Found this bottle of green Lubegard ATF additive. This: https://www.amazon.com/Lubegard-62005-M-V-ATF-Supplement/dp/B004BSOIIM
I'm not sure if this is appropiate for my 2010 Mazda 3. Says: "Enhances Dex/Merc to Perform Like Mercon V", "Resolves Additive Depletion in Mercon V", "Protects the Fluid. Protects the Transmission." "Automatic Transmission Supplement for Ford Applications". Since my car is basically a Ford Focus, parts of the tranny say "FordMoCo", I figure it shouldn't hurt. I know that Mazda specs a specific ATF for its cars. Mazda M-V, which doesn't mean "Mercon-V". I've read somewhere that people have used Mercon V in place of M-V with no ill results. Just wanted to see if this green bottle is worth using, since I didn't even know I had it and might as well throw it in. In the future, if I ever use Lubegard ATF additives, should I go with another kind?
