #4441634
06/26/17 03:47 AM
06/26/17 03:47 AM
Romania
Andy636 Offline
Andy636  Offline
Romania
I run Osram Night Breakers Unlimited in my car.
There are two scenarios here:
1: - you have a projector headlight and there will be NO improvement in distance but the 4000K color temperature will give you a better depth perception at night over regular halogen
2: - you have a reflector headlight and you will notice at least a 30% increase in the illuminated patch of road.
What I love about them is that in 2 years of usage I have never blinded incoming traffic, compared to those Xenon retrofit kits that make you want to beat the owner with a lead pipe.
Now the cons:
- They are more expensive
- They will last you no more than a year, especially if you drive on bumpy roads ( my record is 8 months)
- If you have a car where you have to take apart half the bumper, battery, relays and wire harnesses not to mention sacrificing some finger skin to the gods in order to change a darn light bulb, your cursing will improve dramatically in no time.
Re: Are these bulbs a waste of money? [Re: NJ_Car_Owner] #4441673
06/26/17 06:26 AM
06/26/17 06:26 AM
NJ
NJ
Thanks for the replies!
The car has projector beam headlights for low beam, I always wondered about upgrading and seeing further with them. I think it is going to be a knuckle busting experience... Have to remove the whole headlight assembly.
LED replacement bulbs are not street legal and DOT approved. Philips does make H11 fog light LED bulbs but only approved for fog lights. If and when aftermarket LEDs become legal and have the correct light pattern it'll be what I would do.
Since I have them and they were only $25, I'll give them a try and be ready to replace them.
Thanks again!
Re: Are these bulbs a waste of money? [Re: NJ_Car_Owner] #4441924
06/26/17 12:07 PM
06/26/17 12:07 PM
Northern Kentucky
901Memphis Offline
901Memphis  Offline
Northern Kentucky
Oh it has projectors? Have you thought about doing an H9 upgrade?
http://www.candlepowerforums.com/vb/showthread.php?254193-Difference-between-H9-and-H11-bulbs
Re: Are these bulbs a waste of money? [Re: 901Memphis] #4441949
06/26/17 12:45 PM
06/26/17 12:45 PM
NJ
NJ
Thanks for the suggestion but actually no for 2 reasons. First the car is under warranty and I wouldn't do anything to void it and manufacturers will try to find fault to void it IMO. And second, it is a 65 Watt bulb so it is not a low beam headlight, I'm not looking to blind other people... can't stand when they do that to me. I have read things like that thread before and it sounds good until a problem happens, problems always happen with me! smile
My wife's previous car had projector beam headlights and it had the "Z" cutoff pattern, I haven't noticed it in this car I'll have to take more notice. We never modified the headlights in her previous car (Hyuandai Minivan), used stock 55 watt bulbs and every so often people would flash their headlights at us which is why I looked to see the cutoff against the garage door (I know that's too close for aiming purposes), of course they could have been aimed too high from the factory.
Honestly if these bulbs last less than a year and/or no improvement, I'll go back to stock H11, If they last more than a year and there is an improvement maybe I'll stick with them.
Re: Are these bulbs a waste of money? [Re: NJ_Car_Owner] #4442483
06/27/17 05:05 AM
06/27/17 05:05 AM
Crawfordville FL
SilverFusion2010 Offline
Crawfordville FL
The H9 upgrade gives a nice boost to projector headlamps. I stick with the OEM equivalent long life bulbs when I replace burned out headlamps.
2010 Ford Fusion SE 3.0L V6, 178k miles M1 HM 10w-30
Re: Are these bulbs a waste of money? [Re: NJ_Car_Owner] #4444690
06/29/17 09:12 AM
06/29/17 09:12 AM
Idaho
SubLGT Offline
SubLGT  Offline
Idaho
Originally Posted By: NJ_Car_Owner
And second, it is a 65 Watt bulb so it is not a low beam headlight, I'm not looking to blind other people... can't stand when they do that to me...
Sometimes a H11 to H9 conversion in a projector headlamp is safe (i.e no excessive glare), and sometimes it is not. Depends on the specific vehicle.
http://www.candlepowerforums.com/vb/showthread.php?424988-When-is-H11-gt-H9-safe-and-how-can-we-know
Re: Are these bulbs a waste of money? [Re: Andy636] #4489292
08/15/17 01:38 PM
08/15/17 01:38 PM
NE Ohio
knerml Offline
knerml  Offline
NE Ohio
Now the cons:
Ran those as high beam on a 2015 Elantra. Turned out they run as DRLs and burned out in 12 months.
2015 Hyundai Elantra Sport 2.0 GDI Mobil 1 5W20 & OEM/Mann W811/80 Filter
2018 Hyundai Santa Fe Sport 2.0T Castrol Edge 5W40 & OEM/Mann W811/80 Filter
Re: Are these bulbs a waste of money? [Re: NJ_Car_Owner] #4563869
11/04/17 12:06 PM
11/04/17 12:06 PM
Central NY/Arkansas
avacado11 Offline
avacado11  Offline
Central NY/Arkansas
$25 a pair is still pretty cheap. Standard clear bulbs will run ~$14 a pair anyways.
Don't get too worried about DRLs running the LB bulb at 1/2 wattage. My Nissan has DRLs that are always on and the bulbs still work 2 years later. As long as you don't touch the glass the bulbs will work for a long time. Never had a failure, EVER, unless I touched the glass during installation or it's a cheap $3 bulb that was probably touched during packaging.
2017 Subaru Outback - 0w20 FS - Falken ziex s/tz05
2014 Lexus IS250 - 0w20 FS - Conti Extreme DWS
2014 BMW i3 - Bridgestone Ecopia
