Fullers Vintage Ale anyone?
by Lolvoguy. 12/18/18 11:23 PM
Got an alignment
by michaelluscher. 12/18/18 11:18 PM
Castrol Edge 0W-40; 9,762 mi; 2016 Ford Fiesta ST
by asiancivicmaniac. 12/18/18 10:50 PM
Windows Defender Error Code
by ZeeOSix. 12/18/18 10:20 PM
UOA Motul 300V, 5w40, 2013 BMW S1000RR
by Sportbiker. 12/18/18 09:53 PM
Under valve cover pics
by barkingspider. 12/18/18 09:47 PM
Kubota Super UDT2? Anything better?
by Jmoney7269. 12/18/18 09:23 PM
Car Door Fabric Glue
by cb450sc. 12/18/18 08:57 PM
Canadian Uber
by StevieC. 12/18/18 08:13 PM
71141 / Lifeguard 5
by chefwong. 12/18/18 07:52 PM
Tested Positive for Flu
by john_pifer. 12/18/18 07:37 PM
Cooper RTX?
by 01rangerxl. 12/18/18 07:25 PM
IPhone SE or flip phone?
by 53' Stude. 12/18/18 05:49 PM
1993 K1500 hard cold start
by BrianF. 12/18/18 05:43 PM
Put my wife's dog down yesterday
by Stelth. 12/18/18 05:04 PM
ATF Filter oem vs aftermarket any differences?
by 97prizm. 12/18/18 03:50 PM
Depth-Fiberglass Filter Media.
by Al. 12/18/18 03:43 PM
Sportbiker, trollhattan, MuhThugga, wxo, dbierman
66718 Registered Users
25 registered members (dnewton3, 53' Stude, dlundblad, ChrisD46, Bjornviken, Bailes1992, 1 invisible), 888 guests, and 44 spiders.
Topics295,249
Posts4,930,868
Members66,718
Most Online2,553
Oct 27th, 2018
Mixing Pennzoil Platinum and Castrol Magnatec. #4441184
06/25/17 01:41 PM
06/25/17 01:41 PM
Missouri
GRWOil Offline OP
GRWOil  Offline OP
Missouri
I went to change the oil yesterday in my sister's 2016 Hyundai Accent. It's a 1.6L naturally asperated GDI engine, with a 3.7 quart sump. When I changed it last winter, I filled it from a 5 qt. jug of PP 5w-20 and put a fram Ultra on it. 7500 miles later, I had about 1.5 quarts of PP left from the first oil change and some bottles of Magnatec 5w-20 in the garage.
Long story short, it's got about half PP and half Magnatec, both 5w-20. I didn't think much of it at the time, but now I'm having second thoughts. Are these two oils incompatible? Could there be issues with long-term performance (7,500 miles/6 months) with a mix from two different brands?
Re: Mixing Pennzoil Platinum and Castrol Magnatec. [Re: GRWOil] #4441186
06/25/17 01:47 PM
06/25/17 01:47 PM
Idaho
CT8 Offline
CT8  Offline
Idaho
The oils will be fine.
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: Mixing Pennzoil Platinum and Castrol Magnatec. [Re: GRWOil] #4441214
06/25/17 02:12 PM
06/25/17 02:12 PM
Toronto
PeterPolyol Offline
PeterPolyol  Offline
Toronto
popcorn2
Scambling for solutions is a hopelessly futile endeavour and potentially dangerous, without first coming to a solid, personal understanding of the problem. Beware riding the ideological hobby horse.
Re: Mixing Pennzoil Platinum and Castrol Magnatec. [Re: GRWOil] #4441245
06/25/17 02:58 PM
06/25/17 02:58 PM
Katy, Republic of Texas
blupupher Offline
blupupher  Offline
Many say mix away, many give dire warnings that there could be problems.
No you will not have an exact known quality of oil, but you are mixing 2 good oils. No different that the millions upon millions of vehicles that have whatever oil added as top off oil during an oil change.
I am of the mix away camp, and have mixed different brand (and weights) of oils with no issues (which proves nothing). If the need arises, I will continue to do so. I know that I have a few qts of misc oil that will eventually be mixed for an oil change in my truck.
These include 2 qts PU 5w-20, 1 qt M1 EP 0w-20, 2 qt Auto Zone Syn 0w-20, 1 qt Havoline HM 5w-20.
2018 Hyundai Santa Fe: Dealer oil and filter/5k
2012 Scion xB: QSUD 0w-20, CQ Blue, 5k
2002 Ford F150: GTX HM 5w-20, EcoGard, 1yr
1994 Honda VT1100c: Peak 15w-40, PSL, 5k
Re: Mixing Pennzoil Platinum and Castrol Magnatec. [Re: GRWOil] #4441255
06/25/17 03:12 PM
06/25/17 03:12 PM
MT
jongies3 Offline
jongies3  Offline
MT
Ever since SL, oil companies have been required by the government to make it so all their additives are compatible with all other oil additives. Used to be a bad idea to do this back in the day, but things are different now so don't worry about it.
2004 Toyota Tacoma 3.4 V6: Mobil 1 AFE 0W-30, FRAM TG-3600 filter
1969 Mustang Mach 1 5.8 V8: PYB 10W-30 Napa Gold 1515 filter
1997 Ford F-250 HD 7.3 Powerstroke V8: T6 5W-40 FRAM PH-3786 filter
Re: Mixing Pennzoil Platinum and Castrol Magnatec. [Re: GRWOil] #4441261
06/25/17 03:19 PM
06/25/17 03:19 PM
South Texas Rancho
TexasVaquero Offline
South Texas Rancho
I don't think anything bad is gonna happen. One thing I have been told by Mobil 1 is that if you mix different oils, you reduce both oils' benefits, but that does not make them any worse.
2014 NISSAN VERSA 5spd M/T- M1 EP 5w30 and M1 EP Filter. 5k OCI.
2011 CHEVY IMPALA 3.5ltrs - M1 HM 5w30 and M1 EP Filter. 3k OCI.
Re: Mixing Pennzoil Platinum and Castrol Magnatec. [Re: jongies3] #4441304
06/25/17 04:23 PM
06/25/17 04:23 PM
'Stralia
Shannow Online content
Shannow  Online Content
'Stralia
Really ? show me where that's a fact ...
Re: Mixing Pennzoil Platinum and Castrol Magnatec. [Re: GRWOil] #4441308
06/25/17 04:26 PM
06/25/17 04:26 PM
Crawfordville FL
SilverFusion2010 Offline
Crawfordville FL
When possible do not mix. The oil isn't going to turn into tar or anything but you're guessing at additive packages and don't really know what you end up with. It's likely that the mix would be less effective than either oil by itself depending on the additives in the two oils.
The folks who mix are trying to build a better mousetrap. It's not needed.
2010 Ford Fusion SE 3.0L V6, 181 miles M1 HM 10w-30
Re: Mixing Pennzoil Platinum and Castrol Magnatec. [Re: GRWOil] #4441314
06/25/17 04:33 PM
06/25/17 04:33 PM
Connecticut
69GTX Offline
69GTX  Offline
Connecticut
If you're going to mix oil brands/grades, those 2 are fairly close in additive packages. High calcium, no magnesium, no sodium oils.
2001 Lincoln Cont 4.6L DOHC/ 39K mi / QS HM 5w30 / FUG XG2
1969 Ply GTX/RRs
Re: Mixing Pennzoil Platinum and Castrol Magnatec. [Re: GRWOil] #4441373
06/25/17 05:31 PM
06/25/17 05:31 PM
Down Under
SR5 Online content
SR5  Online Content
Down Under
I would not worry about it, for 6 months in a Hyundai with two name brand synthetics. I worry more about people who don't check the oil level and let it get too low.
Castrol GTX Ultraclean 15W40 A3/B3 + Wesfil-Cooper Z154
Re: Mixing Pennzoil Platinum and Castrol Magnatec. [Re: GRWOil] #4441387
06/25/17 05:49 PM
06/25/17 05:49 PM
California
Errtt Offline
Errtt  Offline
California
Once knew someone who mixed like 4 different HM oils. I think it was a quart each for about a 4 quart sump. He had some weird name of his mix. Your Pentrol Plattec should be fine.
Re: Mixing Pennzoil Platinum and Castrol Magnatec. [Re: GRWOil] #4441403
06/25/17 06:01 PM
06/25/17 06:01 PM
Down Under
SR5 Online content
SR5  Online Content
Down Under
Magna-Platinum
Re: Mixing Pennzoil Platinum and Castrol Magnatec. [Re: GRWOil] #4441419
06/25/17 06:23 PM
06/25/17 06:23 PM
MN
WillsYoda Offline
WillsYoda  Offline
MN
Mix away camp here. Similar add packs. Will work fine. I do it, since I hate waste.
Re: Mixing Pennzoil Platinum and Castrol Magnatec. [Re: Errtt] #4441533
06/25/17 08:46 PM
06/25/17 08:46 PM
Grand Rapids, MI
ThirdeYe Offline
ThirdeYe  Offline
Grand Rapids, MI
I had 3 different oils in my crankcase on my last oil change. I started with Pennzoil Platinum High Mileage, but topped off with Havoline High Mileage and 2 quarts of Formula Shell along the way (all in 5W-20). Still ran just fine. In fact, for some reason it seemed to consume less after it became more of a hodgepodge of oils. grin
07 Honda Accord - 608k - Havoline High Mileage 5W-20/Purolator Synthetic PSL14610
98 Camaro Z28 (Bright Purple Metallic, 1 of 104) - 122k - QS Defy 5w30/AC Delco PF46
Re: Mixing Pennzoil Platinum and Castrol Magnatec. [Re: jongies3] #4441540
06/25/17 08:59 PM
06/25/17 08:59 PM
US-WA
Dyusik Offline
Dyusik  Offline
US-WA
That is your answer, including atf etc.
95 Cherokee 190K DELO 10W30, XG8
07 IS250 103K Napa 10w30, FULL
04 YZF-R1 19K DELO 15w40, XG7317
99 HD XL1200S 21K VR1 20w50, NG1515
14 RX450h 35k PP MIX, NG7047
